[postgis-tickets] [PostGIS] #5506: ERROR: cannot drop function st_setbandnodatavalue(raster, integer, double precision, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Tue Sep 5 02:28:06 PDT 2023
#5506: ERROR:  cannot drop function st_setbandnodatavalue(raster,integer,double
precision,boolean) because other objects depend on it
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:  fixed                  |   Keywords:  raster
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"e428b70577bd51d3924346d9f0124a6d37ef4ff8/git" e428b70/git]:
 {{{#!CommitTicketReference repository="git"
 revision="e428b70577bd51d3924346d9f0124a6d37ef4ff8"
 Backport all fixes to deal with upgrades in presence of views
   - Use a common before/after upgrade script for core and raster:
     rename deprecated funx before, drop them (if possible) after
   - Properly encode all deprecation from 2.5 onward
   - Update run_test.pl to support double upgrades and give hints
     upon leaving functions in the database
 In 3.4 branch (3.4.1dev):
 closes #5493 #5502 #5503 #5504 #5505 #5506 #5507 #5508 #5509 #5510
        #5511 #5512 #5513 #5514 #5515 #5516 #5516 #5517 #5523 #5524
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5506#comment:2>
