[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-578-g93a9e00c4
Mon Sep 18 12:10:19 PDT 2023
the project "PostGIS".
       via  93a9e00c4dac2841a3a2dabe93aee97628e08657 (commit)
       via  c7f249f4a03923ebe8f56b72f41449a13df6c1b4 (commit)
      from  d596b5a06616ae913e1de0ac355f2500b4cc69bf (commit)
revisions in full, below.
commit 93a9e00c4dac2841a3a2dabe93aee97628e08657
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 18 20:33:01 2023 +0200
    Stop including comments in extensions
    Closes #5536
    Includes mention in the NEWS file
diff --git a/NEWS b/NEWS
index 0e6695379..c86ee3c7e 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,7 @@ xxxx/xx/xx
 * Breaking Changes *
+  - #5536, comments are not anymore included in PostGIS extensions
   - xmllint is now required to build comments and documentation
   - DocBook5 XSL is now required to build html documentation
diff --git a/extensions/README b/extensions/README
index cd1384903..7f941b69d 100644
--- a/extensions/README
+++ b/extensions/README
@@ -19,15 +19,6 @@ completing these steps::
   make
   make install
-If you are building from the source SVN repository, it is also recommended to
-make the comments, since the function descriptions will be included::
-  make comments
-Making the comments is not necessary if you are building from the tar.gz source
-distributions, since these include pre-built ``postgis_comments.sql``,
-``topology_comments.sql``, and ``raster_comments.sql`` files.
 Then, to build and install the extensions::
   cd extensions
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 799fdf925..972dc3e8a 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -41,7 +41,6 @@ DATA_built = \
 # NOTE: order matters
 EXTENSION_SCRIPTS = \
 	sql/postgis_for_extension.sql \
-	../../doc/postgis_comments.sql \
 	sql/spatial_ref_sys_config_dump.sql \
 	sql/spatial_ref_sys.sql
@@ -51,7 +50,6 @@ EXTENSION_UPGRADE_SCRIPTS = \
 	../postgis_extension_helper.sql \
 	sql/raster_unpackage.sql \
 	sql/postgis_upgrade.sql \
 	sql/spatial_ref_sys.sql \
 	../postgis_extension_helper_uninstall.sql
@@ -110,9 +108,6 @@ sql:
 sql/spatial_ref_sys.sql: ../../spatial_ref_sys.sql | sql
 	$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
-../../doc/postgis_comments.sql:
-	$(MAKE) -C ../../doc comments
 sql/spatial_ref_sys_config_dump.sql: ../../spatial_ref_sys.sql ../../utils/create_spatial_ref_sys_config_dump.pl | sql
 	$(PERL) @top_srcdir@/utils/create_spatial_ref_sys_config_dump.pl $< > $@
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index 4a2af9502..be4d08df0 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -39,15 +39,13 @@ DATA_built = \
 # Scripts making up the extension file
-	sql/rtpostgis.sql \
-	sql/raster_comments.sql
+	sql/rtpostgis.sql
 # Scripts making up the extension minor upgrade file
 	sql/rtpostgis_upgrade.sql \
-	../../doc/raster_comments.sql \
 # Scripts making up the extension upgrade-from-unpackaged file
@@ -112,12 +110,6 @@ sql/rtpostgis_upgrade_for_extension.sql.in: sql/rtpostgis_for_extension.sql ../.
 	$(PERL) @top_srcdir@/utils/create_upgrade.pl $< > $@
-../../doc/raster_comments.sql:
-sql/raster_comments.sql: ../../doc/raster_comments.sql | sql
-	cp $< $@
 sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS) | sql
 	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
 	cat $^ >> $@
diff --git a/extensions/postgis_sfcgal/Makefile.in b/extensions/postgis_sfcgal/Makefile.in
index 28f00a99c..3480dcb39 100644
--- a/extensions/postgis_sfcgal/Makefile.in
+++ b/extensions/postgis_sfcgal/Makefile.in
@@ -42,8 +42,7 @@ EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS = \
-	sql/sfcgal.sql \
-	sql/sfcgal_comments.sql
+	sql/sfcgal.sql
 EXTRA_CLEAN = sql
@@ -65,12 +64,6 @@ sql/$(EXTENSION)--$(EXTVERSION).sql: $(EXTENSION_SCRIPTS) | sql
 sql/sfcgal.sql: ../../sfcgal/sfcgal.sql | sql
-../../doc/sfcgal_comments.sql:
-sql/sfcgal_comments.sql: ../../doc/sfcgal_comments.sql | sql
-	cp $< $@
 sql/$(EXTENSION)--unpackaged.sql: Makefile | sql
 	echo "-- Nothing to do here" > $@
@@ -87,7 +80,7 @@ sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql/sfcgal.sql sql/$(EXTENSION)
