[PostGIS] #5535: String handling in debug_standardize_address
PostGIS trac at osgeo.org
Mon Oct 30 10:26:09 PDT 2023
  Reporter:  pramsey              |      Owner:  robe
      Type:  defect               |     Status:  new
  Priority:  medium               |  Milestone:  PostGIS 3.4.1
 Component:  pagc_address_parser  |    Version:  3.4.x
Resolution:                       |   Keywords:
Comment (by strk):
 The astyle script created by `make astyle` checks astyle version and
 refuses to run if you don' thave 1.23 (as we had different results with
 different versions). It'd be hard to have that version nowadays so I dubt
 anyone is using that.
 If you changed all lines I guess you could give it a consistent style with
 astyle (updating that astyle.sh script?). Just make sure .editorconfig
 will keep the choosen style afterwards.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5535#comment:4>
