[postgis-tickets] [PostGIS] #5537: Winnie is attempting to use --with-xsldir which is currently not used anymore
PostGIS trac at osgeo.org
Thu Sep 14 13:47:56 PDT 2023
anymore
  Reporter:  strk       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS 3.5.0
 Component:  buildbots  |    Version:  master
Resolution:  fixed      |   Keywords:  winnie
Comment (by robe):
 Okay I think I got my system locally working again and copied the same
 files to winnie.  Hopefully that fixes things.
 To fix I downloaded - https://docbook.org/xml/5.0.1/docbook-5.0.1.zip
 extracted into my /projects/docbook folder
 then in winnie's common scripts defined
 export XML_CATALOG_FILES="/projects/docbook/docbook-5.0.1/catalog.xml"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5537#comment:6>
