[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-340-gd68837299
Thu Sep 7 05:33:30 PDT 2023
the project "PostGIS".
       via  d68837299b57c64e5950eae188bb338ceec2f855 (commit)
       via  16e3ac8b72d478fcfe94846b5cd1a3a0c768fb86 (commit)
       via  27a27f3f372ff3939019e20532070211b34959a7 (commit)
       via  5b747051933a28697cc0678918a47da56107e01c (commit)
       via  1ef08c808c97a82e7fdaded2c7d5bf1209b84541 (commit)
       via  da3d93f995612d49de61c50c8e3d1639bdf8ca56 (commit)
       via  045a6ef194c770d1cd0cfccc3db120f9802ba927 (commit)
       via  56350866da90b36b277618f0146016e48da0f123 (commit)
      from  0a661a8464cf1729161f398f0bcb88ab5914a857 (commit)
revisions in full, below.
commit d68837299b57c64e5950eae188bb338ceec2f855
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Sep 7 10:29:53 2023 +0000
    Translated using Weblate (Italian)
    Currently translated at 62.4% (98 of 157 strings)
    Translation: postgis/using_raster_dataman.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/using_raster_datamanxml/it/
diff --git a/doc/po/it_IT/using_raster_dataman.xml.po b/doc/po/it_IT/using_raster_dataman.xml.po
index 30c0cadd9..2d9751073 100644
--- a/doc/po/it_IT/using_raster_dataman.xml.po
+++ b/doc/po/it_IT/using_raster_dataman.xml.po
@@ -9,7 +9,7 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-07-15 12:17+0000\n"
-"PO-Revision-Date: 2023-09-07 10:14+0000\n"
+"PO-Revision-Date: 2023-09-07 12:33+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
 "using_raster_datamanxml/it/>\n"
@@ -944,9 +944,9 @@ msgid ""
 msgstr ""
 "<varname>scale_y</varname> Il rapporto di scala tra le coordinate "
 "geometriche e il pixel, disponibile solo se tutte le tile nella colonna "
-"raster hanno lo stesso valore di  <varname>scale_y</varname> e questo limite "
-"è applicato. Si rimanda è <xref linkend=\"RT_ST_ScaleY\"/> per ulteriori "
-"dettagli."
+"raster hanno lo stesso valore di <varname>scale_y</varname> e il vincolo su "
+"<varname>scale_y</varname> è applicato. Si rimanda a <xref linkend="
+"\"RT_ST_ScaleY\"/> per ulteriori dettagli."
 #. Tag: para
 #: using_raster_dataman.xml:438
commit 16e3ac8b72d478fcfe94846b5cd1a3a0c768fb86
Date:   Thu Sep 7 10:26:08 2023 +0000
    Currently translated at 16.4% (13 of 79 strings)
    Translation: postgis/reference_lrs.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_lrsxml/it/
diff --git a/doc/po/it_IT/reference_lrs.xml.po b/doc/po/it_IT/reference_lrs.xml.po
index 1cb1be32f..e8c4f6b84 100644
--- a/doc/po/it_IT/reference_lrs.xml.po
+++ b/doc/po/it_IT/reference_lrs.xml.po
@@ -8,7 +8,7 @@ msgstr ""
 "POT-Creation-Date: 2023-07-29 10:57+0000\n"
-"PO-Revision-Date: 2022-01-19 10:14+0000\n"
 "reference_lrsxml/it/>\n"
@@ -17,7 +17,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=2; plural=n != 1;\n"
-"X-Generator: Weblate 4.10.1\n"
+"X-Generator: Weblate 4.16.4\n"
 #. Tag: title
 #: reference_lrs.xml:3
@@ -544,10 +544,9 @@ msgstr ""
 #. Tag: para
 #: reference_lrs.xml:496
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ", <xref linkend=\"ST_LocateBetweenElevations\"/>"
-msgstr ""
-", <xref linkend=\"ST_LocateAlong\"/>, <xref linkend=\"ST_LocateBetween\"/>"
+msgstr ", <xref linkend=\"ST_LocateBetweenElevations\"/>"
 #. Tag: refpurpose
 #: reference_lrs.xml:504
@@ -582,10 +581,9 @@ msgstr "Disponibilità: 1.4.0"
 #. Tag: para
 #: reference_lrs.xml:543
+#, no-c-format
 msgid ", <xref linkend=\"ST_LocateBetween\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_LocateBetween\"/>"
 #. Tag: refpurpose
 #: reference_lrs.xml:552
commit 27a27f3f372ff3939019e20532070211b34959a7
Date:   Thu Sep 7 10:21:35 2023 +0000
    Currently translated at 43.9% (18 of 41 strings)
    Translation: postgis/reference_type.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_typexml/it/
diff --git a/doc/po/it_IT/reference_type.xml.po b/doc/po/it_IT/reference_type.xml.po
index 60a110fcb..f852ffc1c 100644
--- a/doc/po/it_IT/reference_type.xml.po
+++ b/doc/po/it_IT/reference_type.xml.po
@@ -2,13 +2,14 @@
 # Translators:
 # Tommaso Di Bucchianico, 2013
+# Sandro Santilli <strk at kbt.io>, 2023.
