[postgis-tickets] [PostGIS] #5508: ERROR: cannot drop function st_makeemptyraster(integer, integer, double precision, double precision, double precision, double precision, double precision, double precision, integer) because other objects depend on it
PostGIS trac at osgeo.org
Fri Sep 1 06:21:59 PDT 2023
#5508: ERROR:  cannot drop function st_makeemptyraster(integer,integer,double
precision,double precision,double precision,double precision,double
precision,double precision,integer) because other objects depend on it
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:  raster
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"58780c6f2a4a0f3cdf40e9fa47e77763ce46b893/git"
 58780c6f/git]:
 {{{#!CommitTicketReference repository="git"
 revision="58780c6f2a4a0f3cdf40e9fa47e77763ce46b893"
 Deprecate older raster functions instead of dropping them
 Fix raster unpackaging script creator to handle script based drops
 in master (3.5.0dev) branch:
 References #5516 #5517 #5502 #5503 #5504 #5505 #5506 #5507 #5508
            #5509 #5510 #5511 #5512 #5513 #5514 #5515 #5516
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5508#comment:1>
