[postgis-tickets] [PostGIS] #5542: ../../doc/postgis_comments.sql: No such file or directory
PostGIS trac at osgeo.org
Sun Sep 17 00:03:01 PDT 2023
  Reporter:  ImreSamu               |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.5.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:  docbook5 docker-postgis
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"644797a9ea72e4db0c8768b96fe1affd97252baf/git"
 644797a9/git]:
 {{{#!CommitTicketReference repository="git"
 revision="644797a9ea72e4db0c8768b96fe1affd97252baf"
 Do not check documentation on `make check` if deps are not met
 References #5536 #5542
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5542#comment:7>
