[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-351-g253771e3a
Thu Sep 7 21:20:46 PDT 2023
the project "PostGIS".
       via  253771e3ab18d8fd695b676307bc5d4e060b9567 (commit)
       via  f9f6090666f59c3e18ca616744ff4453b36ab2a2 (commit)
       via  ce8a8df521988ddb0cc19c5ef9fa27738776ac13 (commit)
      from  71d841f45119ce598865d502a1ed5a642b025cc5 (commit)
revisions in full, below.
commit 253771e3ab18d8fd695b676307bc5d4e060b9567
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Fri Sep 8 02:59:10 2023 +0000
    Translated using Weblate (Chinese (Simplified))
    Currently translated at 62.7% (37 of 59 strings)
    Translation: postgis/reference_transformation.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_transformationxml/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_transformation.xml.po b/doc/po/zh_Hans/reference_transformation.xml.po
index d93444aab..ba2e87682 100644
--- a/doc/po/zh_Hans/reference_transformation.xml.po
+++ b/doc/po/zh_Hans/reference_transformation.xml.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: build-pg 13\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-07-18 20:22+0000\n"
-"PO-Revision-Date: 2023-09-06 05:32+0000\n"
+"PO-Revision-Date: 2023-09-08 04:20+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/reference_transformationxml/zh_Hans/>\n"
@@ -15,7 +15,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
-"X-Generator: Weblate 4.16.4\n"
+"X-Generator: Weblate 5.0\n"
 #. Tag: para
 #: reference_transformation.xml:5
@@ -25,18 +25,20 @@ msgid ""
 "url=\"https://en.wikipedia.org/wiki/Affine_transformation\">affine "
 "transformations</ulink>."
 msgstr ""
+"这些函数使用<ulink url=\"https://en.wikipedia.org/wiki/"
+"Affine_transformation\">仿射变换</ulink>来改变几何图形的位置和形状。"
 #. Tag: title
 #: reference_transformation.xml:10
 #, no-c-format
 msgid "Affine Transformations"
-msgstr ""
+msgstr "仿射变换"
 #. Tag: refpurpose
 #: reference_transformation.xml:16
 #, no-c-format
 msgid "Apply a 3D affine transformation to a geometry."
-msgstr ""
+msgstr "对几何体应用 3D 仿射变换。"
 #. Tag: title
 #: reference_transformation.xml:52 reference_transformation.xml:127
@@ -53,7 +55,7 @@ msgstr "描述"
 msgid ""
 "Applies a 3D affine transformation to the geometry to do things like "
 "translate, rotate, scale in one step."
-msgstr ""
+msgstr "对几何体应用 3D 仿射变换,一步完成平移、旋转、缩放等操作。"
 #. Tag: para
 #: reference_transformation.xml:55
@@ -70,6 +72,15 @@ msgid ""
 "z' = g*x + h*y + i*z + zoff</programlisting> All of the translate / scale "
 "functions below are expressed via such an affine transformation."
 msgstr ""
+"版本1:调用<programlisting>ST_Affine(geom, a, b, c, d, e, f, g, h, i, xoff, "
+"yoff, zoff)</programlisting>表示变换矩阵<programlisting>/ a b c xoff \\\n"
+"| d e f yoff |\n"
+"| g h i zoff |\n"
+"\\ 0 0 0     1 /</programlisting> 并且顶点变换如下: <programlisting>x' = a*"
+"x + b*y + c*z + xoff\n"
+"y' = d*x + e*y + f*z + yoff\n"
+"z' = g*x + h*y + i*z + zoff</programlisting> "
+"下面所有的平移/缩放函数都是通过这样的仿射变换来表达的。"
 #. Tag: para
 #: reference_transformation.xml:62
@@ -86,6 +97,15 @@ msgid ""
 "y' = d*x + e*y + yoff\n"
 "z' = z </programlisting> This method is a subcase of the 3D method above."
 msgstr ""
+"版本 2:对几何体应用 2d 仿射变换。 调用<programlisting>ST_Affine(geom, a, b, "
+"d, e, xoff, yoff)</programlisting>表示变换矩阵<programlisting>/ a b 0 xoff \\"
+" / a b xoff \\\n"
+"| d e 0 yoff | rsp.   | d e yoff |\n"
+"| 0 0 1 0 | 0 0 1 0 \\ 0 0 1 /\n"
+"\\ 0 0 0    1 /</programlisting> 并且顶点变换如下: <programlisting>x' = a*x "
+"+ b*y + xoff\n"
+"y' = d*x + e*y + yoff\n"
+"z' = z </programlisting> 此方法是上述 3D 方法的子情况。"
 #. Tag: para
 #: reference_transformation.xml:68 reference_transformation.xml:133
@@ -101,7 +121,7 @@ msgstr "增强功能:引入了2.0.0 对多面体曲面、三角形和三角网
 #: reference_transformation.xml:69
 #, no-c-format
 msgid "Availability: 1.1.2. Name changed from Affine to ST_Affine in 1.2.2"
-msgstr ""
+msgstr "可用性:1.1.2。 1.2.2 中名称从 Affine 更改为 ST_Affine"
 #. Tag: para
 #: reference_transformation.xml:70 reference_transformation.xml:283
@@ -172,12 +192,14 @@ msgid ""
 ", <xref linkend=\"ST_Scale\"/>, <xref linkend=\"ST_Translate\"/>, <xref "
 "linkend=\"ST_TransScale\"/>"
 msgstr ""
+", <xref linkend=\"ST_Scale\"/>, <xref linkend=\"ST_Translate\"/>, <xref "
+"linkend=\"ST_TransScale\"/>"
 #. Tag: refpurpose
 #: reference_transformation.xml:98
 #, no-c-format
 msgid "Rotates a geometry about an origin point."
-msgstr ""
+msgstr "绕原点旋转几何体。"
 #. Tag: para
 #: reference_transformation.xml:129
@@ -188,6 +210,8 @@ msgid ""
 "coordinates. If the origin is not specified, the geometry is rotated about "
 "POINT(0 0)."
 msgstr ""
+"围绕原点逆时针旋转几何体 rotRadians。 旋转原点可以指定为 POINT 几何图形,"
+"也可以指定为 x 和 y 坐标。 如果未指定原点,则几何图形将围绕 POINT(0 0) 旋转。"
 #. Tag: para
 #: reference_transformation.xml:134
@@ -195,13 +219,13 @@ msgstr ""
 msgid ""
 "Enhanced: 2.0.0 additional parameters for specifying the origin of rotation "
 "were added."
-msgstr ""
+msgstr "增强:2.0.0 添加了用于指定旋转原点的附加参数。"
 #. Tag: para
 #: reference_transformation.xml:135
 #, no-c-format
 msgid "Availability: 1.1.2. Name changed from Rotate to ST_Rotate in 1.2.2"
-msgstr ""
+msgstr "可用性:1.1.2。 1.2.2 中名称从 Rotate 更改为 ST_Rotate"
 #. Tag: para
 #: reference_transformation.xml:154
@@ -210,12 +234,14 @@ msgid ""
 ", <xref linkend=\"ST_RotateX\"/>, <xref linkend=\"ST_RotateY\"/>, <xref "
 "linkend=\"ST_RotateZ\"/>"
 msgstr ""
+", <xref linkend=\"ST_RotateX\"/>, <xref linkend=\"ST_RotateY\"/>, <xref "
+"linkend=\"ST_RotateZ\"/>"
 #. Tag: refpurpose
 #: reference_transformation.xml:162
 #, no-c-format
 msgid "Rotates a geometry about the X axis."
-msgstr ""
+msgstr "绕 X 轴旋转几何体。"
 #. Tag: funcprototype
 #: reference_transformation.xml:167
@@ -230,7 +256,7 @@ msgstr ""
 #: reference_transformation.xml:178
 #, no-c-format
 msgid "Rotates a geometry geomA - rotRadians about the X axis."
-msgstr ""
+msgstr "绕 X 轴旋转几何体 geomA - rotRadians。"
 #. Tag: para
 #: reference_transformation.xml:180
@@ -240,24 +266,27 @@ msgid ""
 "<code>ST_Affine(geomA, 1, 0, 0, 0, cos(rotRadians), -sin(rotRadians), 0, "
 "sin(rotRadians), cos(rotRadians), 0, 0, 0)</code>."
 msgstr ""
+"<code>ST_RotateX(geomA, rotRadians) </code>是 <code>ST_Affine(geomA, 1, 0, "
+"0, 0, cos(rotRadians), -sin(rotRadians), 0, sin(rotRadians), cos(rotRadians)"
+", 0, 0, 0)</code>的简写。"
 #. Tag: para
 #: reference_transformation.xml:184
 #, no-c-format
 msgid "Availability: 1.1.2. Name changed from RotateX to ST_RotateX in 1.2.2"
-msgstr ""
+msgstr "可用性:1.1.2。 1.2.2 中名称从 RotateX 更改为 ST_RotateX"
 #. Tag: para
 #: reference_transformation.xml:201
 #, no-c-format
 msgid ", <xref linkend=\"ST_RotateY\"/>, <xref linkend=\"ST_RotateZ\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_RotateY\"/>, <xref linkend=\"ST_RotateZ\"/>"
 #. Tag: refpurpose
 #: reference_transformation.xml:209
 #, no-c-format
 msgid "Rotates a geometry about the Y axis."
