[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-532-g3ded186d2
Thu Sep 14 00:58:55 PDT 2023
the project "PostGIS".
       via  3ded186d20be98492f7e0be75cb73a1ca9289ce0 (commit)
      from  a9559257be3d1f7eb8497228af06d9b774d16846 (commit)
revisions in full, below.
commit 3ded186d20be98492f7e0be75cb73a1ca9289ce0
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Sep 14 09:58:41 2023 +0200
    [cirrus-ci] Add docbook and docbook-xsl to macos build
diff --git a/.cirrus.yml b/.cirrus.yml
index c8dcdc7b7..9aa5cf4a1 100644
--- a/.cirrus.yml
+++ b/.cirrus.yml
@@ -64,7 +64,23 @@ task:
   alias: test-macos
   test_script:
     - brew update
-    - brew install autoconf automake libtool gpp pkg-config gdal geos json-c pcre2 postgresql at 14 proj protobuf-c sfcgal cunit
+    - brew install
+        autoconf
+        automake
+        cunit
+        docbook
+        docbook-xsl
+        gdal
+        geos
+        gpp
+        json-c
+        libtool
+        pcre2
+        pkg-config
+        postgresql at 14
+        proj
+        protobuf-c
+        sfcgal
     - ./autogen.sh
     - ./configure --without-gui --without-interrupt-tests --without-topology --without-raster  --with-sfcgal --with-address-standardizer --with-protobuf --with-pgconfig=/opt/homebrew/opt/postgresql at 14/bin/pg_config
     - brew services start postgresql at 14
Summary of changes:
 .cirrus.yml | 18 +++++++++++++++++-
 1 file changed, 17 insertions(+), 1 deletion(-)
hooks/post-receive
