[postgis-tickets] [PostGIS] #5528: IsValid XX000: GEOS isvalid() threw an error!
PostGIS trac at osgeo.org
Mon Sep 4 07:52:48 PDT 2023
  Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.1
 Component:  postgis            |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by strk):
 Simplifying the exterior ring, even with a tolerance of 0, removes the
 problem, so maybe this is related to this change in 3.10.3:
    - Fix IsValidOp to handle repeated node points (JTS-845, Martin Davis)
 That's https://github.com/locationtech/jts/issues/845 which seem to result
 in an IllegalArgumentException thrown when input contains repeated points.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5528#comment:7>
