[postgis-tickets] [PostGIS] #5548: ValidateTopology, failes with ERROR: XX000: GetRingEdges: edge id cannot be null
PostGIS trac at osgeo.org
Thu Sep 21 22:33:25 PDT 2023
be null
 Reporter:  Lars Aksel Opsahl  |      Owner:  strk
     Type:  defect             |     Status:  new
 Priority:  medium             |  Milestone:  PostGIS 3.4.1
Component:  topology           |    Version:  3.4.x
 Keywords:                     |
 We are running on
 POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="120" GEOS="3.10.1-CAPI-1.16.0"
 SFCGAL="1.3.7" PROJ="8.2.0 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/share/proj/proj.db" LIBXML="2.9.10" LIBJSON="0.13.1"
 LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY
 PostgreSQL 12.6 (Ubuntu 12.6-0ubuntu0.20.04.1) on x86_64-pc-linux-gnu,
 compiled by gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, 64-bit
 This is the failing call
 SELECT * FROM topology.ValidateTopology(
 'tmp_resultat_1804_t4',
 '0103000020A210000001000000050000001886F01924952D40A49DCA0D0ECC50401886F01924952D4046B267EF9CCD5040E6511F5B5BBF2D4046B267EF9CCD5040E6511F5B5BBF2D40A49DCA0D0ECC50401886F01924952D40A49DCA0D0ECC5040'
 Here is the output with DEBUG
 NOTICE:  00000: Limiting topology checking to bbox
 SRID=4258;POLYGON((14.79129105626184 67.18835778032968,14.79129105626184
 67.21270356299019,14.873743865559799 67.21270356299019,14.873743865559799
 67.18835778032968,14.79129105626184 67.18835778032968))
 NOTICE:  00000: Checking for coincident nodes
 NOTICE:  00000: Checking for edges crossing nodes
 NOTICE:  00000: Checking for invalid or not-simple edges
 NOTICE:  00000: Checking for crossing edges
 NOTICE:  00000: Checking for edges start_node mismatch
 NOTICE:  00000: Checking for edges end_node mismatch
 NOTICE:  00000: Checking for faces without edges
 NOTICE:  00000: Checking edge linking
 DEBUG:  00000: building index "pg_toast_1750651423_index" on table
 "pg_toast_1750651423" serially
 DEBUG:  00000: CREATE TABLE / PRIMARY KEY will create implicit index
 "shell_check_pkey" for table "shell_check"
 DEBUG:  00000: building index "shell_check_pkey" on table "shell_check"
 serially
 DEBUG:  00000: building index "pg_toast_1750651431_index" on table
 "pg_toast_1750651431" serially
 NOTICE:  00000: Building edge rings
 NOTICE:  00000: Found 476 rings, 445 valid shells, 31 valid holes
 NOTICE:  00000: Constructing geometry of all faces
 DEBUG:  00000: building index "pg_toast_1750651451_index" on table
 "pg_toast_1750651451" serially
 DEBUG:  00000: drop auto-cascades to type shell_check
 DEBUG:  00000: drop auto-cascades to type shell_check[]
 DEBUG:  00000: drop auto-cascades to toast table
 pg_toast_temp_6.pg_toast_1750651423
 DEBUG:  00000: drop auto-cascades to index
 pg_toast_temp_6.pg_toast_1750651423_index
           THEN
             edge_id
           ELSE
             -edge_id
           END ring_id
         FROM tmp_resultat_1804_t4.edge
         WHERE left_face = $1 or right_face = $1
         ORDER BY
           geom <-> $2
         LIMIT 1
       edgering AS (
         SELECT *
         FROM
           topology.GetRingEdges(
             (SELECT ring_id FROM leftmost_edge)
       SELECT
         ST_MakeLine(
           CASE WHEN r.edge > 0 THEN
             e.geom
           ELSE
             ST_Reverse(e.geom)
           END
           ORDER BY r.sequence
         ) outerRing
       FROM edgering r, tmp_resultat_1804_t4.edge e
       WHERE e.edge_id = abs(r.edge)
 PL/pgSQL function _validatetopologygetfaceshellmaximaledgering(character
 varying,integer) line 74 at EXECUTE
 SQL statement "INSERT INTO pg_temp.face_check
     SELECT face_id,
       topology._ValidateTopologyGetFaceShellMaximalEdgeRing(toponame,
 face_id),
       mbr
     FROM face
     WHERE mbr && bbox
     AND (
       CASE WHEN invalid_faces IS NOT NULL THEN
         NOT face_id = ANY(invalid_faces)
       ELSE
         TRUE
       END
     AND face_id NOT IN (
       SELECT face_id FROM pg_temp.face_check
 PL/pgSQL function validatetopology(character varying,geometry) line 336 at
 SQL statement
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5548>
