[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-373-g5c9afde94
Mon Sep 11 08:13:18 PDT 2023
the project "PostGIS".
       via  5c9afde9488981915cece512e5214e91ad55860c (commit)
      from  a61cb95c8acafdc58f6f8cb88794ba6f10e5402f (commit)
revisions in full, below.
commit 5c9afde9488981915cece512e5214e91ad55860c
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 11 16:32:14 2023 +0200
    Resolve XML entities only once
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 9642d2e65..d1b7560c0 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -226,8 +226,7 @@ TAG_GENERATED_SOURCES = \
 	Z_support.tag
 XML_GENERATED_SOURCES = \
-	$(XSL_GENERATED_SOURCES) \
-	postgis-out.xml \
+	$(XSL_GENERATED_SOURCES)
 XML_INPUTS = $(XML_SOURCES) $(XML_GENERATED_SOURCES) $(TAG_GENERATED_SOURCES)
@@ -292,9 +291,6 @@ update-po: $(XML_INPUTS_POT)
   done
 endif
-postgis-nospecial.xml: postgis-out.xml
-	grep -v '\&postgis_special;' $< > $@
 ifeq ($(XSLTPROC),)
 $(XSL_GENERATED_SOURCES): requirements_not_met_xsltproc
 else
@@ -317,9 +313,14 @@ $(GENERATED_COMMENT_FILES): %.sql: xsl/%.sql.xsl $(XML_INPUTS) postgis-out.xml
 $(GENERATED_CHEATSHEET_FILES): $(html_builddir)/%$(DOCSUFFIX).html: xsl/%.html.xsl $(XML_INPUTS) postgis-out.xml xsl/common_cheatsheet.xsl xsl/common_utils.xsl
 	$(XSLTPROC) --novalid $(XSLTPROC_PATH_OPT) $(XSLTPROC_CUSTOM_VARS) -o $@ $< postgis-out.xml
+postgis-nospecial.xml: postgis.xml $(XML_SOURCES) $(TAG_GENERATED_SOURCES) Makefile
+	grep -v '\&postgis_special;' $< > $@.in
+	$(XMLLINT) $(XSLTPROC_PATH_OPT) --noent -o $@ $@.in
 # TODO: use a postgis_release_version variable passed via --stringparam
-postgis-out.xml: postgis.xml Makefile
-	$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g;s'@@POSTGIS_DOWNLOAD_URL@@'${POSTGIS_DOWNLOAD_URL}'g;" $< > $@
+postgis-out.xml: postgis.xml Makefile $(XML_INPUTS) Makefile
+	$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g;s'@@POSTGIS_DOWNLOAD_URL@@'${POSTGIS_DOWNLOAD_URL}'g;" $< > $@.in
 chunked-html: $(html_builddir)/postgis$(DOCSUFFIX)/docbook.css
 $(html_builddir)/postgis$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile $(XML_INPUTS)
Summary of changes:
 doc/Makefile.in | 15 ++++++++-------
 1 file changed, 8 insertions(+), 7 deletions(-)
hooks/post-receive
