[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-138-gc16cd8814
Fri Sep 1 07:42:10 PDT 2023
the project "PostGIS".
       via  c16cd881437f0ced20a91ef8b43e49260e93edf9 (commit)
      from  6f9e4cd82b884466510140421a2868fa6cf21c85 (commit)
revisions in full, below.
commit c16cd881437f0ced20a91ef8b43e49260e93edf9
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 1 16:41:35 2023 +0200
    Avoid calling _postgis_drop_function_by_signature during creation
    Fixes installcheck,
    see https://gitlab.com/postgis/postgis/-/jobs/4999313128
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 0423236f4..e962965e7 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6660,6 +6660,7 @@ CREATE OR REPLACE FUNCTION ST_SimplifyPolygonHull(geom geometry, vertex_fraction
 -- Availability: 2.0.0
 -- Changed: 2.5.0
 -- Enhanced: 3.3.0 implements it in C, if GEOS >= 3.10
+-- Replaces _st_concavehull(geometry) deprecated in 3.3.0-with-geos-3.11
 CREATE OR REPLACE FUNCTION ST_ConcaveHull(param_geom geometry, param_pctconvex float, param_allow_holes boolean DEFAULT false)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_ConcaveHull'
@@ -6667,12 +6668,6 @@ CREATE OR REPLACE FUNCTION ST_ConcaveHull(param_geom geometry, param_pctconvex f
 	PARALLEL SAFE
 	_COST_HIGH;
--- No longer needed with C language implementation
-SELECT _postgis_drop_function_by_signature(
-	'_st_concavehull(geometry)',
-	'3.3.0--geos3.11'
 #else
 -- ST_ConcaveHull and Helper functions starts here --
Summary of changes:
 postgis/postgis.sql.in | 7 +------
 1 file changed, 1 insertion(+), 6 deletions(-)
hooks/post-receive
