[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-611-g3df8cad26
Fri Sep 22 01:23:10 PDT 2023
the project "PostGIS".
       via  3df8cad260549fe6f2eba41b24acb3def9331303 (commit)
      from  dfe511b0121740cfbc26c5aed19086ea19f6af9a (commit)
revisions in full, below.
commit 3df8cad260549fe6f2eba41b24acb3def9331303
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 22 10:22:19 2023 +0200
    Add test for inequality operator
    References #5175
diff --git a/regress/core/operators.sql b/regress/core/operators.sql
index 0b8a44e3b..346e0f825 100644
--- a/regress/core/operators.sql
+++ b/regress/core/operators.sql
@@ -79,10 +79,15 @@ select 'ab3',ST_MakeEnvelope(2,5,4,8) |>> ST_MakeEnvelope(2,2,4,4); --t
 -- same as           =
-select 'eq1',ST_MakeEnvelope(2,2,4,4) = ST_MakeEnvelope(2,2,4,4); -- f
-select 'eq2',ST_MakeEnvelope(2,4,4,8) = 'LINESTRING(2 4,4 8)'::geometry; -- t
+select 'eq1',ST_MakeEnvelope(2,2,4,4) = ST_MakeEnvelope(2,2,4,4); -- t
+select 'eq2',ST_MakeEnvelope(2,4,4,8) = 'LINESTRING(2 4,4 8)'::geometry; -- f
 select 'eq3',ST_MakePoint(0,0) = ST_MakePoint(1,0); -- f
+-- inequality    !=  <>
+select 'neq1',ST_MakeEnvelope(2,2,4,4) != ST_MakeEnvelope(2,2,4,4); -- f
+select 'neq2',ST_MakeEnvelope(2,4,4,8) <> 'LINESTRING(2 4,4 8)'::geometry; -- t
 -- box centroid distance  <->
 select 'cd1', 'LINESTRING(0 0,0 10)'::geometry <->
diff --git a/regress/core/operators_expected b/regress/core/operators_expected
index 801e8bfec..28c2b86e7 100644
--- a/regress/core/operators_expected
+++ b/regress/core/operators_expected
@@ -44,6 +44,8 @@ ab3|t
 eq1|t
 eq2|f
 eq3|f
+neq1|f
+neq2|t
 cd1|4
 bd1|0
 bd2|1
Summary of changes:
 regress/core/operators.sql      | 9 +++++++--
 regress/core/operators_expected | 2 ++
 2 files changed, 9 insertions(+), 2 deletions(-)
hooks/post-receive
