[PostGIS] #5601: A ST_Intersect row is missed when using JOIN.
PostGIS trac at osgeo.org
Tue Oct 31 15:00:20 PDT 2023
  Reporter:  Wenjing   |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS GEOS
 Component:  postgis   |    Version:  3.4.x
Resolution:            |   Keywords:
Comment (by mdavis):
 The fix for this in GEOS 3.12 was in
 [https://github.com/libgeos/geos/pull/774 GEOS 774].  I'll be backporting
 it to 3.11 and 3.10.
 To be clear, this only affects mixed-type geometry collections with point
 elements.  So the problem should be fairly rare in practice.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5601#comment:6>