 msgid ""
 msgstr ""
 "POT-Creation-Date: 2023-07-18 20:22+0000\n"
-"PO-Revision-Date: 2022-05-07 19:23+0000\n"
-"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
+"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "reference_typexml/it/>\n"
 "Language: it_IT\n"
@@ -16,7 +17,7 @@ msgstr ""
-"X-Generator: Weblate 4.11.2\n"
 #. Tag: para
 #: reference_type.xml:5
@@ -87,16 +88,17 @@ msgstr "Descrizione"
 #. Tag: para
 #: reference_type.xml:37
+#, no-c-format
 msgid ""
 "<varname>box2d</varname> is a spatial data type used to represent the two-"
 "dimensional bounding box enclosing a geometry or collection of geometries. "
 "For example, the <xref linkend=\"ST_Extent\"/> aggregate function returns a "
 "<varname>box2d</varname> object."
 msgstr ""
-"box3d è un tipo spaziale di Postgis usato per rappresentare il "
-"parallelepipedo contente una geometria o un insieme di geometrie. La "
-"funzione ST_3DExtent ritorna un oggetto box3d."
+"<varname>box2d</varname> è un tipo di dato spaziale usato per rappresentare "
+"il rettangolo contente una geometria o un insieme di geometrie. La funzione "
+"aggregata <xref linkend=\"ST_Extent\"/>, ad esempio, restituisce un oggetto "
+"<varname>box2d</varname>."
 #. Tag: para
 #: reference_type.xml:41
@@ -181,16 +183,17 @@ msgstr ""
 #. Tag: para
 #: reference_type.xml:83
+#, no-c-format
 msgid ""
 "<varname>box3d</varname> is a PostGIS spatial data type used to represent "
 "the three-dimensional bounding box enclosing a geometry or collection of "
 "geometries. For example, the <xref linkend=\"ST_3DExtent\"/> aggregate "
 "function returns a <varname>box3d</varname> object."
 msgstr ""
+"<varname>box3d</varname> è un tipo di dato spaziale di PostGIS usato per "
+"rappresentare il parallelepipedo contente una geometria o un insieme di "
+"geometrie. La funzione aggregata <xref linkend=\"ST_3DExtent\"/>, ad "
+"esempio, ritorna un oggetto <varname>box3d</varname>."
 #. Tag: para
 #: reference_type.xml:88
@@ -231,13 +234,14 @@ msgstr ""
 #. Tag: para
 #: reference_type.xml:138
+#, no-c-format
 msgid ""
 "<varname>geometry</varname> is a fundamental PostGIS spatial data type used "
 "to represent a feature in planar (Euclidean) coordinate systems."
 msgstr ""
-"Il tipo di dato \"geometry\" è un fondamentale tipo spaziale di Postgis "
-"usato per rappresentare una entità in un sistema di coordinate euclideo. "
+"Il tipo di dato <varname>geometry</varname> è un fondamentale tipo spaziale "
+"di PostGIS usato per rappresentare una entità in un sistema di coordinate "
+"euclideo."
