[PostGIS] #5595: A Crash bug occur in ST_PointOnSurface
PostGIS trac at osgeo.org
Sun Oct 29 02:55:14 PDT 2023
 Reporter:  Wenjing   |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  critical  |  Milestone:  PostGIS 3.5.0
Component:  postgis   |    Version:  3.4.x
 Keywords:            |
 The following statement crashes PostGIS:
 SELECT ST_PointOnSurface(g)  FROM ST_GeomFromText('MULTIPOINT((0 0),
 EMPTY)') As g;
 Here is stack information:
 #0  geos::algorithm::InteriorPointPoint::add (this=0x7ffed776fe60,
 point=0x0)
     at /home/wendy/PostGIS/postgis-
 workshop-2020/geos/src/algorithm/InteriorPointPoint.cpp:69
 #1  0x00007f62b0180f4a in geos::algorithm::InteriorPointPoint::add
     geom=<optimized out>)
 workshop-2020/geos/src/algorithm/InteriorPointPoint.cpp:59
 #2  0x00007f62b0180ff6 in
 geos::algorithm::InteriorPointPoint::InteriorPointPoint (
     this=<optimized out>, g=<optimized out>)
 workshop-2020/geos/src/algorithm/InteriorPointPoint.cpp:42
 #3  0x00007f62b0197e85 in geos::geom::Geometry::getInteriorPoint (
     this=this at entry=0x556c1e75b880)
 workshop-2020/geos/src/geom/Geometry.cpp:189
 #4  0x00007f62b089b0a8 in operator() (__closure=<optimized out>)
 --Type <RET> for more, q to quit, c to continue without paging--
    gis-workshop-2020/geos/capi/geos_ts_c.cpp:1458
 #5  execute<GEOSPointOnSurface_r(GEOSContextHandle_t, const
 geos::geom::Geometry*)::<lambda()> > (f=..., extHandle=0x556c1ea26be0)
 workshop-2020/geos/capi/geos_ts_c.cpp:408
 #6  GEOSPointOnSurface_r (extHandle=0x556c1ea26be0, g1=0x556c1e75b880)
 workshop-2020/geos/capi/geos_ts_c.cpp:1457
 #7  0x00007f62b09abb17 in lwgeom_pointonsurface (geom=<optimized out>)
     at lwgeom_geos.c:1074
 #8  0x00007f62b08f8f80 in pointonsurface (fcinfo=0x556c1e6e8ef0) at
 lwgeom_geos.c:1535
 #9  0x0000556c1d24a4f0 in ExecInterpExpr ()
 #10 0x0000556c1d337c94 in evaluate_expr ()
 #11 0x0000556c1d337ee1 in simplify_function ()
 #12 0x0000556c1d338e7d in eval_const_expressions_mutator ()
 #13 0x0000556c1d2b5a61 in expression_tree_mutator_impl ()
 #14 0x0000556c1d2b5f04 in expression_tree_mutator_impl ()
 #15 0x0000556c1d339de3 in eval_const_expressions ()
 #16 0x0000556c1d31fcd8 in preprocess_expression ()
 #17 0x0000556c1d327072 in subquery_planner ()
 #18 0x0000556c1d327863 in standard_planner ()
 #19 0x0000556c1d3e42bf in pg_plan_query ()
 #20 0x0000556c1d3e43a1 in pg_plan_queries ()
 #21 0x0000556c1d3e4680 in exec_simple_query ()
 #22 0x0000556c1d3e6aae in PostgresMain ()
 #23 0x0000556c1d36142e in ServerLoop ()
 #24 0x0000556c1d36237c in PostmasterMain ()
 #25 0x0000556c1d0b6cb1 in main ()
 The version is the newest in GitHub:
 POSTGIS="3.5.0dev 3.4.0rc1-705-g5c3ec8392" [EXTENSION] PGSQL="170"
 GEOS="3.13.0dev-CAPI-1.18.0" PROJ="8.2.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/share/proj/proj.db" LIBXML="2.9.13"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5595>
