[SCM] PostGIS branch master updated. 3.4.0rc1-720-ga6aec22a6
Fri Oct 27 06:31:44 PDT 2023
the project "PostGIS".
       via  a6aec22a64d7bcad2ac76cac3e68fd7579db2a36 (commit)
      from  2b56d4ae741f4667b87b78d813368fd184980e30 (commit)
revisions in full, below.
commit a6aec22a64d7bcad2ac76cac3e68fd7579db2a36
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Oct 27 15:31:22 2023 +0200
    run_test.pl: ensure success return from create_db if nothing goes wrong
diff --git a/regress/run_test.pl b/regress/run_test.pl
index e8e80936f..ab001b1a1 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -438,7 +438,7 @@ if ( $OPT_DUMPRESTORE )
     print "Creating db '${DB}'\n";
     $rv = create_db();
     if ( ! $rv ) {
-        fail("Could not create db ${DB}", $REGRESS_LOG);
+        fail("Could not create db ${DB} (create_db returned $rv)", $REGRESS_LOG);
         die;
@@ -1527,6 +1527,8 @@ sub create_db
 		print "Running after-create-db-script $hook\n";
 		die unless load_sql_file($hook, 1);
+	return 1;
 sub create_spatial
Summary of changes:
 regress/run_test.pl | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
hooks/post-receive
