[postgis-tickets] [PostGIS] #5549: Have a bot test under pgextwlist conditions
PostGIS trac at osgeo.org
Tue Sep 26 01:26:14 PDT 2023
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  Website Management, Bots
 Component:  postgis  |    Version:
Resolution:           |   Keywords:  pgextwlist
Comment (by strk):
 What we need to test under sandbox:
  1. Create an postgis-regress specific unprivileged role (or user?)
  2. Have run_test.pl switch to the unprivileged role (or connect as the
 unprivileged user)
  3. Make sure postgresql backends will load pgextwlist and have its
 configuration properly set
 The current run_test.pl uses different connections for different steps so
 it's easier if the pgextlist configuration is done once, externally, and
 that direct connection as unprivileged user is used afterwards (using
 PGUSER/PGPASSWORD).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5549#comment:2>
