[PostGIS] #5592: Postgres Upgrade Compatibility with PostGIS Extension
PostGIS trac at osgeo.org
Fri Oct 27 09:53:50 PDT 2023
  Reporter:  rama        |      Owner:  pramsey
      Type:  task        |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 3.4.1
 Component:  postgis     |    Version:  3.3.x
Resolution:  worksforme  |   Keywords:  PostgreSQL V16 Upgrade Dependency
Changes (by robe):
 * status:  new => closed
 * resolution:   => worksforme
Comment:
 Since PostGIS 3+, you should be able to easily pg_upgrade from a 3.* to a
 3.*
 That said, to use pg_upgrade to upgrade you to 3.4. Do this
 1) Upgrade your pg 11 from 2.5 to 3.3
 2) Then that said install PG16 PostGIS 3.4.0
 Then you should have no issue doing pg_uprade from 11 3.3 to 16 3.4
 Once you have PG16 upgraded, run
 SELECT postgis_extensions_upgrade();
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5592#comment:2>
