[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-581-g4f79c38c4
Mon Sep 18 13:43:49 PDT 2023
the project "PostGIS".
       via  4f79c38c41e6b660e053670149fe0875a31c9f64 (commit)
      from  a980403f8242bc6f0e0ed35af04d9d2cf0d01328 (commit)
revisions in full, below.
commit 4f79c38c41e6b660e053670149fe0875a31c9f64
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 18 22:40:22 2023 +0200
    Tweak configure check of depednencies
    - Don't disable extensions if comments cannot be built
    - Don't disable building comments if (unneeded) xmlcatalog isn't found
    - Reword warning about missing xml2pot
    - Reword warning about missing XSL for html documentation
diff --git a/configure.ac b/configure.ac
index 9b8922a8f..2a08a0c6c 100644
--- a/configure.ac
+++ b/configure.ac
@@ -207,8 +207,7 @@ fi
 AC_PATH_PROG([XMLCATALOG], [xmlcatalog], [])
 if test "x$XMLCATALOG" = "x"; then
-	AC_MSG_WARN([xmlcatalog is not installed so documentation cannot be built])
-	CAN_BUILD_COMMENTS=no
+	AC_MSG_WARN([xmlcatalog is not installed so documentation cannot be checked])
 fi
 AC_PATH_PROG([XMLLINT], [xmllint], [])
@@ -222,7 +221,7 @@ fi
 AC_PATH_PROG([XML2POT], [xml2pot], [])
 if test "x$XML2POT" = "x"; then
-	AC_MSG_WARN([xml2pot is not installed so translations cannot be updated])
+	AC_MSG_WARN([xml2pot is not installed so translation template cannot be updated])
 fi
 AC_PATH_PROG([MSGMERGE], [msgmerge], [])
@@ -331,7 +330,7 @@ if test "x$XSLBASE" = "x"; then
 	dnl Check to see if the automatically searched paths above located a
 	dnl valid Docbook stylesheet
 	if test "x$XSLBASE_AUTO" = "x"; then
-		AC_MSG_WARN([could not locate Docbook stylesheets required to build the documentation])
+		AC_MSG_WARN([could not locate Docbook stylesheets required to build the html documentation])
 	fi
 else
 	dnl The user specified an alternate directory so make sure everything
@@ -1772,20 +1771,14 @@ DEPS_MAKEFILE_LIST="$DEPS_MAKEFILE_LIST
 dnl ===========================================================================
 dnl See if we have the requirements for building the extensions, namely
-dnl the xlstproc tool for generating the comments SQL file.
+dnl the pg_config support
 EXTENSIONS=""
 if test "x$PG_CONFIG" != "xno"; then
-  if test \
-          -e doc/postgis_comments.sql -a \
-          -e doc/raster_comments.sql -o \
-          "$CAN_BUILD_COMMENTS" = "yes"
-  then
-      AC_MSG_RESULT([enabling PostgreSQL extension support...])
-      EXTENSIONS=extensions
-      AC_SUBST([EXTENSIONS])
-  fi
+    AC_MSG_RESULT([enabling PostgreSQL extension support...])
+    EXTENSIONS=extensions
+    AC_SUBST([EXTENSIONS])
 fi
 INSTALL_EXTENSION_UPGRADES=yes
Summary of changes:
 configure.ac | 21 +++++++--------------
 1 file changed, 7 insertions(+), 14 deletions(-)
hooks/post-receive
