[PostGIS] #5593: Fails to build with imagemagic 6.9.12.98
PostGIS trac at osgeo.org
Fri Oct 27 13:00:29 PDT 2023
 Reporter:  Bas Couwenberg         |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.1
Component:  build/upgrade/install  |    Version:  3.4.x
 Keywords:                         |
 As reported in [https://bugs.debian.org/1054715 Debian Bug #1054715]:
 > During a rebuild of all packages in sid, your package failed to build
 > on amd64.
 > Relevant part (hopefully):
 > make[3]: Entering directory '/<<PKGBUILDDIR>>/doc/html/images'
 > x86_64-linux-gnu-gcc -I../../../liblwgeom -I../../../liblwgeom
 -I/usr/include -I/usr/include/x86_64-linux-gnu -I/usr/include/webp
 -I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c   -DNDEBUG
 -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu99 -g -O2 -ffile-prefix-
 map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -fstack-clash-protection
 -Wformat -Werror=format-security -fcf-protection -fno-math-errno -fno-
 signed-zeros -Wall -flto -I/usr/include/x86_64-linux-gnu
 -I/usr/include/webp  -c -o styles.o styles.c
 -I/usr/include/webp  -c -o generator.o generator.c
 > /bin/bash ../../../libtool --mode=link \
 > x86_64-linux-gnu-gcc -o generator styles.o generator.o
 ../../../liblwgeom/.libs/liblwgeom.a -Wl,-z,relro -Wl,-z,now -lm -flto
 -L/usr/lib/x86_64-linux-gnu -lgeos_c -lproj
 > libtool: link: x86_64-linux-gnu-gcc -o generator styles.o generator.o
 -Wl,-z -Wl,relro -Wl,-z -Wl,now -flto
 ../../../liblwgeom/.libs/liblwgeom.a -lm -L/usr/lib/x86_64-linux-gnu
 -lgeos_c -lproj
 > convert-im6.q16: attempt to perform an operation not allowed by the
 security policy `@generator-REtQrw/draw0' @
 error/string.c/FileToString/1020.
 > Failure return code (1) from command: convert -size 200x200 xc:none
 -fill none -stroke "#6495ED" -strokewidth 4 -draw '@generator-
 REtQrw/draw0' -flip generator-REtQrw/tmp0.pngreading styles from
 wkt/styles.conf
 > make[3]: *** [Makefile:261: de9im01.png] Error 1
 > The full build log is available from:
 > http://qa-logs.debian.net/2023/10/27/postgis_3.4.0+dfsg-2_unstable.log
 The imagemagick package was recently updated from 6.9.11.60 to 6.9.12.98
 in Debian unstable.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5593>
