[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-571-gd7b58458e
Sat Sep 16 06:32:57 PDT 2023
the project "PostGIS".
       via  d7b58458ea7cf8157d09f59e955820d3a4321892 (commit)
       via  9e6289183ad6c79cc8bf0fd7c84a8bf9364c52c6 (commit)
      from  d692cc82e27a9b7865cc6e81eb2837fcae67289a (commit)
revisions in full, below.
commit d7b58458ea7cf8157d09f59e955820d3a4321892
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Sep 16 09:31:56 2023 -0400
    New Proj variables only available in 7.1+ and not 7.0+
    References #5482 for PostGIS 3.5.0
diff --git a/postgis/lwgeom_transform.c b/postgis/lwgeom_transform.c
index bb43b319f..0cd801ccc 100644
--- a/postgis/lwgeom_transform.c
+++ b/postgis/lwgeom_transform.c
@@ -212,7 +212,7 @@ Datum postgis_proj_version(PG_FUNCTION_ARGS)
 	stringbuffer_append(&sb, pji.version);
 #endif
-#if POSTGIS_PROJ_VERSION >= 70
+#if POSTGIS_PROJ_VERSION >= 71
 	stringbuffer_aprintf(&sb,
 		" NETWORK_ENABLED=%s",
commit 9e6289183ad6c79cc8bf0fd7c84a8bf9364c52c6
Date:   Sat Sep 16 09:31:20 2023 -0400
    Get rid of more duplicate stuff on winnie's config
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index f12746421..3b09f986e 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -115,7 +115,7 @@ export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}ed
 export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
 export PATH="${PGPATH}/bin:${PGPATH}/lib:${PATH}"
-export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJ_PATH}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJ_PATH}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJ_PATH}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
 export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
 CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
Summary of changes:
 ci/winnie/winnie_common.sh | 2 +-
 postgis/lwgeom_transform.c | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