-msgstr ""
+msgstr "绕 Y 轴旋转几何体。"
 #: reference_transformation.xml:214
@@ -272,7 +301,7 @@ msgstr ""
 #: reference_transformation.xml:225
 #, no-c-format
 msgid "Rotates a geometry geomA - rotRadians about the y axis."
-msgstr ""
+msgstr "围绕 y 轴旋转几何体 geomA - rotRadians。"
 #. Tag: para
 #: reference_transformation.xml:227
@@ -282,24 +311,27 @@ msgid ""
 "<code>ST_Affine(geomA, cos(rotRadians), 0, sin(rotRadians), 0, 1, 0, -"
 "sin(rotRadians), 0, cos(rotRadians), 0, 0, 0)</code>."
 msgstr ""
+"<code>ST_RotateY(geomA, rotRadians)</code> 是 <code>ST_Affine(geomA, "
+"cos(rotRadians), 0, sin(rotRadians), 0, 1, 0, -sin(rotRadians), 0, "
+"cos(rotRadians), 0, 0, 0)</code>的简写。"
 #. Tag: para
 #: reference_transformation.xml:230
 #, no-c-format
 msgid "Availability: 1.1.2. Name changed from RotateY to ST_RotateY in 1.2.2"
-msgstr ""
+msgstr "可用性:1.1.2。 1.2.2 中名称从 RotateY 更改为 ST_RotateY"
 #. Tag: para
 #: reference_transformation.xml:250
 #, no-c-format
 msgid ", <xref linkend=\"ST_RotateX\"/>, <xref linkend=\"ST_RotateZ\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_RotateX\"/>, <xref linkend=\"ST_RotateZ\"/>"
 #. Tag: refpurpose
 #: reference_transformation.xml:258
 #, no-c-format
 msgid "Rotates a geometry about the Z axis."
-msgstr ""
+msgstr "绕 Z 轴旋转几何体。"
 #: reference_transformation.xml:263
@@ -314,13 +346,13 @@ msgstr ""
 #: reference_transformation.xml:274
 #, no-c-format
 msgid "Rotates a geometry geomA - rotRadians about the Z axis."
-msgstr ""
+msgstr "绕 Z 轴旋转几何体 geomA - rotRadians。"
 #. Tag: para
 #: reference_transformation.xml:276
 #, no-c-format
 msgid "This is a synonym for ST_Rotate"
-msgstr ""
+msgstr "这是 ST_Rotate 的同义词"
 #. Tag: para
 #: reference_transformation.xml:277
commit f9f6090666f59c3e18ca616744ff4453b36ab2a2
Date:   Fri Sep 8 02:40:55 2023 +0000
    Translated reference_coverage using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (30 of 30 strings)
    Translation: postgis/reference_coverage
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_coverage/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_coverage.xml.po b/doc/po/zh_Hans/reference_coverage.xml.po
index bceaf04be..e938871b5 100644
--- a/doc/po/zh_Hans/reference_coverage.xml.po
+++ b/doc/po/zh_Hans/reference_coverage.xml.po
@@ -7,7 +7,7 @@ msgstr ""
 "POT-Creation-Date: 2023-08-03 01:03+0000\n"
-"PO-Revision-Date: 2023-09-05 06:08+0000\n"
 "postgis/reference_coverage/zh_Hans/>\n"
@@ -16,7 +16,7 @@ msgstr ""
 #. Tag: para
 #: reference_coverage.xml:5
@@ -28,12 +28,16 @@ msgid ""
 "process, and can be operated on with window functions, which retain the "
 "coverage topology inside the window partition while altering the edges."
 msgstr ""
+"这些函数对形成“隐式覆盖”的多边形几何体集进行操作。 "
+"为了形成有效的覆盖范围,多边形不得重叠,并且相邻边的顶点必须完全匹配。 覆盖处"
+"理速度很快,并且可以使用窗口函数进行操作,窗口函数保留窗口分区内的覆盖拓扑,"
+"同时更改边缘。"
 #. Tag: title
 #: reference_coverage.xml:11
 #, no-c-format
 msgid "Coverages"
-msgstr ""
+msgstr "覆盖范围"
 #. Tag: refpurpose
 #: reference_coverage.xml:17
@@ -41,7 +45,7 @@ msgstr ""
 msgid ""
 "Window function that finds locations where polygons fail to form a valid "
 "coverage."
-msgstr ""
+msgstr "用于查找多边形无法形成有效覆盖范围的位置的窗口函数。"
 #: reference_coverage.xml:22
@@ -67,14 +71,15 @@ msgid ""
 "A window function which checks if the polygons in the window partition form "
 "a valid polygonal coverage. It returns linear indicators showing the "
 "location of invalid edges (if any) in each polygon."
-msgstr ""
+msgstr "一个窗口函数,用于检查窗口分区中的多边形是否形成有效的多边形覆盖范围。 "
+"它返回线性指示器,显示每个多边形中无效边(如果有)的位置。"
 #. Tag: para
 #: reference_coverage.xml:38
 #, no-c-format
 msgid ""
 "A set of valid polygons is a valid coverage if the following conditions hold:"
-msgstr ""
+msgstr "如果满足以下条件,则一组有效多边形是有效的覆盖范围:"
 #. Tag: para
 #: reference_coverage.xml:42
@@ -82,7 +87,8 @@ msgstr ""
 msgid ""
 "<emphasis role=\"bold\">Non-overlapping</emphasis> - polygons do not overlap "
 "(their interiors do not intersect)"
-msgstr ""
+msgstr "<emphasis role=\"bold\">Non-"
+"overlapping</emphasis>-多边形不重叠(它们的内部不相交)"
 #. Tag: para
 #: reference_coverage.xml:45
@@ -90,7 +96,7 @@ msgstr ""
 msgid ""
 "<emphasis role=\"bold\">Edge-Matched</emphasis> - vertices along shared "
 "edges are identical"
-msgstr ""
+msgstr "<emphasis role=\"bold\">Edge-Matched</emphasis>-沿共享边的顶点相同"
 #. Tag: para
 #: reference_coverage.xml:50
@@ -102,6 +108,10 @@ msgid ""
 "polygons return the value NULL. Non-polygonal or empty geometries also "
 "produce NULL values."
 msgstr ""
+"作为窗口函数,为每个输入多边形返回一个值。 "
+"对于违反一个或多个有效性条件的多边形,返回值是包含有问题边的 "
+"MULTILINESTRING。 覆盖范围有效的面返回值 NULL。 非多边形或空几何图形也会产生 "
+"NULL 值。"
 #. Tag: para
 #: reference_coverage.xml:55
@@ -113,6 +123,9 @@ msgid ""
 "parameter> parameter is specified with a non-zero distance, edges forming "
 "narrower gaps will also be returned as invalid."
 msgstr ""
+"只要周围的多边形边缘匹配,这些条件就允许有效的覆盖范围包含孔(多边形之间的间"
+"隙)。 然而,非常窄的间隙通常是不希望的。 如果使用非零距离指定<parameter>公差"
+"</parameter>参数,则形成较窄间隙的边缘也将被返回为无效。"
 #. Tag: para
 #: reference_coverage.xml:62
@@ -120,7 +133,8 @@ msgstr ""
 msgid ""
 "The polygons being checked for coverage validity must also be valid "
 "geometries. This can be checked with <xref linkend=\"ST_IsValid\"/>."
-msgstr ""
+msgstr "正在检查覆盖范围有效性的多边形也必须是有效的几何图形。 这可以使用<xref "
+"linkend=\"ST_IsValid\"/> 进行检查。"
 #. Tag: para
 #: reference_coverage.xml:66 reference_coverage.xml:139
@@ -132,7 +146,7 @@ msgstr "可用性:3.4.0"
 #: reference_coverage.xml:67 reference_coverage.xml:140
 #, no-c-format
 msgid "Requires GEOS >= 3.12.0"
-msgstr ""
+msgstr "需要GEOS >= 3.12.0"
 #. Tag: title
 #: reference_coverage.xml:71 reference_coverage.xml:144
@@ -145,7 +159,7 @@ msgstr "示例"
 #: reference_coverage.xml:78
 #, no-c-format
 msgid "Invalid edges caused by overlap and non-matching vertices"
-msgstr ""
+msgstr "由重叠和不匹配顶点引起的无效边"
 #. Tag: title
 #: reference_coverage.xml:88 reference_coverage.xml:178
@@ -161,12 +175,14 @@ msgid ""
 ", <xref linkend=\"ST_CoverageUnion\"/>, <xref "
 "linkend=\"ST_CoverageSimplify\"/>"
 msgstr ""
+", <xref linkend=\"ST_CoverageUnion\"/>, <xref linkend=\"ST_CoverageSimplify\""
 #. Tag: refpurpose
 #: reference_coverage.xml:103
 #, no-c-format
 msgid "Window function that simplifies the edges of a polygonal coverage."
