[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-626-g9288c549c
Mon Sep 25 03:56:52 PDT 2023
the project "PostGIS".
       via  9288c549c18130afa0551372877eb366c1a2e279 (commit)
      from  c34f64d61de01dfbb2e817e6e225d4b560a3c919 (commit)
revisions in full, below.
commit 9288c549c18130afa0551372877eb366c1a2e279
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 25 12:47:52 2023 +0200
    Fix box-filtered validity check of topologies with edge-less faces
    Includes regress test.
    References #5548 in master branch (3.5.0dev)
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index a644dd5ca..3375fb006 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -882,6 +882,7 @@ BEGIN
     AND e.edge_id IS NULL
   LOOP --{
+    invalid_faces := array_append(invalid_faces, rec.id1);
     retrec.error = 'face without edges';
     retrec.id1 = rec.id1;
     retrec.id2 = NULL;
diff --git a/topology/test/regress/validatetopology.sql b/topology/test/regress/validatetopology.sql
index 2aab5e6b6..8a23aed2e 100644
--- a/topology/test/regress/validatetopology.sql
+++ b/topology/test/regress/validatetopology.sql
@@ -195,5 +195,16 @@ SELECT '#5403.1', * FROM topology.ValidateTopology(
 ROLLBACK;
+-- See https://trac.osgeo.org/postgis/ticket/5548
+BEGIN;
+SELECT NULL FROM topology.CreateTopology('t5548');
+SELECT '#5548.0', topology.TopoGeo_addPolygon('t5548',
+  'POLYGON((0 0, 5 10, 10 0,0 0))');
+DELETE FROM t5548.edge;
+DELETE FROM t5548.node;
+SELECT '#5548.1', * FROM topology.ValidateTopology('t5548',
+  ST_MakeEnvelope(2,2,4,4));
+ROLLBACK;
 SELECT NULL FROM topology.DropTopology('city_data');
diff --git a/topology/test/regress/validatetopology_expected b/topology/test/regress/validatetopology_expected
index b0c954fee..82242d0a4 100644
--- a/topology/test/regress/validatetopology_expected
+++ b/topology/test/regress/validatetopology_expected
@@ -38,3 +38,5 @@
 #5105.edges_count|2
 #5105.faces_count|0
 #5403.0|1
+#5548.0|1
+#5548.1|face without edges|1|
Summary of changes:
 topology/sql/manage/ValidateTopology.sql.in     |  1 +
 topology/test/regress/validatetopology.sql      | 11 +++++++++++
 topology/test/regress/validatetopology_expected |  2 ++
 3 files changed, 14 insertions(+)
hooks/post-receive
