[PostGIS] #5584: PostGIS Upgrade Issue
PostGIS trac at osgeo.org
Fri Oct 27 07:16:58 PDT 2023
  Reporter:  rama                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  critical               |  Milestone:  PostGIS Packaging
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:  windows
Comment (by rama):
 Thank you @robe it worked. Thank you for your extended support.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5584#comment:14>