-msgstr ""
+msgstr "简化多边形覆盖范围边缘的窗口函数。"
 #: reference_coverage.xml:108
@@ -188,6 +204,8 @@ msgid ""
 "simplified output polygons are consisent along shared edges, and still form "
 "a valid coverage."
 msgstr ""
+"一种窗函数,可简化多边形覆盖范围内的多边形边缘。 简化保留了覆盖拓扑。 "
+"这意味着简化的输出多边形沿着共享边是一致的,并且仍然形成有效的覆盖范围。"
 #. Tag: para
 #: reference_coverage.xml:128
@@ -199,6 +217,9 @@ msgid ""
 "of distance, and is roughly equal to the square root of triangular areas to "
 "be simplified."
 msgstr ""
+"简化使用了 <ulink url=\"https://en.wikipedia.org/wiki/Visvalingam%E2%80%"
+"93Whyatt_algorithm\">Visvalingam–Whyatt </ulink>算法的格式。 <parameter>公差<"
+"/parameter>参数以距离为单位,大致等于待简化的三角形面积的平方根。"
 #. Tag: para
 #: reference_coverage.xml:133
@@ -208,6 +229,8 @@ msgid ""
 "shared by two polygons) set the <parameter>simplifyBoundary</parameter> "
 "parameter to false."
 msgstr ""
+"要仅简化 Coverage 的“内部”边缘(由两个多边形共享的边缘),请将 "
+"<parameter>SimplyBoundary </parameter>参数设置为 false。"
 #. Tag: para
 #: reference_coverage.xml:135
@@ -218,18 +241,21 @@ msgid ""
 "appeared to be shared). Use <xref linkend=\"ST_CoverageInvalidEdges\"/> to "
 "determine if a coverage is valid."
 msgstr ""
+"如果输入不是有效的覆盖范围,则输出中可能会出现意外的伪影(例如边界交叉点或看"
+"似共享的分离边界)。 使用 <xref linkend=\"ST_CoverageInvalidEdges\"/> "
+"确定覆盖范围是否有效。"
 #. Tag: para
 #: reference_coverage.xml:155 reference_coverage.xml:231
 #, no-c-format
 msgid "Input coverage"
-msgstr ""
+msgstr "输入覆盖范围"
 #. Tag: para
 #: reference_coverage.xml:165
 #, no-c-format
 msgid "Simplified coverage"
-msgstr ""
+msgstr "简化覆盖范围"
 #. Tag: refpurpose
 #: reference_coverage.xml:190
@@ -237,7 +263,7 @@ msgstr ""
 msgid ""
 "Computes the union of a set of polygons forming a coverage by removing "
 "shared edges."
-msgstr ""
+msgstr "通过删除共享边来计算形成覆盖范围的一组多边形的并集。"
 #: reference_coverage.xml:195
@@ -257,6 +283,9 @@ msgid ""
 "linkend=\"ST_Union\"/>, but uses the coverage structure to compute the union "
 "much faster."
 msgstr ""
+"将一组多边形联合起来形成多边形覆盖范围的聚合函数。 "
+"结果是覆盖与覆盖范围相同的区域的多边形几何体。 该函数产生与 <xref linkend="
+"\"ST_Union\"/>相同的结果,但使用覆盖结构来更快地计算并集。"
 #. Tag: para
 #: reference_coverage.xml:212
@@ -266,18 +295,21 @@ msgid ""
 "the output (such as unmerged or overlapping polygons). Use <xref "
 "linkend=\"ST_CoverageInvalidEdges\"/> to determine if a coverage is valid."
 msgstr ""
+"如果输入不是有效的覆盖范围,则输出中可能会出现意外的伪影(例如未合并或重叠的"
+"多边形)。 使用 <xref linkend=\"ST_CoverageInvalidEdges\""
+"/>确定覆盖范围是否有效。"
 #. Tag: para
 #: reference_coverage.xml:216
 #, no-c-format
 msgid "Availability: 3.4.0 - requires GEOS >= 3.8.0"
-msgstr ""
+msgstr "可用性:3.4.0-需要 GEOS >= 3.8.0"
 #. Tag: para
 #: reference_coverage.xml:241
 #, no-c-format
 msgid "Union result"
-msgstr ""
+msgstr "联合结果"
 #. Tag: para
 #: reference_coverage.xml:255
commit ce8a8df521988ddb0cc19c5ef9fa27738776ac13
Date:   Fri Sep 8 01:22:35 2023 +0000
    Currently translated at 100.0% (297 of 297 strings)
    Translation: postgis/reference_processing.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_processingxml/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_processing.xml.po b/doc/po/zh_Hans/reference_processing.xml.po
index e35ff0248..9a7b3f330 100644
--- a/doc/po/zh_Hans/reference_processing.xml.po
+++ b/doc/po/zh_Hans/reference_processing.xml.po
 "POT-Creation-Date: 2023-07-19 07:45+0000\n"
-"PO-Revision-Date: 2023-09-07 10:14+0000\n"
 "postgis/reference_processingxml/zh_Hans/>\n"
 #. Tag: para
 #: reference_processing.xml:5
@@ -1348,6 +1348,9 @@ msgid ""
 "intersections. Lines are not joined across intersections of 3-way or greater "
 "degree."
 msgstr ""
+"返回通过将 MultiLineString 的线元素连接在一起而形成的 LineString 或 "
+"MultiLineString。 线在 2 线交叉点处的端点处连接。 "
+"线不会在三向或更高阶次的交叉点上连接。"
 #. Tag: para
 #: reference_processing.xml:1195
@@ -1357,6 +1360,8 @@ msgid ""
 "will not change point order within LineStrings, so lines with opposite "
 "directions will not be merged"
 msgstr ""
+"如果<emphasis role=\"bold\">定向</emphasis>为 TRUE,则 ST_LineMerge "
+"将不会更改 LineStrings 内的点顺序,因此方向相反的线不会被合并"
 #. Tag: para
 #: reference_processing.xml:1199
@@ -1364,37 +1369,38 @@ msgstr ""
 msgid ""
 "Only use with MultiLineString/LineStrings. Other geometry types return an "
 "empty GeometryCollection"
-msgstr ""
+msgstr "仅与 MultiLineString/LineString 一起使用。 其他几何类型返回空的 "
+"GeometryCollection"
 #. Tag: para
 #: reference_processing.xml:1202
 #, no-c-format
 msgid "Enhanced: 3.3.0 accept a directed parameter."
-msgstr ""
+msgstr "增强:3.3.0 接受定向参数。"
 #. Tag: para
 #: reference_processing.xml:1203
 #, no-c-format
 msgid "Requires GEOS >= 3.11.0 to use the directed parameter."
-msgstr ""
+msgstr "需要 GEOS >= 3.11.0 才能使用定向参数。"
 #. Tag: para
 #: reference_processing.xml:1205
 #, no-c-format
 msgid "This function strips the M dimension."
-msgstr ""
+msgstr "此函数剥离 M 维度。"
 #. Tag: para
 #: reference_processing.xml:1218
 #, no-c-format
 msgid "Merging lines with different orientation."
-msgstr ""
+msgstr "合并不同方向的线。"
 #. Tag: para
 #: reference_processing.xml:1234
 #, no-c-format
 msgid "Lines are not merged across intersections with degree > 2."
-msgstr ""
+msgstr "线不会在度数 > 2 的交点处合并。"
 #. Tag: para
 #: reference_processing.xml:1242
@@ -1402,31 +1408,31 @@ msgstr ""
 msgid ""
 "If merging is not possible due to non-touching lines, the original "
 "MultiLineString is returned."
-msgstr ""
+msgstr "如果由于不接触线而无法合并,则返回原始 MultiLineString。"
 #. Tag: para
 #: reference_processing.xml:1253
 #, no-c-format
 msgid "Lines with opposite directions are not merged if directed = TRUE."
-msgstr ""
+msgstr "如果directed = TRUE,则不合并具有相反方向的线。"
 #. Tag: para
 #: reference_processing.xml:1260
 #, no-c-format
 msgid "Example showing Z-dimension handling."
-msgstr ""
+msgstr "显示 处理Z 维度的示例。"
 #. Tag: para
 #: reference_processing.xml:1265
 #, no-c-format
 msgid ", <xref linkend=\"ST_LineSubstring\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_LineSubstring\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:1272
 #, no-c-format
 msgid "Computes the largest circle contained within a geometry."
-msgstr ""
+msgstr "计算几何体中包含的最大圆。"
 #: reference_processing.xml:1277
@@ -1443,28 +1449,29 @@ msgstr ""
 msgid ""
 "Finds the largest circle that is contained within a (multi)polygon, or which "
 "does not overlap any lines and points. Returns a record with fields:"
-msgstr ""
+msgstr "查找(多)多边形内包含的最大圆,或者不与任何线和点重叠的最大圆。 "
+"返回包含字段的记录:"
 #. Tag: para
 #: reference_processing.xml:1291 reference_processing.xml:1357
 #: reference_processing.xml:1480
 #, no-c-format
 msgid "<varname>center</varname> - center point of the circle"
-msgstr ""
+msgstr "<varname>center</varname>-圆的中心点"
 #. Tag: para
 #: reference_processing.xml:1292 reference_processing.xml:1358
 #, no-c-format
 msgid ""
 "<varname>nearest</varname> - a point on the geometry nearest to the center"
-msgstr ""
+msgstr "<varname>nearest</varname>-几何上最接近中心的点"
 #. Tag: para
 #: reference_processing.xml:1293 reference_processing.xml:1359
 #: reference_processing.xml:1481
 #, no-c-format
 msgid "<varname>radius</varname> - radius of the circle"
-msgstr ""
+msgstr "<varname>radius</varname>-圆的半径"
 #. Tag: para
 #: reference_processing.xml:1296
@@ -1474,20 +1481,21 @@ msgid ""
 "using the internal rings as boundaries. For linear and point inputs, the "
 "circle is inscribed within the convex hull of the input, using the input "
 "lines and points as further boundaries."
