[postgis-tickets] [PostGIS] #5545: Postgis upgrade from 3.2.3 to 3.3.2 failing on create or update function st_orderingequals
trac at osgeo.org
Wed Sep 20 10:58:40 PDT 2023
st_orderingequals
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.3.5
Component: build/upgrade/install | Version: 3.4.x
Resolution: | Keywords:
Comment (by robe):
@Dan,
Here is the way to work around it for now.
ALTER FUNCTION st_orderingequals(geometry, geometry) RENAME TO
st_orderingequals_old;
That should get you past the upgrade issue. You'll have to address later
though.
strk -- what is the naming convention you use so it can be auto dropped
later.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5545#comment:2>
