[postgis-tickets] [PostGIS] #5523: ERROR: cannot change name of input parameter "gj_version"
PostGIS trac at osgeo.org
Fri Sep 1 04:10:35 PDT 2023
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.1
Component:  build/upgrade/install  |    Version:  3.4.x
 Keywords:                         |
 Spotted with:
 > regress/run_test.pl -v --extension --upgrade-path=2.5.7--3.5.0dev
 regress/core/legacy
 Gets here:
 --- regress/core/legacy_expected        2023-09-01 07:52:46.900420710
 +0000
 +++ /tmp/pgis_reg/test_1_out    2023-09-01 10:45:13.215427704 +0000
 @@ -1,3 +1,4 @@
 +ERROR:  cannot change name of input parameter "gj_version"
  Starting up MapServer/Geoserver tests...
  Setting up the data table...
  public.wmstest.pt SRID:4326 TYPE:POLYGON DIMS:2
 @@ -17,3 +18,6 @@
  Removing the data table...
  Done.
  1869|POINT(1 2)
 +ERROR:  cannot drop function
 st_asgeojson(integer,geometry,integer,integer) because extension postgis
 requires it
 +ERROR:  current transaction is aborted, commands ignored until end of
 transaction block
 transaction block
 postgis/legacy.sql:2160: ERROR:  cannot change name of input parameter
 "gj_version"
 The offending signature is NOT marked as dropped in 3.0 in the
 postgis_after_upgrade.sql, closest is this (note the underscore)
 > SELECT _postgis_drop_function_by_signature('_ST_AsGeoJson(int4,
 geometry, int4, int4)'); -- dropped in PostGIS-3.0 (r17300)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5523>