-msgstr ""
+msgstr "对于多边形输入,圆内接于边界环内,使用内环作为边界。 "
+"对于线性和点输入,圆内切于输入的凸包内,使用输入线和点作为进一步的边界。"
 #. Tag: para
 #: reference_processing.xml:1300 reference_processing.xml:1982
 #, no-c-format
 msgid "Availability: 3.1.0."
-msgstr ""
+msgstr "可用性:3.1.0。"
 #. Tag: para
 #: reference_processing.xml:1301 reference_processing.xml:1365
 #: reference_processing.xml:1983
 #, no-c-format
 msgid "Requires GEOS >= 3.9.0."
-msgstr ""
+msgstr "需要GEOS >= 3.9.0。"
 #. Tag: para
 #: reference_processing.xml:1312
@@ -1495,7 +1503,7 @@ msgstr ""
 msgid ""
 "Maximum inscribed circle of a polygon. Center, nearest point, and radius are "
 "returned."
-msgstr ""
+msgstr "多边形的最大内切圆。 返回中心、最近点和半径。"
 #. Tag: para
 #: reference_processing.xml:1322
@@ -1503,19 +1511,19 @@ msgstr ""
 msgid ""
 "Maximum inscribed circle of a multi-linestring. Center, nearest point, and "
 "radius are returned."
-msgstr ""
+msgstr "多线串的最大内切圆。 返回中心、最近点和半径。"
 #. Tag: para
 #: reference_processing.xml:1328
 #, no-c-format
 msgid ", <xref linkend=\"ST_LargestEmptyCircle\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_LargestEmptyCircle\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:1336
 #, no-c-format
 msgid "Computes the largest circle not overlapping a geometry."
-msgstr ""
+msgstr "计算不与几何图形重叠的最大圆。"
 #: reference_processing.xml:1341
@@ -1543,6 +1551,10 @@ msgid ""
 "itself is provided by the center point and a nearest point lying on an "
 "obstacle detemining the circle radius."
 msgstr ""
+"找到不与一组点和线障碍物重叠的最大圆。 (多边形几何图形可以作为障碍物包含在内"
+",但仅使用它们的边界线。)圆的中心被限制位于多边形边界内,默认情况下,多边形"
+"边界是输入几何图形的凸包。 圆心是边界内部距离障碍物最远的点。 "
+"圆本身由中心点和位于确定圆半径的障碍物上的最近点提供。"
 #. Tag: para
 #: reference_processing.xml:1353
@@ -1551,13 +1563,14 @@ msgid ""
 "The circle center is determined to a given accuracy specified by a distance "
 "tolerance, using an iterative algorithm. If the accuracy distance is not "
 "specified a reasonable default is used."
-msgstr ""
+msgstr "使用迭代算法将圆心确定为由距离容差指定的给定精度。 "
+"如果未指定精度距离,则使用合理的默认值。"
 #. Tag: para
 #: reference_processing.xml:1354
 #, no-c-format
 msgid "Returns a record with fields:"
-msgstr ""
+msgstr "返回包含字段的记录:"
 #. Tag: para
 #: reference_processing.xml:1362
@@ -1565,19 +1578,20 @@ msgstr ""
 msgid ""
 "To find the largest empty circle in the interior of a polygon, see <xref "
 "linkend=\"ST_MaximumInscribedCircle\"/>."
-msgstr ""
+msgstr "要查找多边形内部最大的空圆,请参见<xref linkend=\"ST_MaximumInscribedCircle\""
 #. Tag: para
 #: reference_processing.xml:1364
 #, no-c-format
 msgid "Availability: 3.4.0."
-msgstr ""
+msgstr "可用性:3.4.0。"
 #. Tag: para
 #: reference_processing.xml:1379
 #, no-c-format
 msgid "Largest Empty Circle within a set of lines."
-msgstr ""
+msgstr "一组线内最大的空圆。"
 #. Tag: para
 #: reference_processing.xml:1390
@@ -1586,7 +1600,8 @@ msgid ""
 "Largest Empty Circle within a set of points, constrained to lie in a "
 "polygon. The constraint polygon boundary must be included as an obstacle, as "
 "well as specified as the constraint for the circle center."
-msgstr ""
+msgstr "一组点内最大的空圆,约束位于多边形内。 "
+"约束多边形边界必须作为障碍物包含在内,并指定为圆心的约束。"
 #. Tag: refpurpose
 #: reference_processing.xml:1405
@@ -1594,7 +1609,7 @@ msgstr ""
 msgid ""
 "<refpurpose>Returns the smallest circle polygon that contains a geometry.</"
 "refpurpose>"
-msgstr ""
+msgstr "<refpurpose>返回包含几何图形的最小圆形多边形。</refpurpose>"
 #: reference_processing.xml:1410
@@ -1611,7 +1626,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 "<para>Returns the smallest circle polygon that contains a geometry.</para>"
-msgstr ""
+msgstr "<para>返回包含几何图形的最小圆形多边形。</para>"
 #. Tag: para
 #: reference_processing.xml:1422
@@ -1624,6 +1639,10 @@ msgid ""
 "increasing the number of segments. For applications where an approximation "
 "is not suitable <xref linkend=\"ST_MinimumBoundingRadius\"/> may be used."
 msgstr ""
+"边界圆近似为多边形,默认情况下每四分之一圆有 48 个线段。 "
+"由于多边形是最小外接圆的近似值,因此输入几何中的某些点可能不包含在多边形内。 "
+"可以通过增加分段数量来改进近似值。 对于近似值不合适的应用,可以使用 <xref "
+"linkend=\"ST_MinimumBoundingRadius\"/>。"
 #. Tag: para
 #: reference_processing.xml:1427 reference_processing.xml:1484
@@ -1631,7 +1650,7 @@ msgstr ""
 msgid ""
 "Use with <xref linkend=\"ST_Collect\"/> to get the minimum bounding circle "
 "of a set of geometries."
-msgstr ""
+msgstr "与<xref linkend=\"ST_Collect\"/> 一起使用以获得一组几何图形的最小边界圆。"
 #. Tag: para
 #: reference_processing.xml:1429 reference_processing.xml:1486
@@ -1639,7 +1658,8 @@ msgstr ""
 msgid ""
 "To compute two points lying on the mimimum circle (the \"maximum diameter\") "
 "use <xref linkend=\"ST_LongestLine\"/>."
-msgstr ""
+msgstr "要计算位于最小圆(“最大直径”)上的两个点,请使用<xref linkend="
+"\"ST_LongestLine\"/>。"
 #. Tag: para
 #: reference_processing.xml:1432
@@ -1648,7 +1668,8 @@ msgid ""
 "The ratio of the area of a polygon divided by the area of its Minimum "
 "Bounding Circle is referred to as the <emphasis>Reock compactness score</"
 "emphasis>."
-msgstr ""
+msgstr "多边形的面积除以最小包含圆的面积之比称为<emphasis> REOCK "
+"紧致度得分</emphasis>。"
 #. Tag: para
 #: reference_processing.xml:1435
@@ -1662,7 +1683,7 @@ msgstr "可用性:1.4.0"
 msgid ""
 "Minimum bounding circle of a point and linestring. Using 8 segs to "
 "approximate a quarter circle"
-msgstr ""
+msgstr "点和线串的最小外接圆。 用8段近似四分之一圆"
 #. Tag: para
 #: reference_processing.xml:1454
@@ -1671,6 +1692,8 @@ msgid ""
 ", <xref linkend=\"ST_MinimumBoundingRadius\"/>, <xref "
 "linkend=\"ST_LargestEmptyCircle\"/>, <xref linkend=\"ST_LongestLine\"/>"
 msgstr ""
+", <xref linkend=\"ST_MinimumBoundingRadius\"/>, <xref linkend="
+"\"ST_LargestEmptyCircle\"/>, <xref linkend=\"ST_LongestLine\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:1462
@@ -1678,7 +1701,7 @@ msgstr ""
 msgid ""
 "Returns the center point and radius of the smallest circle that contains a "
 "geometry."
-msgstr ""
+msgstr "返回包含几何图形的最小圆的中心点和半径。"
 #: reference_processing.xml:1467
@@ -1695,13 +1718,13 @@ msgstr ""
 msgid ""
 "Computes the center point and radius of the smallest circle that contains a "
 "geometry. Returns a record with fields:"
-msgstr ""
+msgstr "计算包含几何图形的最小圆的中心点和半径。 返回包含字段的记录:"
 #. Tag: para
 #: reference_processing.xml:1489
 #, no-c-format
 msgid "Availability - 2.3.0"
-msgstr ""
+msgstr "可用性-2.3.0"
 #. Tag: para
 #: reference_processing.xml:1499
@@ -1710,12 +1733,14 @@ msgid ""
 ", <xref linkend=\"ST_MinimumBoundingCircle\"/>, <xref "
 "linkend=\"ST_LongestLine\"/>"
 msgstr ""
+", <xref linkend=\"ST_MinimumBoundingCircle\"/>, <xref linkend="
+"\"ST_LongestLine\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:1507
 #, no-c-format
 msgid "Returns a minimum-area rectangle containing a geometry."
-msgstr ""
+msgstr "返回包含几何图形的最小面积矩形。"
 #: reference_processing.xml:1512
@@ -1732,31 +1757,32 @@ msgid ""
 "Returns the minimum-area rotated rectangle enclosing a geometry. Note that "
 "more than one such rectangle may exist. May return a Point or LineString in "
 "the case of degenerate inputs."
