[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-428-gdd114d7f1
Tue Sep 12 15:56:07 PDT 2023
the project "PostGIS".
       via  dd114d7f1635e5c50762ef5b688de9ae390b3a83 (commit)
      from  4316856455d1320256c46317040ed8bb30e03626 (commit)
revisions in full, below.
commit dd114d7f1635e5c50762ef5b688de9ae390b3a83
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 13 00:55:49 2023 +0200
    Fix de,fr and ko_KR check-xml
diff --git a/doc/po/de/installation.xml.po b/doc/po/de/installation.xml.po
index 80e23e8b6..976d51457 100644
--- a/doc/po/de/installation.xml.po
+++ b/doc/po/de/installation.xml.po
@@ -355,8 +355,8 @@ msgid ""
 "org/postgis/ticket/4125</link>."
 msgstr ""
 "Wenn mit PostgreSQL+JIT kompiliert wird, ist die LLVM-Version >=6 "
-"erforderlich <link url = \"https://trac.osgeo.org/postgis/ticket/4125\"> "
-"https://trac.osgeo.org/postgis/ticket/4125 </link>."
+"erforderlich <link xlink:href=\"https://trac.osgeo.org/postgis/ticket/4125\">"
+"https://trac.osgeo.org/postgis/ticket/4125</link>."
 #. Tag: emphasis
 #: installation.xml:217
diff --git a/doc/po/fr/reference_accessor.xml.po b/doc/po/fr/reference_accessor.xml.po
index 6f8c9b2e0..d43ba135e 100644
--- a/doc/po/fr/reference_accessor.xml.po
+++ b/doc/po/fr/reference_accessor.xml.po
@@ -1490,9 +1490,9 @@ msgid ""
 "SQL-MM defines the result of ST_IsSimple(NULL) to be 0, while PostGIS "
 "returns NULL."
 msgstr ""
-"La norme SQL-MM indique que le résultat de la fonction <function> "
-"ST_IsSimple(<varname>NULL</varname>)</function> doit être 0 ; PostGIS "
-"renvoie <varname>NULL</varname>."
+"La norme SQL-MM indique que le résultat de la fonction "
+"ST_IsSimple(NULL) doit être 0 ; PostGIS "
+"renvoie NULL."
 #. Tag: para
 #: reference_accessor.xml:1327
diff --git a/doc/po/ko_KR/reference_accessor.xml.po b/doc/po/ko_KR/reference_accessor.xml.po
index 56b32fd81..f0fc70f4e 100644
--- a/doc/po/ko_KR/reference_accessor.xml.po
+++ b/doc/po/ko_KR/reference_accessor.xml.po
@@ -1220,8 +1220,8 @@ msgid ""
 "SQL-MM defines the result of ST_IsEmpty(NULL) to be 0, while PostGIS returns "
 "NULL."
 msgstr ""
-"SQL-MM은 <function>ST_IsEmpty(<varname>NULL</varname>)</function> 의 결과를 0"
-"으로 정의하지만, PostGIS는 <varname>NULL</varname> 을 반환합니다."
+"SQL-MM은 ST_IsEmpty(NULL) 의 결과를 0"
+"으로 정의하지만, PostGIS는 NULL 을 반환합니다."
 #. Tag: para
 #: reference_accessor.xml:1094
@@ -1385,8 +1385,8 @@ msgid ""
 "returns NULL."
 msgstr ""
-"SQL-MM은 <function>ST_IsSimple(<varname>NULL</varname>)</function> 의 결과를 "
-"0으로 정의하지만, PostGIS는 <varname>NULL</varname> 을 반환합니다."
+"SQL-MM은 ST_IsSimple(NULL) 의 결과를 "
+"0으로 정의하지만, PostGIS는 NULL 을 반환합니다."
 #. Tag: para
Summary of changes:
 doc/po/de/installation.xml.po          | 4 ++--
 doc/po/fr/reference_accessor.xml.po    | 6 +++---
 doc/po/ko_KR/reference_accessor.xml.po | 8 ++++----
 3 files changed, 9 insertions(+), 9 deletions(-)
hooks/post-receive