 #. Tag: para
 #: reference_type.xml:139
@@ -322,14 +326,15 @@ msgstr ""
 #. Tag: para
 #: reference_type.xml:227
+#, no-c-format
 msgid ""
 "<varname>geography</varname> is a spatial data type used to represent a "
 "feature in geodetic coordinate systems. Geodetic coordinate systems model "
 "the earth using an ellipsoid."
 msgstr ""
-"geography è un tipo spaziale usato per rappresentare un'entità in un sistema "
-"di coordinate sferico valido per l'intero pianeta."
+"<varname>geography</varname> è un tipo spaziale usato per rappresentare "
+"un'entità in un sistema di coordinate geodetico. I sistemi di coordinate "
+"geodetici utilizzano un modello ellipsoidale per il pianeta terra."
 #. Tag: para
 #: reference_type.xml:230
commit 5b747051933a28697cc0678918a47da56107e01c
Date:   Thu Sep 7 10:28:11 2023 +0000
    Currently translated at 51.3% (93 of 181 strings)
    Translation: postgis/installation.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/installationxml/it/
diff --git a/doc/po/it_IT/installation.xml.po b/doc/po/it_IT/installation.xml.po
index b346f4f5f..252919516 100644
--- a/doc/po/it_IT/installation.xml.po
+++ b/doc/po/it_IT/installation.xml.po
 "POT-Creation-Date: 2023-07-29 10:16+0000\n"
-"PO-Revision-Date: 2022-01-12 23:53+0000\n"
 "installationxml/it/>\n"
 #. Tag: title
 #: installation.xml:3
@@ -47,14 +47,15 @@ msgstr ""
 #. Tag: para
 #: installation.xml:13
+#, no-c-format
 msgid ""
 "Once PostGIS is installed, it needs to be enabled (<xref "
 "linkend=\"create_spatial_db\"/>) or upgraded (<xref linkend=\"upgrading\"/>) "
 "in each individual database you want to use it in."
 msgstr ""
-"Una volta installato PostGIS, bisogna abilitarlo individualmente nei "
-"database in cui si vuole usare."
+"Una volta installato PostGIS, bisogna abilitarlo (<xref linkend="
+"\"create_spatial_db\"/>) o aggiornarlo (<xref linkend=\"upgrading\"/>) "
+"individualmente nei database in cui si vuole usare."
 #. Tag: title
 #: installation.xml:23
@@ -1103,15 +1104,15 @@ msgstr ""
 #. Tag: para
 #: installation.xml:683
+#, no-c-format
 msgid ""
 "If you configured PostGIS using non-standard PostgreSQL, GEOS, or Proj "
 "locations, you may need to add their library locations to the "
 "<varname>LD_LIBRARY_PATH</varname> environment variable."
 msgstr ""
 "Se avete configurato PostGIS utilizzando percorsi non standard per "
-"PostgreSQL, GEOS o Proj4, potreste dover aggiungere il percorso di queste "
-"librerie nella variabile di ambiente LD_LIBRARY_PATH"
+"PostgreSQL, GEOS o Proj, potreste dover aggiungere il percorso di queste "
+"librerie nella variabile di ambiente <varname>LD_LIBRARY_PATH</varname>."
