[postgis-tickets] [PostGIS] #5528: IsValid XX000: GEOS isvalid() threw an error!
PostGIS trac at osgeo.org
Mon Sep 4 03:18:24 PDT 2023
 Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
     Type:  defect             |     Status:  new
 Priority:  medium             |  Milestone:  PostGIS 3.4.1
Component:  postgis            |    Version:  3.4.x
 Keywords:                     |
 When running on later geos versions I get an exception and the call
 returns
 Here are there result from 3 different systems, where the one with latest
 geos fails first.
 The file /tmp/testIsValid.sql  that we test with will be uploaded.
 psql:/tmp/testIsValid.sql:5: ERROR:  XX000: GEOS isvalid() threw an error!
 postgis_full_version
  POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="120" GEOS="3.10.1-CAPI-1.16.0"
 SFCGAL="1.3.7" PROJ="8.2.0 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/share/proj/proj.db" LIBXML="2.9.10" LIBJSON="0.13.1"
 LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY
 (1 row)
  postgis_geos_version
  3.10.1-CAPI-1.16.0
 (1 row)
  st_isvalid
  t
 (1 row)
  POSTGIS="3.4.0dev 3.3.0rc2-958-g4c776d418" [EXTENSION] PGSQL="120"
 GEOS="3.9.1-CAPI-1.14.2" SFCGAL="1.3.7" PROJ="7.2.1" LIBXML="2.9.10"
 LIBJSON="0.13.1" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY
 (1 row)
  3.9.1-CAPI-1.14.2
 (1 row)
  st_isvalid
  t
 (1 row)
  POSTGIS="3.1.1 aaf4c79" [EXTENSION] PGSQL="120" GEOS="3.9.0-CAPI-1.16.2"
 SFCGAL="1.3.7" PROJ="7.2.1" GDAL="GDAL 3.2.1, released 2020/12/29"
 LIBXML="2.9.10" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
 (Internal)" TOPOLOGY RASTER
 (1 row)
  3.9.0-CAPI-1.16.2
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5528>
