[postgis-tickets] [PostGIS] #5511: ERROR: cannot drop function st_bandpath(raster, integer) because other objects depend on it
PostGIS trac at osgeo.org
Tue Sep 5 02:32:02 PDT 2023
#5511: ERROR:  cannot drop function st_bandpath(raster,integer) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:  fixed                  |   Keywords:  raster
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Old description:
> Spotted via make -C raster/test/regress/ check-locked-upgrade
New description:
Comment:
 Referenced by [58780c6f2a4a0f3cdf40e9fa47e77763ce46b893/git] in master
 branch (3.5.0dev)
 Closed by [e428b70577bd51d3924346d9f0124a6d37ef4ff8/git] in 3.4 branch
 (3.4.1dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5511#comment:1>