-msgstr ""
+msgstr "返回包围几何体的最小面积旋转矩形。 请注意,可能存在多个这样的矩形。 "
+"在退化输入的情况下可能返回 Point 或 LineString。"
 #. Tag: para
 #: reference_processing.xml:1529
 #, no-c-format
 msgid "Availability: 2.5.0."
-msgstr ""
+msgstr "可用性:2.5.0。"
 #. Tag: para
 #: reference_processing.xml:1532
 #, no-c-format
 msgid "Requires GEOS >= 3.6.0."
-msgstr ""
+msgstr "需要GEOS >= 3.6.0。"
 #. Tag: para
 #: reference_processing.xml:1544
 #, no-c-format
 msgid "Oriented envelope of a point and linestring."
-msgstr ""
+msgstr "点和线串的最小外接矩形。"
 #. Tag: refpurpose
 #: reference_processing.xml:1564
 #, no-c-format
 msgid "Returns an offset line at a given distance and side from an input line."
-msgstr ""
+msgstr "返回距输入线给定距离和方向的偏移线。"
 #: reference_processing.xml:1572
@@ -1777,7 +1803,9 @@ msgid ""
 "points of the returned geometries are not further than the given distance "
 "from the input geometry. Useful for computing parallel lines about a center "
 "line."
-msgstr ""
+msgstr "返回距输入线给定距离和方向的偏移线。 "
+"返回几何图形的所有点与输入几何图形的距离不超过给定距离。 "
+"对于计算围绕中心线的平行线很有用。"
 #. Tag: para
 #: reference_processing.xml:1592
@@ -1786,14 +1814,15 @@ msgid ""
 "For positive distance the offset is on the left side of the input line and "
 "retains the same direction. For a negative distance it is on the right side "
 "and in the opposite direction."
-msgstr ""
+msgstr "对于正距离,偏移位于输入线的左侧并保持相同的方向。 "
+"对于负距离,它位于右侧且方向相反。"
 #. Tag: para
 #: reference_processing.xml:1597
 #, no-c-format
 msgid ""
 "Units of distance are measured in units of the spatial reference system."
-msgstr ""
+msgstr "距离单位以空间参考系的单位来测量。"
 #. Tag: para
 #: reference_processing.xml:1600
@@ -1801,7 +1830,7 @@ msgstr ""
 msgid ""
 "Note that output may be a MULTILINESTRING or EMPTY for some jigsaw-shaped "
 "input geometries."
-msgstr ""
+msgstr "请注意,对于某些拼图形状的输入几何图形,输出可能是 MULTILINESTRING 或 EMPTY。"
 #. Tag: para
 #: reference_processing.xml:1603
@@ -1809,7 +1838,7 @@ msgstr ""
 msgid ""
 "The optional third parameter allows specifying a list of blank-separated "
 "key=value pairs to tweak operations as follows:"
-msgstr ""
+msgstr "可选的第三个参数允许指定空白分隔的键=值对的列表来调整操作,如下所示:"
 #. Tag: para
 #: reference_processing.xml:1608
@@ -1817,7 +1846,7 @@ msgstr ""
 msgid ""
 "'quad_segs=#' : number of segments used to approximate a quarter circle "
 "(defaults to 8)."
-msgstr ""
+msgstr "'quad_segs=#' :用于近似四分之一圆的线段数(默认为 8)。"
 #. Tag: para
 #: reference_processing.xml:1611
@@ -1825,7 +1854,8 @@ msgstr ""
 msgid ""
 "'join=round|mitre|bevel' : join style (defaults to \"round\"). 'miter' is "
 "also accepted as a synonym for 'mitre'."
-msgstr ""
+msgstr "'join=round|mitre|bevel' :连接样式(默认为“round”)。 "
+"“mitre”也被认为是“mitre”的同义词。"
 #. Tag: para
 #: reference_processing.xml:1614
@@ -1834,6 +1864,8 @@ msgid ""
 "'mitre_limit=#.#' : mitre ratio limit (only affects mitred join style). "
 "'miter_limit' is also accepted as a synonym for 'mitre_limit'."
 msgstr ""
+"'mitre_limit=#.#' :斜接比率限制(仅影响斜接连接样式)。 "
+"“miter_limit”也被接受为“mitre_limit”的同义词。"
 #. Tag: para
 #: reference_processing.xml:1620
@@ -1846,25 +1878,25 @@ msgstr "可用性:2.0"
 #, no-c-format
 msgid ""
 "Enhanced: 2.5 - added support for GEOMETRYCOLLECTION and MULTILINESTRING"
-msgstr ""
+msgstr "增强:2.5 - 添加了对 GEOMETRYCOLLECTION 和 MULTILINESTRING 的支持"
 #. Tag: para
 #: reference_processing.xml:1630
 #, no-c-format
 msgid "Compute an open buffer around roads"
-msgstr ""
+msgstr "计算道路周围的开放缓冲区"
 #. Tag: para
 #: reference_processing.xml:1641
 #, no-c-format
 msgid "15, 'quad_segs=4 join=round' original line and its offset 15 units."
-msgstr ""
+msgstr "15、'quad_segs=4 join=round' 原始线及其偏移 15 个单位。"
 #. Tag: para
 #: reference_processing.xml:1652
 #, no-c-format
 msgid "-15, 'quad_segs=4 join=round' original line and its offset -15 units"
-msgstr ""
+msgstr "-15, 'quad_segs=4 join=round' 原始线及其偏移量-15个单位"
 #. Tag: para
 #: reference_processing.xml:1665
@@ -1872,7 +1904,7 @@ msgstr ""
 msgid ""
 "double-offset to get more curvy, note the first reverses direction, so -30 + "
 "15 = -15"
-msgstr ""
+msgstr "双偏移以获得更多曲线,请注意第一个反转方向,因此 -30+15 = -15"
 #. Tag: para
 #: reference_processing.xml:1675
@@ -1880,25 +1912,25 @@ msgstr ""
 msgid ""
 "double-offset to get more curvy,combined with regular offset 15 to get "
 "parallel lines. Overlaid with original."
-msgstr ""
+msgstr "双偏移以获得更多曲线,与常规偏移 15 结合以获得平行线。 与原图重叠。"
 #. Tag: para
 #: reference_processing.xml:1687
 #, no-c-format
 msgid "15, 'quad_segs=4 join=bevel' shown with original line"
-msgstr ""
+msgstr "15、'quad_segs=4 join=bevel' 显示为原始线"
 #. Tag: para
 #: reference_processing.xml:1698
 #, no-c-format
 msgid "15,-15 collected, join=mitre mitre_limit=2.1"
-msgstr ""
+msgstr "15、-15收集,join=mitre mitre_limit=2.1"
 #. Tag: refpurpose
 #: reference_processing.xml:1719
 #, no-c-format
 msgid "Computes a point guaranteed to lie in a polygon, or on a geometry."
-msgstr ""
+msgstr "计算保证位于多边形或几何体上的点。"
 #: reference_processing.xml:1724
@@ -1916,12 +1948,14 @@ msgid ""
 "interior of a surface (POLYGON, MULTIPOLYGON, and CURVED POLYGON). In "
 "PostGIS this function also works on line and point geometries."
 msgstr ""
+"返回保证位于曲面内部的<varname>点</varname>(POLYGON、MULTIPOLYGON 和 CURVED "
+"POLYGON)。 在 PostGIS 中,此函数也适用于线和点几何图形。"
 #. Tag: para
 #: reference_processing.xml:1741
 #, no-c-format
 msgid "&sfs_compliant; s3.2.14.2 // s3.2.18.2"
-msgstr ""
+msgstr "&sfs_compliant; s3.2.14.2 // s3.2.18.2"
 #. Tag: para
 #: reference_processing.xml:1742
@@ -1933,30 +1967,34 @@ msgid ""
 "seem to support this function only for surfaces. SQL Server 2008 supports "
 "all common geometry types."
 msgstr ""
+"&sqlmm_compliant; SQL-MM 3:8.1.5、9.5.6。 该规范仅针对表面几何形状定义 "
+"ST_PointOnSurface。 PostGIS扩展了功能以支持所有常见的几何类型。 "
+"其他数据库(Oracle、DB2、ArcSDE)似乎仅支持曲面的此功能。 SQL Server 2008 "
+"支持所有常见的几何类型。"
 #. Tag: para
 #: reference_processing.xml:1763
 #, no-c-format
 msgid "PointOnSurface of a <varname>MULTIPOINT</varname>"
-msgstr ""
+msgstr "<varname>多点</varname>表面上的点"
 #. Tag: para
 #: reference_processing.xml:1774
 #, no-c-format
 msgid "PointOnSurface of a <varname>LINESTRING</varname>"
-msgstr ""
+msgstr "<varname>线串</varname>表面上的点"
 #. Tag: para
 #: reference_processing.xml:1787
 #, no-c-format
 msgid "PointOnSurface of a <varname>POLYGON</varname>"
-msgstr ""
+msgstr "<varname>面</varname>表面上的点"
 #. Tag: para
 #: reference_processing.xml:1798
 #, no-c-format
 msgid "PointOnSurface of a <varname>GEOMETRYCOLLECTION</varname>"
-msgstr ""
+msgstr "<varname>几何集合</varname>表面上的点"
 #. Tag: para
 #: reference_processing.xml:1809
@@ -1966,18 +2004,21 @@ msgid ""
 "is guaranteed to lie within polygons, whereas the point computed by <xref "
 "linkend=\"ST_Centroid\"/> may be outside."
 msgstr ""
+"<emphasis role=\"bold\">示例:</emphasis>ST_PointOnSurface "
+"的结果保证位于多边形内,而 <xref linkend=\"ST_Centroid\""
+"/>计算的点可能位于多边形外。"
 #. Tag: para
 #: reference_processing.xml:1819
 #, no-c-format
 msgid "Red: point on surface; Green: centroid"
-msgstr ""
+msgstr "红色:表面上的点; 绿色:质心"
 #. Tag: para
 #: reference_processing.xml:1828
 #, no-c-format
 msgid ", <xref linkend=\"ST_MaximumInscribedCircle\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_MaximumInscribedCircle\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:1836
@@ -1985,7 +2026,7 @@ msgstr ""
 msgid ""
 "Computes a collection of polygons formed from the linework of a set of "
 "geometries."