 #. Tag: para
 #: installation.xml:691
commit 1ef08c808c97a82e7fdaded2c7d5bf1209b84541
Date:   Thu Sep 7 10:16:44 2023 +0000
    Currently translated at 20.0% (26 of 130 strings)
    Translation: postgis/reference_operator.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_operatorxml/it/
diff --git a/doc/po/it_IT/reference_operator.xml.po b/doc/po/it_IT/reference_operator.xml.po
index e32c8bd94..549eaea78 100644
--- a/doc/po/it_IT/reference_operator.xml.po
+++ b/doc/po/it_IT/reference_operator.xml.po
@@ -7,7 +7,7 @@ msgstr ""
-"PO-Revision-Date: 2022-01-19 00:27+0000\n"
 "reference_operatorxml/it/>\n"
@@ -16,7 +16,7 @@ msgstr ""
 #. Tag: title
 #: reference_operator.xml:3
@@ -165,7 +165,7 @@ msgstr "Si veda anche"
 #. Tag: para
 #: reference_operator.xml:77
+#, no-c-format
 msgid ""
 ", <xref linkend=\"ST_Extent\"/>, <xref linkend=\"ST_Geometry_Overabove\"/>, "
 "<xref linkend=\"ST_Geometry_Overright\"/>, <xref "
@@ -173,10 +173,10 @@ msgid ""
 ">, <xref linkend=\"ST_Geometry_Contain\"/>, <xref "
 "linkend=\"ST_Geometry_Contained\"/>"
 msgstr ""
-", <xref linkend=\"ST_Geometry_Overright\"/>, <xref "
-"linkend=\"ST_Geometry_Overbelow\"/>, <xref linkend=\"ST_Geometry_Overleft\"/"
-">, <xref linkend=\"ST_Geometry_Contain\"/>, <xref "
-"linkend=\"ST_Geometry_Contained\"/>"
+", <xref linkend=\"ST_Extent\"/>, <xref linkend=\"ST_Geometry_Overabove\"/>, "
+"<xref linkend=\"ST_Geometry_Overright\"/>, <xref linkend="
+"\"ST_Geometry_Overbelow\"/>, <xref linkend=\"ST_Geometry_Overleft\"/>, <xref "
+"linkend=\"ST_Geometry_Contain\"/>, <xref linkend=\"ST_Geometry_Contained\"/>"
 #. Tag: refpurpose
 #: reference_operator.xml:94
@@ -318,7 +318,7 @@ msgstr ""
 #. Tag: para
 #: reference_operator.xml:261
+#, no-c-format
 msgid ""
 ", <xref linkend=\"overlaps_box2df_geometry\"/>, <xref "
 "linkend=\"contains_geometry_box2df\"/>, <xref "
@@ -328,10 +328,12 @@ msgid ""
 "linkend=\"is_contained_box2df_geometry\"/>, <xref "
 "linkend=\"is_contained_box2df_box2df\"/>"
 msgstr ""
+", <xref linkend=\"overlaps_box2df_geometry\"/>, <xref linkend="
+"\"contains_geometry_box2df\"/>, <xref linkend=\"contains_box2df_geometry\"/"
+">, <xref linkend=\"contains_box2df_box2df\"/>, <xref linkend="
+"\"is_contained_geometry_box2df\"/>, <xref linkend="
+"\"is_contained_box2df_geometry\"/>, <xref linkend="
+"\"is_contained_box2df_box2df\"/>"
 #. Tag: refpurpose
 #: reference_operator.xml:277
@@ -847,7 +849,7 @@ msgstr ""
 #. Tag: para
 #: reference_operator.xml:1035
+#, no-c-format
 msgid ""
 "linkend=\"overlaps_box2df_box2df\"/>, <xref "
@@ -857,10 +859,11 @@ msgid ""
 msgstr ""
+"\"overlaps_box2df_box2df\"/>, <xref linkend=\"contains_geometry_box2df\"/>, "
+"<xref linkend=\"contains_box2df_geometry\"/>, <xref linkend="
+"\"contains_box2df_box2df\"/>, <xref linkend=\"is_contained_box2df_geometry\"/"
+">, <xref linkend=\"is_contained_box2df_box2df\"/>"
 #. Tag: refpurpose
 #: reference_operator.xml:1051
@@ -894,7 +897,7 @@ msgstr ""
 #. Tag: para
 #: reference_operator.xml:1096
+#, no-c-format
 msgid ""
@@ -904,10 +907,11 @@ msgid ""
 "linkend=\"is_contained_geometry_box2df\"/>, <xref "
 msgstr ""
