[SCM] PostGIS branch stable-3.4 updated. 3.4.0-62-gb154cfb19
    git at osgeo.org
    git at osgeo.org
    Tue Oct 31 05:59:11 PDT 2023
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  b154cfb19df496b517109f2d769162d2793520e2 (commit)
      from  8731cb579fb79286f968955798f647c3bc51cf9f (commit)
revisions in full, below.
commit b154cfb19df496b517109f2d769162d2793520e2
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Oct 31 08:59:07 2023 -0400
    Fix ST_AlphaShape examples, per Dapeng Wang observations
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index 31ea1c29c..3e503739e 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -548,48 +548,53 @@ FROM ( SELECT ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
         <caption><para>Alpha-shape of a MultiPoint (same example As <xref linkend="ST_OptimalAlphaShape" />)</para></caption>
       </mediaobject>
     </informalfigure>
-         <programlisting>SELECT ST_AsText(ST_AlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),
+    <programlisting>SELECT ST_AsText(ST_AlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),
                 (88 29),(24 82),(32 51),(37 23),(27 54),(84 19),(75 87),(44 42),(77 67),(90 30),(36 61),(32 65),
                 (81 47),(88 58),(68 73),(49 95),(81 60),(87 50),
                 (78 16),(79 21),(30 22),(78 43),(26 85),(48 34),(35 35),(36 40),(31 79),(83 29),(27 84),(52 98),(72 95),(85 71),
                 (75 84),(75 77),(81 29),(77 73),(41 42),(83 72),(23 36),(89 53),(27 57),(57 97),(27 77),(39 88),(60 81),
                 (80 72),(54 32),(55 26),(62 22),(70 20),(76 27),(84 35),(87 42),(82 54),(83 64),(69 86),(60 90),(50 86),(43 80),(36 73),
                 (36 68),(40 75),(24 67),(23 60),(26 44),(28 33),(40 32),(43 19),(65 16),(73 16),(38 46),(31 59),(34 86),(45 90),(64 97))'::geometry,80.2));</programlisting>
-          <screen>POLYGON((89 53,91 50,87 42,90 30,88 29,84 19,78 16,73 16,65 16,53 18,43 19,37 23,30 22,28 33,23 36,26 44,27 54,23 60,24 67,
-          27 77,24 82,26 85,34 86,39 88,45 90,49 95,52 98,57 97,64 97,72 95,76 88,75 84,83 72,85 71,88 58,89 53))</screen>
+    <screen>POLYGON((89 53,91 50,87 42,90 30,88 29,84 19,78 16,73 16,65 16,53 18,43 19,
+37 23,30 22,28 33,23 36,26 44,27 54,23 60,24 67,27 77,
+24 82,26 85,34 86,39 88,45 90,49 95,52 98,57 97,
+64 97,72 95,76 88,75 84,83 72,85 71,88 58,89 53))</screen>
         </para>
     <para>
         <informalfigure>
         <mediaobject>
             <imageobject>
-            <imagedata fileref="images/st_alphashape02.png" />
+            <imagedata fileref="images/st_alphashape02.png"/>
             </imageobject>
-            <caption><para>Alpha-shape of a MultiPoint, allowing holes (same example as <xref linkend="ST_OptimalAlphaShape" />)</para></caption>
+            <caption><para>Alpha-shape of a MultiPoint, allowing holes (same example as <xref linkend="ST_OptimalAlphaShape"/>)</para></caption>
         </mediaobject>
         </informalfigure>
-            <programlisting>SELECT ST_AsText(ST_AlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),(88 29),(24 82),(32 51),(37 23),(27 54),(84 19),(75 87),(44 42),(77 67),(90 30),(36 61),(32 65),(81 47),(88 58),(68 73),(49 95),(81 60),(87 50),
+        <programlisting>SELECT ST_AsText(ST_AlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),(88 29),(24 82),(32 51),(37 23),(27 54),(84 19),(75 87),(44 42),(77 67),(90 30),(36 61),(32 65),(81 47),(88 58),(68 73),(49 95),(81 60),(87 50),
                 (36 68),(40 75),(24 67),(23 60),(26 44),(28 33),(40 32),(43 19),(65 16),(73 16),(38 46),(31 59),(34 86),(45 90),(64 97))'::geometry, 100.1,true))</programlisting>
-            <screen>POLYGON((89 53,91 50,87 42,90 30,88 29,84 19,78 16,73 16,65 16,53 18,43 19,37 23,30 22,28 33,23 36,26 44,27 54,23 60,24 67,27 77,24 82,26 85,34 86,39 88,45 90,49 95,52 98,57 97,64 97,72 95,76 88,75 84,83 72,85 71,88 58,89 53),
-              (36 61,36 68,40 75,43 80,50 86,60 81,68 73,77 67,81 60,82 54,81 47,78 43,76 27,62 22,54 32,48 34,44 42,38 46,36 61))</screen>