-msgstr ""
+msgstr "计算由一组几何图形的线条形成的多边形集合。"
 #. Tag: para
 #: reference_processing.xml:1857
@@ -1995,6 +2036,8 @@ msgid ""
 "of a set of geometries. If the input linework does not form any polygons, an "
 "empty GeometryCollection is returned."
 msgstr ""
+"创建一个 GeometryCollection,其中包含由一组几何图形的线条形成的多边形。 "
+"如果输入线条未形成任何多边形,则返回空的 GeometryCollection。"
 #. Tag: para
 #: reference_processing.xml:1862
@@ -2004,6 +2047,8 @@ msgid ""
 "is intended to form a valid polygonal geometry, use <xref "
 "linkend=\"ST_BuildArea\"/> to prevent holes being filled."
 msgstr ""
+"此函数创建覆盖所有分隔区域的多边形。 如果结果旨在形成有效的多边形几何体,"
+"请使用 <xref linkend=\"ST_BuildArea\"/> 来防止填充孔。"
 #. Tag: para
 #: reference_processing.xml:1868
@@ -2013,6 +2058,8 @@ msgid ""
 "properly. To ensure input is noded use <xref linkend=\"ST_Node\"/> on the "
 "input geometry before polygonizing."
 msgstr ""
+"输入线条必须正确节点才能使该功能正常工作。 为了确保输入已节点化,"
+"请在多边形化之前在输入几何体上使用 <xref linkend=\"ST_Node\"/>。"
 #. Tag: para
 #: reference_processing.xml:1876
@@ -2021,7 +2068,8 @@ msgid ""
 "GeometryCollections can be difficult to handle with external tools. Use "
 "<xref linkend=\"ST_Dump\"/> to convert the polygonized result into separate "
 "polygons."
-msgstr ""
+msgstr "使用外部工具可能很难处理几何集合。 使用<xref linkend=\"ST_Dump\"/> "
+"将多边形结果转换为单独的多边形。"
 #. Tag: para
 #: reference_processing.xml:1882
@@ -2033,25 +2081,25 @@ msgstr "可用性: 1.0.0RC1"
 #: reference_processing.xml:1908
 #, no-c-format
 msgid "Polygonized result"
-msgstr ""
+msgstr "多边形化结果"
 #. Tag: para
 #: reference_processing.xml:1920
 #, no-c-format
 msgid "Polygonizing a table of linestrings:"
-msgstr ""
+msgstr "多边形线串表:"
 #. Tag: para
 #: reference_processing.xml:1926
 #, no-c-format
 msgid ", <xref linkend=\"ST_Dump\"/>, <xref linkend=\"ST_Node\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_Dump\"/>, <xref linkend=\"ST_Node\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:1938
 #, no-c-format
 msgid "Returns a valid geometry with points rounded to a grid tolerance."
-msgstr ""
+msgstr "返回有效的几何图形,其点舍入到网格公差。"
 #: reference_processing.xml:1943
@@ -2068,7 +2116,7 @@ msgstr ""
 msgid ""
 "Returns a valid geometry with all points rounded to the provided grid "
 "tolerance, and features below the tolerance removed."
-msgstr ""
+msgstr "返回有效的几何图形,其中所有点均舍入到提供的网格公差,并删除低于公差的要素。"
 #. Tag: para
 #: reference_processing.xml:1959
@@ -2076,25 +2124,26 @@ msgstr ""
 msgid ""
 "Unlike <xref linkend=\"ST_SnapToGrid\"/> the returned geometry will be "
 "valid, with no ring self-intersections or collapsed components."
-msgstr ""
+msgstr "与<xref linkend=\"ST_SnapToGrid\"/> "
+"不同,返回的几何图形将是有效的,没有环自相交或折叠组件。"
 #. Tag: para
 #: reference_processing.xml:1961
 #, no-c-format
 msgid "Precision reduction can be used to:"
-msgstr ""
+msgstr "精度降低可用于:"
 #. Tag: para
 #: reference_processing.xml:1964
 #, no-c-format
 msgid "match coordinate precision to the data accuracy"
-msgstr ""
+msgstr "将坐标精度与数据精度相匹配"
 #. Tag: para
 #: reference_processing.xml:1967
 #, no-c-format
 msgid "reduce the number of coordinates needed to represent a geometry"
-msgstr ""
+msgstr "减少表示几何图形所需的坐标数量"
 #. Tag: para
 #: reference_processing.xml:1970
@@ -2103,7 +2152,8 @@ msgid ""
 "ensure valid geometry output to formats which use lower precision (e.g. text "
 "formats such as WKT, GeoJSON or KML when the number of output decimal places "
 "is limited)."
-msgstr ""
+msgstr "确保有效的几何输出为使用较低精度的格式(例如,当输出小数位数有限时,WKT、"
+"GeoJSON 或 KML 等文本格式)。"
 #. Tag: para
 #: reference_processing.xml:1975
@@ -2111,25 +2161,25 @@ msgstr ""
 msgid ""
 "export valid geometry to systems which use lower or limited precision (e.g. "
 "SDE, Oracle tolerance value)"
-msgstr ""
+msgstr "将有效几何图形导出到使用较低或有限精度的系统(例如 SDE、Oracle 公差值)"
 #. Tag: para
 #: reference_processing.xml:1991
 #, no-c-format
 msgid "Precision reduction can reduce number of vertices"
-msgstr ""
+msgstr "降低精度可以减少顶点数量"
 #. Tag: para
 #: reference_processing.xml:1994
 #, no-c-format
 msgid "Precision reduction splits polygons if needed to ensure validity"
-msgstr ""
+msgstr "如果需要的话,精度降低会分割多边形以确保有效性"
 #. Tag: para
 #: reference_processing.xml:2001
 #, no-c-format
 msgid ", <xref linkend=\"ST_Simplify\"/>, <xref linkend=\"ST_SimplifyVW\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_Simplify\"/>, <xref linkend=\"ST_SimplifyVW\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:2008
@@ -2137,7 +2187,7 @@ msgstr ""
 msgid ""
 "Returns a collection containing paths shared by the two input linestrings/"
 "multilinestrings."
-msgstr ""
+msgstr "返回一个集合,其中包含两个输入线串/多线串共享的路径。"
 #: reference_processing.xml:2013
@@ -2157,18 +2207,21 @@ msgid ""
 "collection, those going in the opposite direction are in the second element. "
 "The paths themselves are given in the direction of the first geometry."
 msgstr ""
+"返回一个集合,其中包含两个输入几何图形共享的路径。 "
+"那些朝相同方向去的在集合的第一个元素中,那些朝相反方向去的在第二个元素中。 "
+"路径本身是在第一个几何体的方向上给出的。"
 #. Tag: title
 #: reference_processing.xml:2031
 #, no-c-format
 msgid "Examples: Finding shared paths"
-msgstr ""
+msgstr "示例:查找共享路径"
 #. Tag: para
 #: reference_processing.xml:2041
 #, no-c-format
 msgid "A multilinestring and a linestring"
-msgstr ""
+msgstr "multilinestring和linestring"
 #. Tag: para
 #: reference_processing.xml:2052
@@ -2176,7 +2229,7 @@ msgstr ""
 msgid ""
 "The shared path of multilinestring and linestring overlaid with original "
 "geometries."
-msgstr ""
+msgstr "multilinestring和 linestring与原始几何图形重叠的共享路径。"
 #. Tag: para
 #: reference_processing.xml:2071
@@ -2184,6 +2237,7 @@ msgstr ""
 msgid ""
 ", <xref linkend=\"ST_GeometryN\"/>, <xref linkend=\"ST_NumGeometries\"/>"
 msgstr ""
+", <xref linkend=\"ST_GeometryN\"/>, <xref linkend=\"ST_NumGeometries\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:2082
@@ -2191,7 +2245,7 @@ msgstr ""
 msgid ""
 "Returns a simplified version of a geometry, using the Douglas-Peucker "
 "algorithm."
