[PostGIS] #5601: A ST_Intersect row is missed when using JOIN.
PostGIS trac at osgeo.org
Tue Oct 31 06:38:55 PDT 2023
  Reporter:  Wenjing   |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS GEOS
 Component:  postgis   |    Version:  3.4.x
Resolution:            |   Keywords:
Comment (by Wenjing):
 Sorry for forgetting to add the version
 I use the version is the newest in GitHub:
 POSTGIS="3.5.0dev 3.4.0rc1-705-g5c3ec8392" [EXTENSION] PGSQL="170"
 GEOS="3.13.0dev-CAPI-1.18.0" PROJ="8.2.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org/ USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/share/proj/proj.db" LIBXML="2.9.13"
 It seems a regression issue?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5601#comment:3>
