[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-572-gea76f5eab
Sat Sep 16 19:23:43 PDT 2023
the project "PostGIS".
       via  ea76f5eabe77a5bd494ca8d8022316a2d15d462a (commit)
      from  d7b58458ea7cf8157d09f59e955820d3a4321892 (commit)
revisions in full, below.
commit ea76f5eabe77a5bd494ca8d8022316a2d15d462a
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Sep 17 00:55:59 2023 +0000
    Translated PostGIS Manual using Weblate (Italian)
    Currently translated at 21.9% (1266 of 5771 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/it/
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index 88c1247f9..ce5ffa20a 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-09-14 17:40+0000\n"
-"PO-Revision-Date: 2023-09-15 22:23+0000\n"
+"PO-Revision-Date: 2023-09-17 02:23+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/it/>\n"
@@ -12747,6 +12747,9 @@ msgid ""
 "buffering expands a geometry in all directions, ST_Expand expands the "
 "bounding box along each axis."
 msgstr ""
+"ST_Expand è simile a <xref linkend=\"ST_Buffer\"/>, solo che mentre il "
+"buffering espande una geometria in tutte le direzioni, ST_Expand espande il "
+"rettangolo di selezione lungo ogni asse."
 #. Tag: para
 #, no-c-format
@@ -12757,6 +12760,11 @@ msgid ""
 "20)') < 10</code>. This has been replaced by the simpler and more "
 "efficient <xref linkend=\"ST_DWithin\"/> function."
 msgstr ""
+"Prima della versione 1.3, ST_Expand veniva utilizzato insieme a <xref "
+"linkend=\"ST_Distance\"/> per eseguire query di distanza indicizzabili. Ad "
+"esempio, <code>geom && ST_Expand('POINT(10 20)', 10) AND ST_Distance("
+"geom, 'POINT(10 20)') < 10</code>. Questa funzione è stata sostituita "
+"dalla più semplice ed efficiente <xref linkend=\"ST_DWithin\"/>."
 #. Tag: para
 #, no-c-format
@@ -12764,6 +12772,8 @@ msgid ""
 "Availability: 1.5.0 behavior changed to output double precision instead of "
 "float4 coordinates."
 msgstr ""
+"Disponibilità: 1.5.0 il comportamento è stato modificato per produrre "
+"coordinate a doppia precisione anziché float4."
 #. Tag: para
 #, no-c-format
@@ -12782,12 +12792,14 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"ST_DWithin\"/>, <xref linkend=\"ST_SRID\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_DWithin\"/>, <xref linkend=\"ST_SRID\"/>"
 #. Tag: refpurpose
 #, no-c-format
 msgid "Aggregate function that returns the bounding box of geometries."
 msgstr ""
+"Funzione aggregata che restituisce il rettangolo di selezione delle "
+"geometrie."
 #. Tag: para
 #, no-c-format
@@ -12795,6 +12807,8 @@ msgid ""
 "An aggregate function that returns a <xref linkend=\"box2d_type\"/> bounding "
 "box that bounds a set of geometries."
 msgstr ""
+"Una funzione aggregata che restituisce un rettangolo di selezione <xref "
+"linkend=\"box2d_type\"/> che delimita un insieme di geometrie."
 #. Tag: para
 #, no-c-format
@@ -12802,12 +12816,15 @@ msgid ""
 "The bounding box coordinates are in the spatial reference system of the "
 "input geometries."
 msgstr ""
+"Le coordinate del rettangolo di selezione sono nel sistema di riferimento "
+"spaziale delle geometrie in ingresso."
 #. Tag: para
 #, no-c-format
 msgid ""
 "ST_Extent is similar in concept to Oracle Spatial/Locator's SDO_AGGR_MBR."
 msgstr ""
+"ST_Extent è simile nel concetto a SDO_AGGR_MBR di Oracle Spatial/Locator."
 #. Tag: para
 #, no-c-format
@@ -12815,6 +12832,9 @@ msgid ""
 "ST_Extent returns boxes with only X and Y ordinates even with 3D geometries. "
 "To return XYZ ordinates use <xref linkend=\"ST_3DExtent\"/>."
 msgstr ""
+"ST_Extent restituisce rettangoli con le sole ordinate X e Y anche con le "
+"geometrie 3D. Per restituire le ordinate XYZ, utilizzare <xref linkend="
+"\"ST_3DExtent\"/>."
 #. Tag: para
 #, no-c-format
@@ -12823,6 +12843,9 @@ msgid ""
 "linkend=\"ST_SetSRID\"/> to convert it into a geometry with SRID metadata. "
 "The SRID is the same as the input geometries."
 msgstr ""
+"Il valore <code>box3d</code> restituito non include un SRID. Utilizzare "
+"<xref linkend=\"ST_SetSRID\"/> per convertirlo in una geometria con metadati "
+"SRID. Il SRID è lo stesso delle geometrie di input."
 #. Tag: para
 #, no-c-format
@@ -12832,12 +12855,14 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"ST_3DExtent\"/>, <xref linkend=\"ST_SetSRID\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_3DExtent\"/>, <xref linkend=\"ST_SetSRID\"/>"
 #. Tag: refpurpose
 #, no-c-format
 msgid "Aggregate function that returns the 3D bounding box of geometries."
 msgstr ""
+"Funzione aggregata che restituisce il rettangolo di selezione 3D delle "
+"geometrie."
 #. Tag: para
 #, no-c-format
@@ -12845,21 +12870,26 @@ msgid ""
 "An aggregate function that returns a <xref linkend=\"box3d_type\"/> "
 "(includes Z ordinate) bounding box that bounds a set of geometries."
 msgstr ""
+"linkend=\"box3d_type\"/> (include l'ordinata Z) che delimita un insieme di "
+"geometrie."
 #. Tag: para
 #, no-c-format
 msgid "Changed: 2.0.0 In prior versions this used to be called ST_Extent3D"
 msgstr ""
+"Modificato nella versione 2.0.0. Nelle versioni precedenti era chiamato "
+"ST_Extent3D"
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"ST_Force_3DZ\"/>, <xref linkend=\"ST_SetSRID\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_Force_3DZ\"/>, <xref linkend=\"ST_SetSRID\"/>"
 #. Tag: refpurpose
 #, no-c-format
 msgid "Creates a BOX2D defined by two 2D point geometries."
-msgstr ""
+msgstr "Crea un BOX2D definito da due geometrie di punti 2D."
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/it_IT/postgis-manual.po | 40 +++++++++++++++++++++++++++++++++++-----
 1 file changed, 35 insertions(+), 5 deletions(-)
hooks/post-receive