-msgstr ""
+msgstr "使用 Douglas-Peucker 算法返回几何的简化版本。"
 #. Tag: para
 #: reference_processing.xml:2104
@@ -2203,6 +2257,10 @@ msgid ""
 "simplification occurs on a object-by-object basis you can also feed a "
 "GeometryCollection to this function."
 msgstr ""
+"使用 Douglas-Peucker 算法返回给定几何图形的“简化”版本。 实际上只会对(多)线"
+"和(多)多边形执行某些操作,但您可以使用任何类型的几何体安全地调用它。 "
+"由于简化是在逐个对象的基础上进行的,因此您还可以将 GeometryCollection "
+"提供给此函数。"
 #. Tag: para
 #: reference_processing.xml:2111
@@ -2215,6 +2273,10 @@ msgid ""
 "engines, to avoid having large numbers of very small objects disappear from "
 "a map leaving surprising gaps."
 msgstr ""
+"“保留折叠”标志将保留在给定容差的情况下太小的对象。 例如,将 1m 长的线简化为 "
+"10m 公差。 如果将<varname> preserveCollapsed </varname>参数指定为 "
+"true,则该线不会消失。 该标志对于渲染引擎很有用,可以避免大量非常小的对象从地"
+"图上消失,留下令人惊讶的间隙。"
 #. Tag: para
 #: reference_processing.xml:2118 reference_processing.xml:2299
@@ -2223,7 +2285,8 @@ msgstr ""
 msgid ""
 "Note that returned geometry might lose its simplicity (see <xref "
 "linkend=\"ST_IsSimple\"/>)"
-msgstr ""
+msgstr "请注意,返回的几何图形可能会失去其简单性(请参阅<xref linkend=\"ST_IsSimple\""
 #. Tag: para
 #: reference_processing.xml:2120 reference_processing.xml:2301
@@ -2233,6 +2296,8 @@ msgid ""
 "Note topology may not be preserved and may result in invalid geometries. Use "
 "(see <xref linkend=\"ST_SimplifyPreserveTopology\"/>) to preserve topology."
 msgstr ""
+"请注意,拓扑可能不会保留,并可能导致无效的几何图形。 使用(请参阅<xref "
+"linkend=\"ST_SimplifyPreserveTopology\"/>)保留拓扑。"
 #. Tag: para
 #: reference_processing.xml:2122
@@ -2244,7 +2309,7 @@ msgstr "可用性:1.2.2"
 #: reference_processing.xml:2127
 #, no-c-format
 msgid "A circle simplified too much becomes a triangle, medium an octagon,"
-msgstr ""
+msgstr "它是一个经过简化后变成三角形或八角形的圆,"
 #. Tag: para
 #: reference_processing.xml:2132
@@ -2253,6 +2318,8 @@ msgid ""
 ", <xref linkend=\"ST_SimplifyPreserveTopology\"/>, <xref "
 "linkend=\"ST_SimplifyVW\"/>, Topology <xref linkend=\"TP_ST_Simplify\"/>"
 msgstr ""
+", <xref linkend=\"ST_SimplifyPreserveTopology\"/>, <xref linkend="
+"\"ST_SimplifyVW\"/>, Topology <xref linkend=\"TP_ST_Simplify\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:2143
@@ -2260,7 +2327,7 @@ msgstr ""
 msgid ""
 "Returns a simplified and valid version of a geometry, using the Douglas-"
 "Peucker algorithm."
-msgstr ""
+msgstr "使用 Douglas-Peucker 算法返回几何的简化且有效的版本。"
 #: reference_processing.xml:2149
@@ -2282,12 +2349,17 @@ msgid ""
 "geometry. Since simplification occurs on a object-by-object basis you can "
 "also feed a GeometryCollection to this function."
 msgstr ""
+"使用 Douglas-Peucker 算法返回给定几何图形的“简化”版本。 "
+"将避免创建无效的派生几何图形(特别是多边形)。 实际上只会对(多)线和(多)多"
+"边形执行某些操作,但您可以使用任何类型的几何体安全地调用它。 "
+"提供给此函数。"
 #. Tag: para
 #: reference_processing.xml:2168
 #, no-c-format
 msgid "Availability: 1.3.3"
-msgstr ""
+msgstr "可用性:1.3.3"
 #. Tag: para
 #: reference_processing.xml:2173
@@ -2295,7 +2367,7 @@ msgstr ""
 msgid ""
 "Same example as Simplify, but we see Preserve Topology prevents "
 "oversimplification. The circle can at most become a square."
-msgstr ""
+msgstr "与简化相同的示例,但我们看到保留拓扑可以防止过度简化。 圆最多可以变成正方形。"
 #. Tag: refpurpose
 #: reference_processing.xml:2186
@@ -2303,7 +2375,7 @@ msgstr ""
 msgid ""
 "Computes a simplifed topology-preserving outer or inner hull of a polygonal "
 "geometry."
-msgstr ""
+msgstr "计算多边形几何的简化的保留拓扑的外部或内部外壳。"
 #: reference_processing.xml:2191
@@ -2326,6 +2398,9 @@ msgid ""
 "geometry formed by a subset of the input vertices. MultiPolygons and holes "
 "are handled and produce a result with the same structure as the input."
 msgstr ""
+"计算多边形几何的简化的保留拓扑的外部或内部外壳。 外壳完全覆盖输入几何体。 "
+"内部外壳完全被输入几何体覆盖。 结果是由输入顶点的子集形成的多边形几何体。 "
+"处理多重多边形和孔并产生与输入结构相同的结果。"
 #. Tag: para
 #: reference_processing.xml:2210
@@ -2338,6 +2413,10 @@ msgid ""
 "geometry. For outer hulls a value of 0.0 produces the convex hull (for a "
 "single polygon); for inner hulls it produces a triangle."
 msgstr ""
+"顶点数的减少由<varname> vertex_fraction </varname>参数控制,该参数是 0 到 1 "
+"范围内的数字。值越低,结果越简单,顶点数越少,凹度也越小。 对于外壳和内壳,"
+"顶点分数 1.0 生成原始几何形状。 对于外壳,值 0.0 生成凸包(对于单个多边形);"
+" 对于内壳,它会生成一个三角形。"
 #. Tag: para
 #: reference_processing.xml:2217
@@ -2347,7 +2426,8 @@ msgid ""
 "corners that contain the least amount of area, until the vertex count target "
 "is reached. It prevents edges from crossing, so the result is always a valid "
 "polygonal geometry."
-msgstr ""
+msgstr "简化过程通过逐步删除包含最少面积的凹角来进行,直到达到顶点数目标。 "
+"它可以防止边交叉,因此结果始终是有效的多边形几何体。"
 #. Tag: para
 #: reference_processing.xml:2222
@@ -2355,37 +2435,37 @@ msgstr ""
 msgid ""
 "To get better results with geometries that contain relatively long line "
 "segments, it might be necessary to \"segmentize\" the input, as shown below."
-msgstr ""
+msgstr "为了获得包含相对较长线段的几何图形的更好结果,可能需要“分段”输入,如下所示。"
 #. Tag: para
 #: reference_processing.xml:2225 reference_processing.xml:2401
 #, no-c-format
 msgid "Availability: 3.3.0."
-msgstr ""
+msgstr "可用性:3.3.0。"
 #. Tag: para
 #: reference_processing.xml:2226 reference_processing.xml:2402
 #, no-c-format
 msgid "Requires GEOS >= 3.11.0."
-msgstr ""
+msgstr "需要GEOS >= 3.11.0。"
 #. Tag: para
 #: reference_processing.xml:2238
 #, no-c-format
 msgid "Outer hull of a Polygon"
-msgstr ""
+msgstr "多边形的外壳"
 #. Tag: para
 #: reference_processing.xml:2250
 #, no-c-format
 msgid "Inner hull of a Polygon"
-msgstr ""
+msgstr "多边形的内壳"
 #. Tag: para
 #: reference_processing.xml:2262
 #, no-c-format
 msgid "Outer hull simplification of a MultiPolygon, with segmentization"
-msgstr ""
+msgstr "MultiPolygon 的外壳简化,具有分段功能"
 #. Tag: para
 #: reference_processing.xml:2272
@@ -2394,6 +2474,8 @@ msgid ""
 ", <xref linkend=\"ST_SimplifyVW\"/>, <xref linkend=\"ST_ConcaveHull\"/>, "
 "<xref linkend=\"ST_Segmentize\"/>"
 msgstr ""
+", <xref linkend=\"ST_SimplifyVW\"/>, <xref linkend=\"ST_ConcaveHull\"/>, "
+"<xref linkend=\"ST_Segmentize\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:2280
@@ -2401,7 +2483,7 @@ msgstr ""
 msgid ""
 "Returns a simplified version of a geometry, using the Visvalingam-Whyatt "
 "algorithm"
-msgstr ""
+msgstr "使用 Visvalingam-Whyatt 算法返回几何的简化版本"
 #: reference_processing.xml:2285
@@ -2422,13 +2504,17 @@ msgid ""
 msgstr ""
+"使用 Visvalingam-Whyatt 算法返回给定几何图形的“简化”版本。 实际上只会对(多)"
+"线和(多)多边形执行某些操作,但您可以使用任何类型的几何体安全地调用它。 "
+"提供给此函数。"
 #. Tag: para
 #: reference_processing.xml:2302
 #, no-c-format
 msgid ""
 "This function handles 3D and the third dimension will affect the result."
-msgstr ""
+msgstr "该函数处理 3D,第三维将影响结果。"
 #. Tag: para
 #: reference_processing.xml:2303 reference_processing.xml:2360
@@ -2440,7 +2526,7 @@ msgstr "可用性:2.2.0"
 #: reference_processing.xml:2308
 #, no-c-format
 msgid "A LineString is simplified with a minimum area threshold of 30."
-msgstr ""
+msgstr "LineString 通过最小面积阈值 30 进行简化。"
 #. Tag: para
 #: reference_processing.xml:2313
@@ -2450,6 +2536,9 @@ msgid ""
 "linkend=\"ST_SimplifyPreserveTopology\"/>, Topology <xref "
 "linkend=\"TP_ST_Simplify\"/>"
 msgstr ""
+", <xref linkend=\"ST_Simplify\"/>, <xref linkend="
+"\"ST_SimplifyPreserveTopology\"/>, Topology <xref linkend=\"TP_ST_Simplify\""
 #. Tag: refpurpose
 #: reference_processing.xml:2320
@@ -2457,7 +2546,7 @@ msgstr ""
 msgid ""
 "Sets the effective area for each vertex, using the Visvalingam-Whyatt "
 "algorithm."
