[postgis-tickets] [PostGIS] #5537: Winnie is attempting to use --with-xsldir which is currently not used anymore
PostGIS trac at osgeo.org
Thu Sep 14 08:32:35 PDT 2023
anymore
  Reporter:  strk       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.5.0
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:  winnie
Comment (by robe):
 strk so I removed the reference to xsl-dir on my local, and still end with
 this error:
 make[1]: Entering directory '/projects/postgis/postgis-git/utils'
 comm -12 postgis_restore_data.hardcoded postgis_restore_data.generated >
 postgis_restore_data.needlessly-hardcoded
 make[1]: Leaving directory '/projects/postgis/postgis-git/utils'
 ---- Making check-unit in doc
 make[1]: Entering directory '/projects/postgis/postgis-git/doc'
 # Fail early if cannot find required RelaxNG
 xmlcatalog "" "http://docbook.org/xml/5.0/rng/docbook.rng"
 No entry for SYSTEM http://docbook.org/xml/5.0/rng/docbook.rng
 No entry for URI http://docbook.org/xml/5.0/rng/docbook.rng
 make[1]: *** [Makefile:585: check-xml] Error 4
 make[1]: Leaving directory '/projects/postgis/postgis-git/doc'
 make: *** [GNUmakefile:25: check-unit] Error 1
 How can I turn off any kind of doc building? I just want to turn it off.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5537#comment:4>