 sql/sfcgal_upgrade.sql : ../../sfcgal/sfcgal_upgrade.sql | sql
-sql/sfcgal_upgrade_minor.sql: ../postgis_extension_helper.sql sql/sfcgal_upgrade.sql ../../doc/sfcgal_comments.sql ../postgis_extension_helper_uninstall.sql | sql
+sql/sfcgal_upgrade_minor.sql: ../postgis_extension_helper.sql sql/sfcgal_upgrade.sql ../postgis_extension_helper_uninstall.sql | sql
 	cat $^ >> $@
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 516b52882..5beff997e 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -77,7 +77,7 @@ expected/test-upgrade.out: sql/test-upgrade.sql | expected
 sql/test-pagc_normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/pagc_normalize_address_regress.sql | sql
 	cat $^ > $@
-sql/$(EXTENSION)_pre.sql: sql/tiger_geocoder.sql  sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql | sql
+sql/$(EXTENSION)_pre.sql: sql/tiger_geocoder.sql  sql_bits/mark_editable_objects.sql.in | sql
 	cat $^ > $@
 sql/$(EXTENSION).sql: sql/$(EXTENSION)_pre.sql ../../utils/create_or_replace_to_create.pl
@@ -85,7 +85,7 @@ sql/$(EXTENSION).sql: sql/$(EXTENSION)_pre.sql ../../utils/create_or_replace_to_
 		| $(PERL) @top_srcdir@/utils/create_or_replace_to_create.pl sql/$(EXTENSION)_pre.sql \
-sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql | sql
+sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in | sql
 	cat $^ > $@
 	echo "SELECT postgis_extension_drop_if_exists('${EXTENSION}', 'DROP SCHEMA tiger_data');" >> $@
 	cat @srcdir@/../postgis_extension_helper_uninstall.sql  >> $@
@@ -179,13 +179,6 @@ sql/tiger_geocoder.sql: sql/tiger_geocoder.sql.in
 sql/add_search_path.sql: sql_bits/add_search_path.sql.in | sql
 	cp $< $@
-../../doc/tiger_geocoder_comments.sql:
-sql_bits/tiger_geocoder_comments.sql: ../../doc/tiger_geocoder_comments.sql
-	mkdir -p sql_bits
-	cp $< $@
 #hardcode for now
 #TODO: generate via create_unpackaged.pl
 sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/tiger_geocoder--unpackaged.sql.in | sql
diff --git a/extensions/postgis_topology/Makefile.in b/extensions/postgis_topology/Makefile.in
index f5c9c9920..3247605fe 100644
--- a/extensions/postgis_topology/Makefile.in
+++ b/extensions/postgis_topology/Makefile.in
@@ -10,8 +10,7 @@ MODULEPATH    = $$libdir/$(EXTENSION)- at POSTGIS_MAJOR_VERSION@
 	extlock.sql \
 	sql/topology.sql \
-	sql_bits/mark_editable_objects.sql.in \
-	sql/topology_comments.sql
+	sql_bits/mark_editable_objects.sql.in
 ifeq (@LIBINCLUDEMINORVERSION@,yes)
 MODULEPATH=$$libdir/$(EXTENSION)-$(MINORVERSION)
@@ -46,7 +45,6 @@ EXTENSION_UPGRADE_SCRIPTS = \
 	sql_bits/remove_from_extension.sql.in \
 	sql/topology_upgrade.sql \
-	sql/topology_comments.sql \
 EXTRA_CLEAN = sql/
@@ -71,12 +69,6 @@ sql/$(EXTENSION)--$(EXTVERSION).sql: $(EXTENSION_SCRIPTS) | sql
 sql/topology.sql: ../../topology/topology.sql | sql
 	sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e '/^CREATE SCHEMA/d;'  $< > $@
-../../doc/topology_comments.sql:
-sql/topology_comments.sql: ../../doc/topology_comments.sql | sql
-	cp $< $@
commit c7f249f4a03923ebe8f56b72f41449a13df6c1b4
Date:   Mon Sep 18 21:08:57 2023 +0200
    Add breaking change about new documentation requirements
index db10d3cae..0e6695379 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,11 @@
-PostGIS 3.4.0
+PostGIS 3.5.0dev
 xxxx/xx/xx
+* Breaking Changes *
+  - xmllint is now required to build comments and documentation
+  - DocBook5 XSL is now required to build html documentation
 * New Features *
   - #5055, add explicit <> geometry operator to prevent non-unique
Summary of changes:
 NEWS                                          |  8 +++++++-
 extensions/README                             |  9 ---------
 extensions/postgis/Makefile.in                |  5 -----
 extensions/postgis_raster/Makefile.in         | 10 +---------
 extensions/postgis_sfcgal/Makefile.in         | 11 ++---------
 extensions/postgis_tiger_geocoder/Makefile.in | 11 ++---------
 extensions/postgis_topology/Makefile.in       | 10 +---------
 7 files changed, 13 insertions(+), 51 deletions(-)
hooks/post-receive