-msgstr ""
+msgstr "使用 Visvalingam-Whyatt 算法设置每个顶点的有效区域。"
 #: reference_processing.xml:2327
@@ -2479,6 +2568,9 @@ msgid ""
 "returned, containing only vertices with an effective area greater than or "
 "equal to the threshold value."
 msgstr ""
+"使用 Visvalingam-Whyatt 算法设置每个顶点的有效区域。 有效区域存储为顶点的 M "
+"值。 如果使用可选的“theshold”参数,则将返回简化的几何图形,仅包含有效区域大于"
+"或等于阈值的顶点。"
 #. Tag: para
 #: reference_processing.xml:2343
@@ -2489,6 +2581,9 @@ msgid ""
 "the full geometry will be returned with effective areas as M-values, which "
 "can be used by the client to simplify very quickly."
 msgstr ""
+"当指定阈值时,此函数可用于服务器端简化。 另一种选择是使用零阈值。 "
+"在这种情况下,将返回完整的几何图形,其中有效区域作为 M "
+"值,客户端可以使用它来快速简化。"
 #. Tag: para
 #: reference_processing.xml:2346
@@ -2499,12 +2594,15 @@ msgid ""
 "occurs on a object-by-object basis you can also feed a GeometryCollection to "
 "this function."
 msgstr ""
+"实际上只会对(多)线和(多)多边形执行某些操作,但您可以使用任何类型的几何体"
+"安全地调用它。 由于简化是在逐个对象的基础上进行的,因此您还可以将 "
+"GeometryCollection 提供给此函数。"
 #. Tag: para
 #: reference_processing.xml:2358
 #, no-c-format
 msgid "The output geometry will lose all previous information in the M-values"
-msgstr ""
+msgstr "输出几何图形将丢失 M 值中的所有先前信息"
 #. Tag: para
 #: reference_processing.xml:2359
@@ -2512,7 +2610,7 @@ msgstr ""
 msgid ""
 "This function handles 3D and the third dimension will affect the effective "
 "area"
-msgstr ""
+msgstr "此功能处理 3D,三维度会影响有效区域"
 #. Tag: para
 #: reference_processing.xml:2365
@@ -2520,13 +2618,14 @@ msgstr ""
 msgid ""
 "Calculating the effective area of a LineString. Because we use a threshold "
 "value of zero, all vertices in the input geometry are returned."
-msgstr ""
+msgstr "计算 LineString 的有效区域。 "
+"因为我们使用阈值为零,所以返回输入几何体中的所有顶点。"
 #. Tag: refpurpose
 #: reference_processing.xml:2379
 #, no-c-format
 msgid "Computes the constrained Delaunay triangulation of polygons"
-msgstr ""
+msgstr "计算多边形的约束 Delaunay 三角剖分"
 #: reference_processing.xml:2384
@@ -2542,7 +2641,7 @@ msgstr ""
 msgid ""
 "Computes the constrained Delaunay triangulation of polygons. Holes and "
 "Multipolygons are supported."
-msgstr ""
+msgstr "计算多边形的约束 Delaunay 三角剖分。 支持孔和多边形。"
 #. Tag: para
 #: reference_processing.xml:2396
@@ -2553,6 +2652,9 @@ msgid ""
 "with the maximum total interior angle over all possible triangulations. It "
 "provides the \"best quality\" triangulation of the polygon."
 msgstr ""
+"多边形的“约束 Delaunay 三角剖分”是由多边形的顶点形成的一组三角形,并精确地覆"
+"盖它,并且在所有可能的三角剖分上具有最大总内角。 "
+"它提供了多边形的“最佳质量”三角测量。"
 #. Tag: title
 #: reference_processing.xml:2406 reference_processing.xml:2411
@@ -2564,19 +2666,19 @@ msgstr "示例"
 #: reference_processing.xml:2407
 #, no-c-format
 msgid "Triangulation of a square."
-msgstr ""
+msgstr "正方形的三角剖分。"
 #. Tag: para
 #: reference_processing.xml:2412
 #, no-c-format
 msgid "Triangulation of the letter P."
-msgstr ""
+msgstr "字母 P 的三角剖分。"
 #. Tag: para
 #: reference_processing.xml:2419
 #, no-c-format
 msgid "Polygon Triangulation"
-msgstr ""
+msgstr "多边形三角剖分"
 #. Tag: para
 #: reference_processing.xml:2426
@@ -2585,13 +2687,15 @@ msgid ""
 ", <xref linkend=\"ST_ConstrainedDelaunayTriangles\"/>, <xref "
 "linkend=\"ST_Tesselate\"/>"
 msgstr ""
+", <xref linkend=\"ST_ConstrainedDelaunayTriangles\"/>, <xref linkend="
+"\"ST_Tesselate\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:2438
 #, no-c-format
 msgid ""
 "Returns the boundaries of the Voronoi diagram of the vertices of a geometry."
-msgstr ""
+msgstr "返回几何体顶点的 Voronoi 图的边界。"
 #: reference_processing.xml:2443
@@ -2616,12 +2720,17 @@ msgid ""
 "an empty geometry collection if the <varname>extend_to</varname> envelope "
 "has zero area."
 msgstr ""
+"根据提供的几何图形的顶点计算二维<ulink url=\"https://en.wikipedia.org/wiki/"
+"Voronoi_diagram\"> Voronoi 图</ulink>,并将图中单元格之间的边界作为 "
+"MultiLineString 返回。 如果输入几何图形为 null,则返回 null。 "
+"如果输入几何图形仅包含一个顶点,则返回一个空几何图形集合。 "
+"如果<varname>extend_to</varname>最小外接矩形的面积为零,则返回空几何集合。"
 #. Tag: para
 #: reference_processing.xml:2467 reference_processing.xml:2548
 #, no-c-format
 msgid "Optional parameters:"
-msgstr ""
+msgstr "可选参数:"
 #. Tag: para
 #: reference_processing.xml:2471 reference_processing.xml:2552
@@ -2630,7 +2739,8 @@ msgid ""
 "<varname>tolerance</varname>: The distance within which vertices will be "
 "considered equivalent. Robustness of the algorithm can be improved by "
 "supplying a nonzero tolerance distance. (default = 0.0)"
-msgstr ""
+msgstr "<varname>容差</varname>:顶点被视为相等的距离。 "
+"通过提供非零容差距离可以提高算法的稳健性。 (默认 = 0.0)"
 #. Tag: para
 #: reference_processing.xml:2474 reference_processing.xml:2555
@@ -2641,24 +2751,27 @@ msgid ""
 "envelope (default = NULL, default envelope is the bounding box of the input "
 "expanded by about 50%)."
 msgstr ""
+"<varname>extend_to</varname>:如果存在,图表将扩展以覆盖所提供几何图形的最小"
+"外接矩形,除非小于默认最小外接矩形(默认 = NULL,"
+"默认最小外接矩形是输入扩展约 50% 的边界框)。"
 #. Tag: para
 #: reference_processing.xml:2493
 #, no-c-format
 msgid "Voronoi diagram lines, with tolerance of 30 units"
-msgstr ""
+msgstr "Voronoi 图线,容差为 30 个单位"
 #. Tag: para
 #: reference_processing.xml:2505
 #, no-c-format
 msgid ", <xref linkend=\"ST_VoronoiPolygons\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_VoronoiPolygons\"/>"
 #. Tag: refpurpose
 #: reference_processing.xml:2516
 #, no-c-format
 msgid "Returns the cells of the Voronoi diagram of the vertices of a geometry."
-msgstr ""
+msgstr "返回几何体顶点的 Voronoi 图的单元格。"
 #: reference_processing.xml:2521
@@ -2683,21 +2796,27 @@ msgid ""
 "contains only one vertex. Returns an empty geometry collection if the "
 "<varname>extend_to</varname> envelope has zero area."
 msgstr ""
+"Voronoi_diagram\"> Voronoi 图</ulink>。 结果是 POLYGON 的 "
+"GEOMETRYCOLLECTION,其覆盖的包络大于输入顶点的范围。 如果输入几何图形为 "
+"null,则返回 null。 "
 #. Tag: para
 #: reference_processing.xml:2574
 #, no-c-format
 msgid "Points overlaid on top of Voronoi diagram"
-msgstr ""
+msgstr "覆盖在 Voronoi 图顶部的点"
 #. Tag: para
 #: reference_processing.xml:2585
 #, no-c-format
 msgid "Voronoi diagram, with tolerance of 30 units"
-msgstr ""
+msgstr "Voronoi 图,容差为 30 个单位"
 #. Tag: para
 #: reference_processing.xml:2597
 #, no-c-format
 msgid ", <xref linkend=\"ST_VoronoiLines\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_VoronoiLines\"/>"
Summary of changes:
 doc/po/zh_Hans/reference_coverage.xml.po       |  66 +++--
 doc/po/zh_Hans/reference_processing.xml.po     | 365 ++++++++++++++++---------
 doc/po/zh_Hans/reference_transformation.xml.po |  72 +++--
 3 files changed, 343 insertions(+), 160 deletions(-)
hooks/post-receive
