[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-533-g76359c68d
Thu Sep 14 02:51:20 PDT 2023
the project "PostGIS".
       via  76359c68d2e213002861d7914d2db62ff5dad922 (commit)
      from  3ded186d20be98492f7e0be75cb73a1ca9289ce0 (commit)
revisions in full, below.
commit 76359c68d2e213002861d7914d2db62ff5dad922
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Sep 14 11:49:28 2023 +0200
    Encode xmllint requirement for postgis-out and postgis-nospecial xml
    The new requirement was created by 5c9afde94
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 0eec2aed2..352864db5 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -323,6 +323,11 @@ postgis-out.xml: postgis.xml Makefile $(XML_INPUTS) Makefile
 	$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g;s'@@POSTGIS_DOWNLOAD_URL@@'${POSTGIS_DOWNLOAD_URL}'g;" $< > $@.in
 	$(XMLLINT) $(XSLTPROC_PATH_OPT) --noent -o $@ $@.in
+ifeq ($(XMLLINT),)
+postgis-nospecial.xml: requirements_not_met_xmllint
+postgis-out.xml: requirements_not_met_xmllint
+endif
 chunked-html: $(html_builddir)/postgis$(DOCSUFFIX)/docbook.css
 $(html_builddir)/postgis$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile
 	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
@@ -610,11 +615,8 @@ requirements_not_met_xsltproc:
 requirements_not_met_xmllint:
 	@echo
 	@echo "configure was unable to find 'xmllint' which is required"
-	@echo "to build the documentation."
-	@echo "Install xmllint and then re-run configure. Alternatively "
-	@echo "refer to online manual:"
-	@echo
-	@echo "  http://postgis.net/documentation"
+	@echo "to build the postgis comments and documentation."
+	@echo "Install xmllint and then re-run configure."
 	@echo
 	@false
Summary of changes:
 doc/Makefile.in | 12 +++++++-----
 1 file changed, 7 insertions(+), 5 deletions(-)
hooks/post-receive
