[SCM] PostGIS branch master updated. 3.4.0rc1-739-g5c37f9732
Tue Oct 31 23:34:59 PDT 2023
the project "PostGIS".
       via  5c37f97329db3fc67b542d12ac31d73ad2f71c5a (commit)
       via  e2bf40c322c8805ca13e5a270b98b2793ee436a3 (commit)
       via  85395aaa89ccdf54593b3fb6efd88916d798816d (commit)
      from  2ef9d749d796709ce3f798caf76d584698e8f858 (commit)
revisions in full, below.
commit 5c37f97329db3fc67b542d12ac31d73ad2f71c5a
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Oct 8 21:27:26 2023 +0200
    [woodie] Test with unprivileged user under pgextwlist
    Closes #5566
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index aa8081b43..c0bbe64ca 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -17,11 +17,19 @@ steps:
   regress-pg12:
     image: *test-image
     group: build
+    environment:
+      - PGVER=12
+      - POSTGIS_REGRESS_DB_OWNER=postgis_reg_unprivileged_user
+      - RUNTESTFLAGS=--after-create-db-script $${CI_WORKSPACE}/regress/hooks/configure-pgextwlist.sql
     commands:
-      - PGVER=12 sh ci/dronie/postgis_regress.sh
+      - sh ci/dronie/postgis_regress.sh
   regress-pg15:
     image: *test-image
     group: build
+    environment:
+      - PGVER=15
     commands:
-      - PGVER=15 sh ci/dronie/postgis_regress.sh
commit e2bf40c322c8805ca13e5a270b98b2793ee436a3
Date:   Tue Oct 31 23:18:48 2023 +0100
    Set ownership of packaged functions to extension owner
    Still check that the functions were owned by a superuser.
    References #4648
    References #5545
    References #5566
diff --git a/utils/create_unpackaged.pl b/utils/create_unpackaged.pl
index a50725158..e7021d87a 100755
--- a/utils/create_unpackaged.pl
+++ b/utils/create_unpackaged.pl
@@ -331,26 +331,41 @@ DROP FUNCTION _postgis_package_object(text, text);
 DO LANGUAGE 'plpgsql' \$BODY\$
 DECLARE
 	rec RECORD;
+	sql TEXT;
 BEGIN
-	-- Check ownership of extension functions
-	-- matches ownership of extension itself
+	-- Check extension functions are all owned by a superuser
 	FOR rec IN
 		SELECT
 			p.oid,
 			p.proowner,
-			e.extowner
+			e.extowner,
+			r.rolsuper
 		FROM pg_catalog.pg_depend AS d
 			INNER JOIN pg_catalog.pg_extension AS e ON (d.refobjid = e.oid)
 			INNER JOIN pg_catalog.pg_proc AS p ON (d.objid = p.oid)
+			INNER JOIN pg_catalog.pg_roles AS r ON (r.oid = p.proowner)
 		WHERE d.refclassid = 'pg_catalog.pg_extension'::pg_catalog.regclass
 		AND deptype = 'e'
 		AND e.extname = '${extname}'
 		AND d.classid = 'pg_catalog.pg_proc'::pg_catalog.regclass
-		AND p.proowner != e.extowner
 	LOOP
-		RAISE EXCEPTION 'Function % is owned by % but extension is owned by %',
-				rec.oid::regprocedure, rec.proowner::regrole, rec.extowner::regrole;
+		IF NOT rec.rolsuper THEN
+			RAISE EXCEPTION 'Function % is owned by non-superuser %',
+					rec.oid::regprocedure, rec.proowner::regrole;
+		END IF;
+		IF NOT rec.proowner = rec.extowner THEN
+			RAISE NOTICE
+					'Changing ownership of function % from % to % to match ext',
+					rec.oid::regprocedure, rec.proowner::regrole,
+					rec.extowner::regrole;
+			sql := format(
+				'ALTER FUNCTION %s OWNER TO %I',
+			EXECUTE sql;
+		END IF;
 	END LOOP;
 	-- TODO: check ownership of more objects ?
commit 85395aaa89ccdf54593b3fb6efd88916d798816d
Date:   Tue Oct 31 21:41:18 2023 +0100
    run_test.pl: use db ext creator for upgrading too
    References #5566
diff --git a/regress/run_test.pl b/regress/run_test.pl
index ab001b1a1..bc4daf5e7 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -772,7 +772,7 @@ Environment Variables:
                   Defaults to connecting user (determined by libpq env
                   variables)
   POSTGIS_REGRESS_ROLE_EXT_CREATOR
-                  PostgreSQL role to switch to for creating the
+                  PostgreSQL role to switch to for creating/upgrading the
                   postgis extensions. Defaults to POSTGIS_REGRESS_DB_OWNER
   POSTGIS_REGRESS_DIR
                   Base directory of regress tests. Defaults to
@@ -1842,6 +1842,11 @@ sub upgrade_spatial_extensions
     my $sql;
     my $upgrade_via_function = 0;
+    if ( $DB_ROLE_EXT_MKR ) {
+      print "Using role '$DB_ROLE_EXT_MKR' for spatial extensions upgrade.\n";
+      $psql_opts .= " -c \"set role='$DB_ROLE_EXT_MKR'\"";
     if ( $OPT_UPGRADE_TO =~ /!$/ )
       $OPT_UPGRADE_TO =~ s/!$//;
Summary of changes:
 .woodpecker/regress.yml    | 12 ++++++++++--
 regress/run_test.pl        |  7 ++++++-
 utils/create_unpackaged.pl | 27 +++++++++++++++++++++------
 3 files changed, 37 insertions(+), 9 deletions(-)
hooks/post-receive
