[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-99-ge27edc502
Fri Sep 1 01:07:54 PDT 2023
the project "PostGIS".
       via  e27edc5029c6199d5e8f89793928ac593f41544d (commit)
      from  16db45e4a2bcf4ab276305794dc3dbfee7b8b1a5 (commit)
revisions in full, below.
commit e27edc5029c6199d5e8f89793928ac593f41544d
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Aug 31 21:55:18 2023 +0200
    Have run_test.pl hint about what might be missing from upgrade drop
diff --git a/regress/run_test.pl b/regress/run_test.pl
index a9cce2a56..30e576cdd 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -2061,6 +2061,29 @@ sub uninstall_spatial
 	if ( $OBJ_COUNT_POST != $OBJ_COUNT_PRE )
 		fail("Object count pre-install ($OBJ_COUNT_PRE) != post-uninstall ($OBJ_COUNT_POST)");
+        if ( $OPT_UPGRADE_FROM )
+            my $fromversion = $OPT_UPGRADE_FROM;
+            $fromversion =~ s/unpackaged//;
+            print
+                "\n-------------------------------------------------\n",
+                "Need to add these to an after_upgrade.sql script?",
+                sql("
+SELECT format(
+    'SELECT _postgis_drop_function_by_identity(%L, %L, %L);',
+    proname,
+    pg_catalog.pg_get_function_identity_arguments(oid),
+    '$fromversion'
+FROM pg_proc
+WHERE pronamespace = '${OPT_SCHEMA}'::regnamespace
+ORDER BY 1;
 		return 0;
Summary of changes:
 regress/run_test.pl | 23 +++++++++++++++++++++++
 1 file changed, 23 insertions(+)
hooks/post-receive
