[postgis-tickets] [PostGIS] #5540: berries can't generate garden tests
PostGIS trac at osgeo.org
Thu Sep 14 21:44:47 PDT 2023
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.5.0
Component:  buildbots  |    Version:  master
 Keywords:             |
 Berries failing on trying to run garden test with this:
 00:14:47 make[1]: Entering directory
 '/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie/3a4b92978a0abcc6683a7342a6efdfc7befd2967/doc'
 00:14:47 /usr/bin/xsltproc -o postgis_gardentest_35.sql --path
 .:/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie/3a4b92978a0abcc6683a7342a6efdfc7befd2967/doc
 xsl/postgis_gardentest.sql.xsl postgis-out.xml
 00:14:47 XPath error : Undefined namespace prefix
 00:14:47 runtime error: file xsl/postgis_gardentest.sql.xsl line 330
 element apply-templates
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5540>
