[postgis-tickets] [PostGIS] #5175: <> and != on geometry yield operator is not unique
PostGIS trac at osgeo.org
Thu Sep 21 13:01:59 PDT 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 3.5.0
 Component:  postgis  |    Version:  3.2.x
Resolution:           |   Keywords:
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Still missing:
   - testcase showing the problem being fixed (should fail when that new
 operator is removed)
   - uogradec support (if you add a test you'll see it fail on the woodie
 upgrade test)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5175#comment:19>
