[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-262-g42f5df7f5
Tue Sep 5 06:38:18 PDT 2023
the project "PostGIS".
       via  42f5df7f5e7286001ab61a06df534db7d5230f50 (commit)
       via  b0000a7280999788c26539d80c6dc114f376cfea (commit)
      from  c0acc976e229b0f24b4d5923e633ce5eeb1d81cc (commit)
revisions in full, below.
commit 42f5df7f5e7286001ab61a06df534db7d5230f50
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Sep 5 12:34:36 2023 +0200
    [woodie] Run building of images and checking of XML in parallel
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 299d688e4..ca48078a2 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -43,12 +43,14 @@ steps:
       path: *when_path_full
   check-xml:
     image: *test_image
+    group: check-xml-and-build-images
     commands:
       - make -C build-docs/doc check
     when:
       path: *when_path
   build-images:
     image: *test_image
     commands:
       - make -C build-docs/doc images
     when:
commit b0000a7280999788c26539d80c6dc114f376cfea
Date:   Tue Sep 5 12:09:52 2023 +0200
    Use CKJ fonts for korean PDF
    Closes #2967 in master branch (3.5.0dev)
diff --git a/doc/po/ko_KR/Makefile.in b/doc/po/ko_KR/Makefile.in
index d1cee468a..69f11ab08 100644
--- a/doc/po/ko_KR/Makefile.in
+++ b/doc/po/ko_KR/Makefile.in
@@ -1,3 +1,6 @@
 include @srcdir@/../Makefile.local
+DBLATEX_EXTRA_OPTIONS = -b xetex
 DOCSUFFIX=-ko_KR
 srcdir=@srcdir@
+postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf: texstyle.sty
diff --git a/doc/po/ko_KR/texstyle.sty b/doc/po/ko_KR/texstyle.sty
new file mode 100644
index 000000000..2edd0bee6
--- /dev/null
+++ b/doc/po/ko_KR/texstyle.sty
@@ -0,0 +1,14 @@
+%% This style is derived from the manual
+%% http://dblatex.sourceforge.net/doc/manual/sec-custom-latex.html
+\NeedsTeXFormat{LaTeX2e} % is this needed ?
+\ProvidesPackage{texstyle}[2017/04/25 PostGIS DocBook Korean Style ]
+%% Just use the original package and pass the options
+\RequirePackageWithOptions{texstyle-common}
+\usepackage{xeCJK}
+\setCJKmainfont{IPAMincho}
+\setCJKsansfont{IPAGothic}
+\setCJKmonofont{IPAGothic}
Summary of changes:
 .woodpecker/docs.yml                   | 2 ++
 doc/po/ko_KR/Makefile.in               | 3 +++
 doc/po/{zh_Hans => ko_KR}/texstyle.sty | 2 +-
 3 files changed, 6 insertions(+), 1 deletion(-)
 copy doc/po/{zh_Hans => ko_KR}/texstyle.sty (83%)
hooks/post-receive
