[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-551-g119b6e4bf
Thu Sep 14 13:48:32 PDT 2023
the project "PostGIS".
       via  119b6e4bf0f5b48c37ca978a69ffab1c3c60001b (commit)
      from  0027ccc8973427ba2d7188c9cd193b0f2e1bfb66 (commit)
revisions in full, below.
commit 119b6e4bf0f5b48c37ca978a69ffab1c3c60001b
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Sep 14 22:32:40 2023 +0200
    Go back to find docbook XSL at configure time
    This reverts commit b6583e98323ffe1a8438b51f3a9c70205fdbcf6b
    bringing --with-xsldir support back.
    Closes #5538 #5539
    References #5537
diff --git a/configure.ac b/configure.ac
index f4b0a34e9..2af8f28d7 100644
--- a/configure.ac
+++ b/configure.ac
@@ -266,6 +266,87 @@ if test "x$XMLLINT" = "x"; then
 	AC_MSG_WARN([xmllint is not installed so documentation cannot be checked])
 fi
+dnl
+dnl Allow the user to specify the location of the html/docbook.xsl stylesheet
+dnl
+AC_ARG_WITH([xsldir],
+	[AS_HELP_STRING([--with-xsldir=PATH], [specify the directory containing the docbook.xsl stylesheet])],
+	[XSLBASE="$withval"], [XSLBASE=""])
+XSLBASE_AUTO=""
+if test "x$XSLBASE" = "x"; then
+	dnl If the user did not specify a directory for the docbook
+	dnl stylesheet, choose the first uri that can resolve
+  dnl html/docbook.xsl or the first directory
+	dnl that matches from the following list
+	SEARCHPATH="
+    http://cdn.docbook.org/release/xsl/current
+    http://docbook.sourceforge.net/release/xsl-ns
+		/usr/share/sgml/docbook/xsl-stylesheets
+		/usr/share/xml/docbook/stylesheet/docbook-xsl-ns
+		/usr/share/xml/docbook/stylesheet/nwalsh
+		/usr/share/sgml/docbook/stylesheet/xsl/nwalsh
+		/opt/local/share/xsl/docbook-xsl
+		/usr/local/opt/docbook-xsl/docbook-xsl
+		/usr/local/share/xsl/docbook-xsl
+		/usr/share/xsl/docbook-xsl
+	for p in ${SEARCHPATH}; do
+    if expr "${p}" : / >/dev/null; then
+      AC_MSG_CHECKING([for html/docbook.xsl in directory $p...])
+      if test -r "${p}"/html/docbook.xsl; then
+        XSLBASE_AUTO="${p}"
+        AC_MSG_RESULT([found])
+        break
+      fi
+      AC_MSG_RESULT([not found])
+    elif test "x$XMLCATALOG" != "x"; then
+      AC_MSG_CHECKING([for html/docbook.xsl in URI $p...])
+      if $XMLCATALOG '' "${p}/html/docbook.xsl" >/dev/null; then
+        break
+      fi
+    fi
+	done
+	dnl Check to see if the automatically searched paths above located a
+	dnl valid Docbook stylesheet
+	if test "x$XSLBASE_AUTO" = "x"; then
+		AC_MSG_WARN([could not locate Docbook stylesheets required to build the documentation])
+	fi
+else
+	dnl The user specified an alternate directory so make sure everything
+	dnl looks sensible
+	if test ! -d "$XSLBASE"; then
+		AC_MSG_ERROR([the docbook stylesheet directory specified using --with-xsldir does not exist])
+	fi
+	if test ! -f "$XSLBASE/html/docbook.xsl"; then
+		AC_MSG_ERROR([the docbook stylesheet directory specified using --with-xsldir does not contain the html/docbook.xsl file])
+	fi
+fi
+dnl
+dnl If XSLBASE has been set then at this point we know it must be
+dnl valid and so we can just use it. If XSLBASE_AUTO has been set, and XSLBASE
+dnl is empty then a valid stylesheet was found in XSLBASE_AUTO so we
+dnl should use that. Otherwise just continue silently with a blank XSLBASE
+dnl variable which will trigger the error message in the documentation Makefile
+dnl
+	if test ! "x$XSLBASE_AUTO" = "x"; then
+		XSLBASE="$XSLBASE_AUTO"
+	fi
+fi
+AC_SUBST([XSLBASE])
 dnl ===========================================================================
 dnl Detect if pkg-config installed
@@ -1817,6 +1898,7 @@ fi
 AC_MSG_RESULT()
 AC_MSG_RESULT([ -------- Documentation Generation -------- ])
 AC_MSG_RESULT([  xsltproc:             ${XSLTPROC}])
+AC_MSG_RESULT([  docbook xsl base:     ${XSLBASE}])
 AC_MSG_RESULT([  dblatex:              ${DBLATEX}])
 AC_MSG_RESULT([  convert:              ${CONVERT}])
 AC_MSG_RESULT()
diff --git a/doc/Makefile.in b/doc/Makefile.in
index eaf8576f7..2577683ce 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -60,6 +60,7 @@ INSTALL=@INSTALL@
 INSTALL_DATA=@INSTALL_DATA@
 XSLTPROC=@XSLTPROC@
+XSLBASE=@XSLBASE@
 CAN_UPDATE_TRANSLATIONS=@CAN_UPDATE_TRANSLATIONS@
 XMLLINT=@XMLLINT@
 CAN_BUILD_COMMENTS=@CAN_BUILD_COMMENTS@
@@ -111,12 +112,8 @@ XSLTPROC_CHUNKED_HTML_OPTS = \
 	--stringparam img.src.path ../ \
 	--stringparam html.stylesheet ../style.css
-# FIXME: the official URI would be http://cdn.docbook.org/release/xsl/current/
-# but see https://trac.osgeo.org/postgis/ticket/5539
-#DOCBOOK_XSLBASE=http://cdn.docbook.org/release/xsl/current
-DOCBOOK_XSLBASE=http://docbook.sourceforge.net/release/xsl-ns
-HTML_DOCBOOK_XSL=$(DOCBOOK_XSLBASE)/html/docbook.xsl
-CHUNK_HTML_DOCBOOK_XSL=$(DOCBOOK_XSLBASE)/html/chunk.xsl
+HTML_DOCBOOK_XSL=$(XSLBASE)/html/docbook.xsl
+CHUNK_HTML_DOCBOOK_XSL=$(XSLBASE)/html/chunk.xsl
 # DBLatex's dblatex script for PDF generation from DocBook
 DBLATEX=@DBLATEX@
Summary of changes:
 configure.ac    | 82 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++
 doc/Makefile.in |  9 +++----
 2 files changed, 85 insertions(+), 6 deletions(-)
hooks/post-receive
