[postgis-tickets] [PostGIS] #5546: ERROR: operator is not unique: topogeometry <> topogeometry
PostGIS trac at osgeo.org
Fri Sep 22 02:36:36 PDT 2023
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  assigned
  Priority:  blocker   |  Milestone:  PostGIS 3.5.0
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:  regression
Comment (by strk):
 Dropping the `operator <>` for geometry drops the ambiguity:
 pg35=# alter extension postgis drop operator <> (geometry, geometry);
 ALTER EXTENSION
 pg35=# drop operator <> (geometry, geometry);
 DROP OPERATOR
 pg35=# select (1,1,1,1)::topogeometry <> (1,1,1,1)::topogeometry;
 f
 Somehow the planner seem to still cast topogeometry to geometry even if
 there is no cast defined ?!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5546#comment:6>
