[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-575-gbfaab7641
Sun Sep 17 00:41:30 PDT 2023
the project "PostGIS".
       via  bfaab7641d9591bcc21e436d012fd2e79f9d25d7 (commit)
      from  644797a9ea72e4db0c8768b96fe1affd97252baf (commit)
revisions in full, below.
commit bfaab7641d9591bcc21e436d012fd2e79f9d25d7
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Sep 17 09:41:07 2023 +0200
    Check for xml checking validation deps at configure time
    References #5536 #5542
diff --git a/configure.ac b/configure.ac
index 7f82a6cc8..9b8922a8f 100644
--- a/configure.ac
+++ b/configure.ac
@@ -361,6 +361,32 @@ fi
 AC_SUBST([XSLBASE])
+dnl
+dnl Ensure DocBook RelaxNG can be found
+dnl
+DOCBOOK5_RNG=http://docbook.org/xml/5.0/rng/docbook.rng
+if test "x$XMLCATALOG" = "x"; then
+  DOCBOOK5_RNG=
+else
+  if $XMLCATALOG '' "${DOCBOOK5_RNG}" > /dev/null; then :
+  else DOCBOOK5_RNG=
+  fi
+fi
+AC_SUBST([DOCBOOK5_RNG])
+dnl
+dnl Ensure DocBook DTD can be found
+dnl
+DOCBOOK5_DTD=http://docbook.org/xml/5.0/rng/docbook.dtd
+  DOCBOOK5_DTD=
+else
+  if $XMLCATALOG '' "${DOCBOOK5_DTD}" > /dev/null; then :
+  else DOCBOOK5_DTD=
+  fi
+fi
+AC_SUBST([DOCBOOK5_DTD])
 dnl ===========================================================================
 dnl Detect if pkg-config installed
diff --git a/doc/Makefile.in b/doc/Makefile.in
index b5becf14e..51cc5ac1a 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -62,6 +62,8 @@ INSTALL_DATA=@INSTALL_DATA@
 XMLCATALOG=@XMLCATALOG@
 XSLTPROC=@XSLTPROC@
 XSLBASE=@XSLBASE@
+DOCBOOK5_RNG=@DOCBOOK5_RNG@
+DOCBOOK5_DTD=@DOCBOOK5_DTD@
 CAN_UPDATE_TRANSLATIONS=@CAN_UPDATE_TRANSLATIONS@
 XMLLINT=@XMLLINT@
 CAN_BUILD_COMMENTS=@CAN_BUILD_COMMENTS@
@@ -274,6 +276,14 @@ check-xml: requirements_not_met_xmlcatalog
 CAN_CHECK_XML = no
 endif
+ifeq ($(DOCBOOK5_RNG),)
+CAN_CHECK_XML = no
+endif
+ifeq ($(DOCBOOK5_DTD),)
+CAN_CHECK_XML = no
+endif
 ifeq ($(MSGMERGE),)
 $(PO_FILES): requirements_not_met_msgmerge
 endif
@@ -630,15 +640,11 @@ check-regress:
 check-unit: $(CHECK_UNIT_TARGET)
 check-xml: postgis-out.xml
-	# Fail early if cannot find required RelaxNG
-	$(XMLCATALOG) "" "http://docbook.org/xml/5.0/rng/docbook.rng"
-	# Fail early if cannot find required DTD
-	$(XMLCATALOG) "" "http://docbook.org/xml/5.0/dtd/docbook.dtd"
 	# TODO: --schematron http://docbook.org/xml/5.0/sch/docbook.sch
 	# See https://trac.osgeo.org/postgis/ticket/5532
 	$(XMLLINT) --noout --nonet \
 		--valid --loaddtd \
-		--relaxng http://docbook.org/xml/5.0/rng/docbook.rng \
+		--relaxng $(DOCBOOK5_RNG) \
 check-cheatsheets: cheatsheets
Summary of changes:
 configure.ac    | 26 ++++++++++++++++++++++++++
 doc/Makefile.in | 16 +++++++++++-----
 2 files changed, 37 insertions(+), 5 deletions(-)
hooks/post-receive