+"\"contains_box2df_box2df\"/>, <xref linkend=\"is_contained_geometry_box2df\"/"
 #. Tag: refpurpose
 #: reference_operator.xml:1112
@@ -941,7 +945,7 @@ msgstr ""
 #. Tag: para
 #: reference_operator.xml:1157
+#, no-c-format
 msgid ""
@@ -951,10 +955,11 @@ msgid ""
 "linkend=\"is_contained_box2df_geometry\"/>"
 msgstr ""
+">, <xref linkend=\"is_contained_box2df_geometry\"/>"
 #. Tag: refpurpose
 #: reference_operator.xml:1173
@@ -1178,7 +1183,7 @@ msgstr ""
 #. Tag: para
 #: reference_operator.xml:1504
+#, no-c-format
 msgid ""
@@ -1188,10 +1193,12 @@ msgid ""
 msgstr ""
 #. Tag: refpurpose
 #: reference_operator.xml:1520
commit da3d93f995612d49de61c50c8e3d1639bdf8ca56
Date:   Thu Sep 7 10:25:29 2023 +0000
    Currently translated at 86.3% (38 of 44 strings)
    Translation: postgis/reference_management.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_managementxml/it/
diff --git a/doc/po/it_IT/reference_management.xml.po b/doc/po/it_IT/reference_management.xml.po
index 715265d66..8aa69f95c 100644
--- a/doc/po/it_IT/reference_management.xml.po
+++ b/doc/po/it_IT/reference_management.xml.po
 "reference_managementxml/it/>\n"
@@ -117,8 +117,9 @@ msgstr ""
 "caso la vista sarà registrata correttamente in geometry_columns perché "
 "eredita il typmod dalla colonna geometry originale. Le viste che usano "
 "funzioni che ritornano geometrie verranno registrate correttamente se il "
-"tipo delll'output della funzione verrà definito esplicitamente con la "
-"funzione CAST come typmod geometry."
+"tipo dell'output della funzione verrà definito esplicitamente con la "
+"funzione CAST come typmod geometry. Si veda <xref linkend="
+"\"Manual_Register_Spatial_Column\"/>."
 #. Tag: para
 #: reference_management.xml:122 reference_management.xml:199
@@ -402,7 +403,8 @@ msgstr ""
 "Se alla funzione viene passato l'<varname>oid</varname> di una vista, questa "
 "cerca di determinare srid, dimensione e tipo della geometria di tutte le "
 "colonne geometry della vista, inserendo le appropriate righe nella tabella "
-"geometry_columns. I vincoli spaziali non vengono controllati né definiti."
+"<varname>geometry_columns</varname>. I vincoli spaziali non vengono "
+"controllati né definiti."
 #. Tag: para
 #: reference_management.xml:396
commit 045a6ef194c770d1cd0cfccc3db120f9802ba927
Date:   Thu Sep 7 10:31:15 2023 +0000
    Currently translated at 78.2% (18 of 23 strings)
    Translation: postgis/performance_tips.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/performance_tipsxml/it/
diff --git a/doc/po/it_IT/performance_tips.xml.po b/doc/po/it_IT/performance_tips.xml.po
index 1fb14f891..75194e93f 100644
--- a/doc/po/it_IT/performance_tips.xml.po
+++ b/doc/po/it_IT/performance_tips.xml.po
 "POT-Creation-Date: 2023-07-15 01:28+0000\n"
 "performance_tipsxml/it/>\n"
@@ -100,7 +100,7 @@ msgstr ""
 #. Tag: para
 #: performance_tips.xml:35
+#, no-c-format
 msgid ""
 "To see whether your suffer from this issue, use the \"EXPLAIN ANALYZE\" "
 "postgresql command. For more information and the technical details, you can "
@@ -112,8 +112,9 @@ msgstr ""
 "Per controllare se i propri dati sono interessati da questo bug, si può "
