[SCM] PostGIS branch stable-3.4 updated. 3.4.0-61-g8731cb579
Mon Oct 30 16:51:39 PDT 2023
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  8731cb579fb79286f968955798f647c3bc51cf9f (commit)
      from  2516ed21bef5de664847daf5400a0520bfd70ed3 (commit)
revisions in full, below.
commit 8731cb579fb79286f968955798f647c3bc51cf9f
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Oct 30 19:51:35 2023 -0400
    Update to new home of sfcgal. References #5600 for PostGIS 3.4.1
diff --git a/README.postgis b/README.postgis
index d7262a057..d94a466ed 100644
--- a/README.postgis
+++ b/README.postgis
@@ -96,7 +96,7 @@ For apt-based systems you can run this command to install the below dependencies
 * SFCGAL 1.4.1+ is requires for additional functionality ST_AlphaShape, ST_OptimalAlphaShape,
   and ST_3DConvexhull
-  https://gitlab.com/Oslandia/SFCGAL
+  https://gitlab.com/sfcgal/SFCGAL
 * protobuf-c (Optional, Version 1.1.0 or higher)
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 7ec9944c3..168e68bb3 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -214,7 +214,7 @@ echo "LIBICONV VERSION: ${ICON_VER} http://ftp.gnu.org/gnu/libiconv/libiconv-${I
 if [ -n "$SFCGAL_VER"  ]; then
     echo "CGAL VERSION: ${CGAL_VER} http://www.cgal.org" >> $verfile
     echo "BOOST VERSION: ${BOOST_VER} http://www.boost.org" >> $verfile
-    echo "SFCGAL VERSION: ${SFCGAL_VER} http://www.sfcgal.org https://github.com/Oslandia/SFCGAL" >> $verfile
+    echo "SFCGAL VERSION: ${SFCGAL_VER} http://www.sfcgal.org https://gitlab.com/sfcgal/SFCGAL" >> $verfile
 fi;
 if [ -f ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/gdal_depends.txt ]; then
diff --git a/doc/installation.xml b/doc/installation.xml
index ff15ae3f5..a7fcf30d4 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -246,9 +246,9 @@ sh autogen.sh
 	  <listitem>
 		<para>
-			SFCGAL, version 1.3.1 (or higher), 1.4.1 or higher is recommended and required to be able to use all functionality. SFCGAL can be used to provide additional 2D and 3D advanced analysis functions to PostGIS cf <xref linkend="reference_sfcgal" />. And also allow to use SFCGAL rather than GEOS for some 2D functions provided by both backends (like ST_Intersection or ST_Area, for instance). A PostgreSQL configuration variable <code>postgis.backend</code> allow end user to control which backend he want to use if SFCGAL is installed (GEOS by default). Nota: SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: <ulink url="https://oslandia.gitlab.io/SFCGAL/dev.html">https://oslandia.gitlab.io/SFCGAL/dev.html</ulink>)
+			SFCGAL, version 1.3.1 (or higher), 1.4.1 or higher is recommended and required to be able to use all functionality. SFCGAL can be used to provide additional 2D and 3D advanced analysis functions to PostGIS cf <xref linkend="reference_sfcgal" />. And also allow to use SFCGAL rather than GEOS for some 2D functions provided by both backends (like ST_Intersection or ST_Area, for instance). A PostgreSQL configuration variable <code>postgis.backend</code> allow end user to control which backend he want to use if SFCGAL is installed (GEOS by default). Nota: SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: <ulink url="https://sfcgal.org">https://sfcgal.org</ulink>)
-		  <ulink url="https://gitlab.com/Oslandia/SFCGAL/">https://gitlab.com/Oslandia/SFCGAL/</ulink>.
+		  <ulink url="https://gitlab.com/sfcgal/SFCGAL/">https://gitlab.com/sfcgal/SFCGAL/</ulink>.
 		</para>
 	  </listitem>
Summary of changes:
 README.postgis               | 2 +-
 ci/winnie/package_postgis.sh | 2 +-
 doc/installation.xml         | 4 ++--
 3 files changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
