[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-100-ga25edd673
Fri Sep 1 02:01:48 PDT 2023
the project "PostGIS".
       via  a25edd67373e1b6c008034d62600899ce13bb93d (commit)
      from  e27edc5029c6199d5e8f89793928ac593f41544d (commit)
revisions in full, below.
commit a25edd67373e1b6c008034d62600899ce13bb93d
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 1 10:59:10 2023 +0200
    Make sure the expected/ dir is created in build tree
    References #5522 in master branch (3.5.0dev)
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index dc13a272a..0941ed562 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -58,6 +58,7 @@ PG_CPPFLAGS = @CFLAGS@ @CPPFLAGS@ -DPCRE_VERSION=@PCRE_VERSION@
 SHLIB_LINK = @SHLIB_LINK@ @PCRE_LDFLAGS@
 EXTRA_CLEAN = sql/ usps-st-city-name.txt mk-st-regexp mk-city-regex test_main
 REGRESS = test-init-extensions test-parseaddress test-standardize_address_1 test-standardize_address_2 test-debug_standardize_address
 sql:
 	mkdir -p $@
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 49c8a975a..516b52882 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -43,6 +43,7 @@ endif
 all: sql/$(EXTENSION)_pre.sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql sql/test-normalize_address.sql sql/test-pagc_normalize_address.sql expected/test-normalize_address.out expected/test-pagc_normalize_address.out sql/test-upgrade.sql expected/test-upgrade.out
+.PHONY: expected
 expected:
 	mkdir -p $@
Summary of changes:
 extensions/address_standardizer/Makefile.in   | 1 +
 extensions/postgis_tiger_geocoder/Makefile.in | 1 +
 2 files changed, 2 insertions(+)
hooks/post-receive