 "usare il comando PostgreSQL \"EXPLAIN ANALYZE\". Per maggiori informazioni e "
 "dettagli tecnici consultare il corrispondente thread sulla mailing list di "
-"PostgreSQL: http://archives.postgresql.org/pgsql-performance/2005-02/"
-"msg00030.php"
+"PostgreSQL: <ulink url=\"http://archives.postgresql.org/pgsql-performance/"
+"2005-02/msg00030.php\">http://archives.postgresql.org/pgsql-performance/"
+"2005-02/msg00030.php</ulink>"
 #. Tag: para
 #: performance_tips.xml:41
commit 56350866da90b36b277618f0146016e48da0f123
Date:   Thu Sep 7 10:26:55 2023 +0000
    Currently translated at 11.8% (19 of 161 strings)
    Translation: postgis/reference_constructor.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_constructorxml/it/
diff --git a/doc/po/it_IT/reference_constructor.xml.po b/doc/po/it_IT/reference_constructor.xml.po
index d0bd94e23..a4f7fe8d6 100644
--- a/doc/po/it_IT/reference_constructor.xml.po
+++ b/doc/po/it_IT/reference_constructor.xml.po
-"PO-Revision-Date: 2022-01-13 16:44+0000\n"
 "reference_constructorxml/it/>\n"
@@ -18,7 +18,7 @@ msgstr ""
 #. Tag: title
 #: reference_constructor.xml:3
@@ -451,14 +451,15 @@ msgstr ""
 #. Tag: para
 #: reference_constructor.xml:267
+#, no-c-format
 msgid ""
 ", <xref linkend=\"ST_AsEWKT\"/>, <xref linkend=\"ST_AsText\"/>, <xref "
 "linkend=\"ST_GeomFromText\"/>, <xref linkend=\"ST_MakePoint\"/>, <xref "
 "linkend=\"ST_Point\"/>"
 msgstr ""
-", <xref linkend=\"ST_AsText\"/>, <xref linkend=\"ST_GeomFromText\"/>, <xref "
-"linkend=\"ST_MakePoint\"/>"
+", <xref linkend=\"ST_AsEWKT\"/>, <xref linkend=\"ST_AsText\"/>, <xref "
+"linkend=\"ST_GeomFromText\"/>, <xref linkend=\"ST_MakePoint\"/>, <xref "
+"linkend=\"ST_Point\"/>"
 #. Tag: refpurpose
 #: reference_constructor.xml:282
@@ -858,15 +859,15 @@ msgstr ""
 #. Tag: para
 #: reference_constructor.xml:549
+#, no-c-format
 msgid ""
 ", <xref linkend=\"ST_MakePoint\"/>, <xref linkend=\"ST_SetSRID\"/>, <xref "
 "linkend=\"ST_Transform\"/>, <xref linkend=\"ST_PointZ\"/>, <xref "
 "linkend=\"ST_PointM\"/>, <xref linkend=\"ST_PointZM\"/>"
 msgstr ""
-", <xref linkend=\"ST_AsText\"/>, <xref linkend=\"ST_GeomFromEWKT\"/>, <xref "
-"linkend=\"ST_GeomFromText\"/>, <xref linkend=\"ST_LineMerge\"/>, <xref "
-"linkend=\"ST_MakePolygon\"/>"
+", <xref linkend=\"ST_MakePoint\"/>, <xref linkend=\"ST_SetSRID\"/>, <xref "
+"linkend=\"ST_Transform\"/>, <xref linkend=\"ST_PointZ\"/>, <xref linkend="
+"\"ST_PointM\"/>, <xref linkend=\"ST_PointZM\"/>"
 #. Tag: refpurpose
 #: reference_constructor.xml:557
Summary of changes:
 doc/po/it_IT/installation.xml.po          | 17 ++++----
 doc/po/it_IT/performance_tips.xml.po      |  9 ++--
 doc/po/it_IT/reference_constructor.xml.po | 19 +++++----
 doc/po/it_IT/reference_lrs.xml.po         | 14 +++---
 doc/po/it_IT/reference_management.xml.po  | 10 +++--
 doc/po/it_IT/reference_operator.xml.po    | 71 +++++++++++++++++--------------
 doc/po/it_IT/reference_type.xml.po        | 39 +++++++++--------
 doc/po/it_IT/using_raster_dataman.xml.po  |  8 ++--
 8 files changed, 101 insertions(+), 86 deletions(-)
hooks/post-receive
