[postgis-tickets] [PostGIS] #5538: Drop -with-xsldir configure switch support (now unused)
PostGIS trac at osgeo.org
Thu Sep 14 02:28:00 PDT 2023
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.5.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 Some builders MIGHT be using it, like Winnie is (see #5537)
 The new way to deal with XML is XML catalogs and xsltproc will honour a
 XML_CATALOG_FILES environment variable to point to custom catalogs (by
 default /etc/xml/catalog is used)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5538>
