[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-299-g2f4a4c9d8
Tue Sep 5 23:10:38 PDT 2023
the project "PostGIS".
       via  2f4a4c9d8b7faedb3fe4715b5add8b80770565de (commit)
      from  c3d59b3059cd9d6a8fe74eb462f2376f361e1acd (commit)
revisions in full, below.
commit 2f4a4c9d8b7faedb3fe4715b5add8b80770565de
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Wed Sep 6 06:06:47 2023 +0000
    Translated using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (158 of 158 strings)
    Translation: postgis/reference_operator.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_operatorxml/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_operator.xml.po b/doc/po/zh_Hans/reference_operator.xml.po
index 13851f521..198763891 100644
--- a/doc/po/zh_Hans/reference_operator.xml.po
+++ b/doc/po/zh_Hans/reference_operator.xml.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: build-pg 13\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-07-18 20:22+0000\n"
-"PO-Revision-Date: 2023-09-06 05:32+0000\n"
+"PO-Revision-Date: 2023-09-06 06:10+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/reference_operatorxml/zh_Hans/>\n"
@@ -1688,24 +1688,27 @@ msgid ""
 "that the spatial index is only used when the operator is in the ORDER BY "
 "clause."
 msgstr ""
+"该操作数将利用几何上可能可用的 n-D GiST 索引。 "
+"它与其他使用空间索引的运算符不同,只有当该运算符位于 ORDER BY "
+"子句中时才会使用空间索引。"
 #. Tag: para
 #: reference_operator.xml:1844 reference_operator.xml:1901
 #, no-c-format
 msgid "Availability: 2.2.0 -- KNN only available for PostgreSQL 9.1+"
-msgstr ""
+msgstr "可用性:2.2.0——KNN 仅适用于 PostgreSQL 9.1+"
 #. Tag: para
 #: reference_operator.xml:1851
 #, no-c-format
 msgid ", <xref linkend=\"geometry_distance_knn\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"geometry_distance_knn\"/>"
 #. Tag: refpurpose
 #: reference_operator.xml:1862
 #, no-c-format
 msgid "Returns the n-D distance between A and B bounding boxes."
-msgstr ""
+msgstr "返回 A 和 B 边界框之间的 n 维距离。"
 #. Tag: funcprototype
 #: reference_operator.xml:1869
@@ -1715,6 +1718,9 @@ msgid ""
 "<paramdef> <type>geometry </type> <parameter>A</parameter> </paramdef> "
 "<paramdef> <type>geometry </type> <parameter>B</parameter> </paramdef>"
 msgstr ""
+"<funcdef>double precision <function><<#>></function></funcdef> "
+"<paramdef> <type>geometry </type> <parameter>A</parameter> </paramdef> "
+"<paramdef> <type>geometry </type> <parameter>B</parameter> </paramdef>"
 #. Tag: para
 #: reference_operator.xml:1890
@@ -1725,6 +1731,10 @@ msgid ""
 "index (PostgreSQL 9.1+ required). Useful for doing nearest neighbor "
 "<emphasis role=\"strong\">approximate</emphasis> distance ordering."
 msgstr ""
+"<varname><<#>></varname> "
+"运算符返回两个浮点边界框之间的距离,可能从空间索引中读取它们(需要 "
+"PostgreSQL 9.1)。 对于进行最近邻<emphasis role=\"strong\""
+">近似</emphasis>距离排序很有用。"
 #. Tag: para
 #: reference_operator.xml:1895
@@ -1734,9 +1744,12 @@ msgid ""
 "(ST_GeomFromText('POINT(1 2)') <<#>> geom) instead of g1.geom "
 msgstr ""
+"仅当其中一个几何图形是常量时,索引才会生效,例如 ORDER BY "
+"(ST_GeomFromText('POINT(1 2)') <<#>> geom) 而不是 g1.geom "
 #. Tag: para
 #: reference_operator.xml:1907
 #, no-c-format
 msgid ", <xref linkend=\"geometry_distance_box\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"geometry_distance_box\"/>"
Summary of changes:
 doc/po/zh_Hans/reference_operator.xml.po | 23 ++++++++++++++++++-----
 1 file changed, 18 insertions(+), 5 deletions(-)
hooks/post-receive
