[postgis-tickets] [PostGIS] #5536: Stop shipping comments with the extensions (was: Stop shipping comments with the extension build - don't require docbook anything to regress)
trac at osgeo.org
Mon Sep 18 03:07:56 PDT 2023
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.5.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Changes (by strk):
* summary:
=> Stop shipping comments with the extensions
Comment:
Just to clarify: after the recent changes (
[644797a9ea72e4db0c8768b96fe1affd97252baf/git] ) the "regress" dependency
difference from 3.4 is only the need of "xmllint" which was added as a
dependency to build those comments. Docbook5 xml is not needed because
comments are using XSL files included in the PostGIS source tree, so only
the xsltproc processor was required in 3.4 and now we added xmllint to
that dependency.
For this reason I changed the ticket title to just focus on dropping the
inclusion of comments from the extensions, as this is not strictly tight
with regression testing.
For reference, the (passed) PSC motion to drop comments from extensions is
here:
https://lists.osgeo.org/pipermail/postgis-devel/2023-September/030115.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5536#comment:5>
