[postgis-tickets] [PostGIS] #5528: IsValid XX000: GEOS isvalid() threw an error!
PostGIS trac at osgeo.org
Mon Sep 4 03:59:46 PDT 2023
  Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.1
 Component:  postgis            |    Version:  3.4.x
Resolution:                     |   Keywords:
Changes (by strk):
 * cc: Lars Aksel Opsahl (removed)
Comment:
 When I try the query against POSTGIS="3.4.0 3.4.0" on PostgreSQL 12.16 I
 get:
 > ERROR:  Pointarray length (-1132134400) is too large
 But it works against POSTGIS="3.5.0dev 3.4.0rc1-191-g57c5dad0f" on
 PostgreSQL 13.5:
 $ psql -tAf testIsValid.sql
 t
 POSTGIS="3.5.0dev 3.4.0rc1-191-g57c5dad0f" [EXTENSION] PGSQL="130"
 GEOS="3.12.0dev-CAPI-1.18.0" PROJ="9.1.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/opt/proj-9.1/share/proj/proj.db" LIBXML="2.9.13"
 LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY
 GEOS-3.10.1 is pretty old as the latest release of the 3.10 series is
 3.10.5, releases on March 2023
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5528#comment:4>
