[PostGIS] #5545: Postgis upgrade from 3.2.3 to 3.3.2 failing on create or update function st_orderingequals
PostGIS trac at osgeo.org
Tue Oct 31 23:41:28 PDT 2023
st_orderingequals
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.3.5
 Component:  upgrade  |    Version:  3.4.x
Resolution:           |   Keywords:  pgextwlist
Comment (by strk):
 As of [e2bf40c322c8805ca13e5a270b98b2793ee436a3/git] we change ownership
 of unpackaged function at packaging time, after checking they are owned by
 a superuser. This may or may not fix this problem, as PostgreSQL core
 could be preventing packaging earlier in the process. For some reason I
 don't see failure in pgextwlist-based CI at this stage.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5545#comment:17>