+            <screen>POLYGON((89 53,91 50,87 42,90 30,84 19,78 16,73 16,65 16,53 18,43 19,30 22,28 33,23 36,
+26 44,27 54,23 60,24 67,27 77,24 82,26 85,34 86,39 88,45 90,49 95,52 98,57 97,64 97,72 95,
+76 88,75 84,83 72,85 71,88 58,89 53),(36 61,36 68,40 75,43 80,60 81,68 73,77 67,
+81 60,82 54,81 47,78 43,76 27,62 22,54 32,44 42,38 46,36 61))</screen>
     </para>
     <para>
         <informalfigure>
         <mediaobject>
             <imageobject>
-            <imagedata fileref="images/st_alphashape03.png" />
+            <imagedata fileref="images/st_alphashape03.png"/>
             </imageobject>
-            <caption><para>Alpha-shape of a MultiPoint, allowing holes (same example as <xref linkend="ST_ConcaveHull" />)</para></caption>
+            <caption><para>Alpha-shape of a MultiPoint, allowing holes (same example as <xref linkend="ST_ConcaveHull"/>)</para></caption>
         </mediaobject>
         </informalfigure>
-            <programlisting>SELECT ST_AlphaShape(
-            'MULTIPOINT ((132 64), (114 64), (99 64), (81 64), (63 64), (57 49), (52 36), (46 20), (37 20), (26 20), (32 36), (39 55), (43 69), (50 84), (57 100), (63 118), (68 133), (74 149), (81 164), (88 180), (101 180), (112 180), (119 164), (126 149), (132 131), (139 113), (143 100), (150 84), (157 69), (163 51), (168 36), (174 20), (163 20), (150 20), (143 36), (139 49), (132 64), (99 151), (92 138), (88 124), (81 109), (74 93), (70 82), (83 82), (99 82), (112 82), (126 82), (121 96), (114 109), (110 122), (103 138), (99 151), (34 27), (43 31), (48 44), (46 58), (52 73), (63 73), (61 84), (72 71), (90 69), (101 76), (123 71), (141 62), (166 27), (150 33), (159 36), (146 44), (154 53), (152 62), (146 73), (134 76), (143 82), (141 91), (130 98), (126 104), (132 113), (128 127), (117 122), (112 133), (119 144), (108 147), (119 153), (110 171), (103 164), (92 171), (86 160), (88 142), (79 140), (72 124), (83 131), (79 118), (68 113), (63 102), (68 93), (35 45))'::geometry,102.2, t
 rue);</programlisting>
-            <screen>POLYGON((134 80,136 75,130 63,135 45,132 44,126 28,117 24,110 24,98 24,80 27,82 39,72 51,60 48,56 34,52 52,42 50,
-                34 54,39 66,40 81,34 90,36 100,40 116,36 123,39 128,51 129,58 132,68 135,74 142,78 147,86 146,96 146,
-                108 142,114 132,112 126,112 116,116 110,120 108,125 108,128 106,125 96,132 87,134 80))</screen>
+            'MULTIPOINT ((132 64), (114 64), (99 64), (81 64), (63 64), (57 49), (52 36), (46 20), (37 20), (26 20), (32 36), (39 55), (43 69), (50 84), (57 100), (63 118), (68 133), (74 149), (81 164), (88 180), (101 180), (112 180), (119 164), (126 149), (132 131), (139 113), (143 100), (150 84), (157 69), (163 51), (168 36), (174 20), (163 20), (150 20), (143 36), (139 49), (132 64), (99 151), (92 138), (88 124), (81 109), (74 93), (70 82), (83 82), (99 82), (112 82), (126 82), (121 96), (114 109), (110 122), (103 138), (99 151), (34 27), (43 31), (48 44), (46 58), (52 73), (63 73), (61 84), (72 71), (90 69), (101 76), (123 71), (141 62), (166 27), (150 33), (159 36), (146 44), (154 53), (152 62), (146 73), (134 76), (143 82), (141 91), (130 98), (126 104), (132 113), (128 127), (117 122), (112 133), (119 144), (108 147), (119 153), (110 171), (103 164), (92 171), (86 160), (88 142), (79 140), (72 124), (83 131), (79 118), (68 113), (63 102), (68 93), (35 45))'::geometry,102.2, t
 rue));</programlisting>
+            <screen>POLYGON((26 20,32 36,35 45,39 55,43 69,50 84,57 100,63 118,68 133,74 149,81 164,88 180,
+						101 180,112 180,119 164,126 149,132 131,139 113,143 100,150 84,157 69,163 51,168 36,
+						174 20,163 20,150 20,143 36,139 49,132 64,114 64,99 64,90 69,81 64,63 64,57 49,52 36,46 20,37 20,26 20),
+						(74 93,81 109,88 124,92 138,103 138,110 122,114 109,121 96,112 82,99 82,83 82,74 93))</screen>
     </para>
 	  </refsection>
       <refsection>
Summary of changes:
 doc/reference_sfcgal.xml | 35 ++++++++++++++++++++---------------
 1 file changed, 20 insertions(+), 15 deletions(-)
hooks/post-receive
