[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-406-geb027f6ee
Tue Sep 12 00:50:56 PDT 2023
the project "PostGIS".
       via  eb027f6eeb3bde6e5b5511fe5c2c730d6b9b4ab9 (commit)
      from  94922de5cacf6ea3adb85274e55eade713f05699 (commit)
revisions in full, below.
commit eb027f6eeb3bde6e5b5511fe5c2c730d6b9b4ab9
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Sep 12 09:49:45 2023 +0200
    Skip hitting network for cheatsheets and comments generation too
    References #2792
diff --git a/doc/Makefile.in b/doc/Makefile.in
index e85467ceb..22c757676 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -309,10 +309,10 @@ $(TAG_GENERATED_SOURCES): xsl/node_by_xpath.xsl xsl-config.xml | Makefile
 endif
 $(GENERATED_COMMENT_FILES): %.sql: xsl/%.sql.xsl postgis-out.xml
-	$(XSLTPROC) --novalid $(XSLTPROC_PATH_OPT) -o $@ $< postgis-out.xml
+	$(XSLTPROC) --novalid $(XSLTPROCFLAGS) $(XSLTPROC_PATH_OPT) -o $@ $< postgis-out.xml
 $(GENERATED_CHEATSHEET_FILES): $(html_builddir)/%$(DOCSUFFIX).html: xsl/%.html.xsl postgis-out.xml xsl/common_cheatsheet.xsl xsl/common_utils.xsl
-	$(XSLTPROC) --novalid $(XSLTPROC_PATH_OPT) $(XSLTPROC_CUSTOM_VARS) -o $@ $< postgis-out.xml
+	$(XSLTPROC) --novalid $(XSLTPROCFLAGS) $(XSLTPROC_PATH_OPT) $(XSLTPROC_CUSTOM_VARS) -o $@ $< postgis-out.xml
 postgis-nospecial.xml: postgis.xml $(XML_SOURCES) $(TAG_GENERATED_SOURCES) Makefile
 	grep -v '\&postgis_special;' $< > $@.in
Summary of changes:
 doc/Makefile.in | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
